Projects Tucks 29 Roadster Build ---->
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 26, 2013.
  1. woodbutcher
    woodbutcher
    :D Hi Tuck.Great pics of the family.Thanks for posting.St Cloud is my Moms old stomping grounds.She was born and raised there(1906).A bit before your time.
    Good luck.Have fun.Be safe.
    Leo
    els, Tuck and enloe like this.
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  3. tfeverfred
    tfeverfred
    Nice job on the axle fill.
    els, Tuck and vetteguy402 like this.
  4. Rand Man
    Rand Man
    Love the gold and pearl white. You do dang good work and write a great thread. I like the kind that has so much detail, that it takes me a while to read through.
    els, vetteguy402 and Tuck like this.
  5. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Got this little guy all trimmed up with castle nuts-
    I decided not to drill this axle- or anything else. I keep looking trough the little books.. the bulk or majority of my FAVORITE hot rods don't have a drilled axle, hmmmmm.
    I'm practicing restraint.
    This axle is so pitted it'll get lightened up enough by the time I'm done filing and sanding.
    31chevymike, els, don colaps and 6 others like this.
  6. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Missed this- yeah I'll trim the bottom up (-;
    31chevymike and els like this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Miles of welding today... a bit of filing and grinding and a list of supplies to order like sand paper, belts for the small hand held belt grinder-
    heads up to anyone wanting to chrome bones- when you grind off the weld you need to weld it again- the weld is mostly external so if don't weld them they'll split, I usually cut it open at the seam a couple inches tack tack and cut a couple more and tack tack again- otherwise they'll end up wavy.
    There is usually a lot of corrosion in these seams so it sometimes helps to blast the open seam- other than that there is not a whole lot you can do about it-
    I finished the welding on the other side of the axle too and started to fill divots etc- not going to get too crazy on the axle just jet most of this type of stuff I can do in the garage at home after school starts.
    Both of the bones are pretty much identical- and the shock pockets are pretty much mirrored on each- fine tuned the notches for the shocks and some other detail work but overall really happy with the progress.
    I think I'll jump back to the pedals and steering and fine tune some of that next.
    Tuck
    Outback, 31chevymike, els and 4 others like this.
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Anyone seen one of these before? It's a Speed Products "SP" adapter to turn the filter parallel with the block instead of sticking straight out! Picked this up on eBay- kinda neat!
    31chevymike, Jet96, els and 6 others like this.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Every part of what you see in the above pic is getting chromed! (-;
    You're looking at the bottom of the frame, tack welded the sleeves in place that hold the U-bolt steering box ***embly.
  10. I'm liking the front fender scoop/vent pieces.
    Don't forget to take your kids back to the junkyard, saw your girl having a meltdown on IG, and it's the cutest thing I ever saw.
    els, enloe and Tuck like this.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Here is Speed Products oil filter adapter with a '55 canister- can't wait to chrome the canister!! It's cool it tucks it up and in a little it's not 90 degrees exactly it gives it a little more clearance- so cool!
    31chevymike, Jet96, kiwijeff and 7 others like this.
  12. enloe
    enloe
    from east , tn.
    Man you always find some cool parts for your builds
    els and Tuck like this.
  13. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    School's started and I have a couple new cl***es that I started that are consuming all of my time.... all of it.
    But... I've been wrestling with the idea of simplifying the shifter by going to a top shift lasalle and adding the olds short shaft to it. I found one for sale just need to go pick it up... maybe this weekend if I can work it out.
    20686514_1434186696637001_6671024022546808832_n.jpg 20686509_458776747829408_7906286140481601536_n.jpg
    I really really really love the Hurst Shifter- but maybe it'll find itself in my coupe or the Ranchero... by getting rid of the hurst I would give myself more room for my right leg and s**** pedal- the shifter linkage is another thing thats sort of in the way-
    I realize that I can problem solve my way out of it and use the Hurst... but at the end of the day if a top loader is available and its a good solution and simplifies the ch***is I think its a win win.
    Here's what I'm gonna do----> Good little piece by @Paul
    Lasalle Conversion by Paul
  14. Paul
    Paul
    Editor
    good idea,
    it's a little more involved than the linked thread with the '37 but very doable,
    couple things to watch for;
    tapered pins in shift rails,
    and the cluster shaft is a smaller diameter so that shaft,
    it's bearings and gear need to stay with the '37 case.
    get a copy of '37-'38 Cadillac shop manual to walk you through it,
    just use the Olds parts when putting it back together.
    here's a quick teaser thread of one I did a little while ago: '37 LaSalle gets short shafted
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks @Paul stoked to get it in there and see what it looks like. Hopefully I can pick it up Saturday.
  16. robber grin
    robber grin
    FUN read - sub'd
    beautiful family
    amazing car
    skills of a wizard
    Tuck likes this.
  17. jobbless
    jobbless
    Looks sweet so far. Love mags and whitewalls.. .... awesome work.. going to be a cool ride.
  18. vtwhead
    vtwhead
    Tuck, I have some parts for the 37 lasalle but no 1st/reverse or synchros. FWIW
    Walt
    Tuck likes this.
  19. tfeverfred
    tfeverfred
    Love the yo-yo.
    Tuck likes this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    you have a yo yo that you could copy... why not make a yo yo handle for the top loader... you are getting stuff chromed anyhow... a little lathe time with some acrylic to make the knobs...best of both worlds?
  21. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  22. Paul
    Paul
    Editor
    Nice, hope the inside is as cherry as the outside looks!
    Tuck likes this.
  23. vtwhead
    vtwhead
    ^^^^^^^X2
    Tuck likes this.
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    He said he bought it in 1972 for $165 from a Cadillac restorer! It looks like brand new!
  25. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  26. Holy ****balls that's cool!
    Outback, brad2v, Tuck and 2 others like this.
  27. enloe
    enloe
    from east , tn.
    Very Cool
    Tuck likes this.
  28. TexasSpeed
    TexasSpeed
    from Texas
    That's unreal. So awesome.
    Tuck likes this.
  29. vtwhead
    vtwhead
    Impressive!
    Tuck likes this.
  30. Paul
    Paul
    Editor
    What is that tail housing in your hand?
    'looks different than all the '50 Olds' I've seen.
    '37 looks super clean, like fresh ***embled and never run, I'm jealous!
    Atwater Mike, Outback and Tuck like this.
