Hot Rods Black painted engines
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Aug 22, 2017.
  1. jjjmm56
    jjjmm56
    from FL.
    They all look great. As for the guys that don't like black show me some other options.
  2. mountainman2
    mountainman2
    Oh Hell, here come the pink ones! :eek:
    Jibs and TagMan like this.
  3. shortypu
    shortypu
    My black later model sbc and my flathead and my sbf,I like black. IMG_4199.JPG IMG_0131.JPG IMG_7950.jpg
    j-jock likes this.
  4. wryhawk
    wryhawk
    Black engines are said to radiate heat well. Stude engines were black from 1962-1966. Prior to 1954, they were olive
    green, which was the color of the 30 wt. oil of the day, in case anyone cares.
    JT
  5. This is actually a Stock Eliminator engine. I've been painting them all black for 40 years. (except Pontiacs) My customer got it home and decided he didn't like it for his blue Chevelle. So he painted it the worst engine color ever, to match his spare . I'll let you guys guess what color they both are now:(
  6. Nope, it means you build beautiful engines. Colour doesn't matter.
  7. bobbooth
    bobbooth
    from limeyland
  8. FrankenRodz
    FrankenRodz
    My Favorite Engine Bay from any of my Projects.
    289 Ford in a '62 Fairlane.
    Strangely, I got more positive comments from painting the Water Pump the custom grey color.
    The attempt was to highlight some details on a black canvas.
  9. jjjmm56
    jjjmm56
    from FL.
    What's the best paint to use. I see the pros using base coat clear coat over epoxy primer. How well does this hold up?
  10. HOTRODPRIMER
    HOTRODPRIMER
    The engine in my old beater deuce sedan is black and looks nothing like the nice examples I see here. HRP
  11. Baumi
    Baumi
    312 Y-Block
    gggholson and Fern 54 like this.
  12. egads
    egads
    j-jock likes this.
  13. zzford
    zzford
    You are gonna love a black engine. At least until you try to find an oil leak.
    Spooner Clinton and CA. 280 like this.
  14. lurker mick
    lurker mick
    I use Eastwood's 2-part engine paint, holds up great. You can even brush it on and it looks good.
    Mick
  15. earlymopar
    earlymopar
    "2-part", as-in an "A" & "B" base and catalyst? -EM
  16. lurker mick
    lurker mick
    Eastwood calls it "High-Temp Ceramic Engine Paint" and a urethane activator, mix is 4:1.
    Mick
  17. mike bowling
    mike bowling
    327 in my black coupe
    302 HO in my green coupe
    Painted BLACK ( with WHITE firewalls) DSCN3200.JPG DSCN3529.JPG Camera 2-20-09 035.jpg DSCN2656.JPG
  18. Countn'Carbs
    Countn'Carbs
    from CO
  19. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
  20. joeyesmen
    joeyesmen
    My old 29 A roadster --
    Screen Shot 2017-09-03 at 3.20.16 PM.png Screen Shot 2017-09-03 at 3.21.36 PM.png
    Same car, when the engine used to be red . . .
    I personally think the black painted block looks a lot better.
  21. joeycarpunk
    joeycarpunk
    from MN,USA
    When going black on engines I prefer semi gloss over high gloss.
    theHIGHLANDER likes this.
  22. woodhawg
    woodhawg
    Runnin shine likes this.
  23. Donut Dave
    Donut Dave
    hendelec and wackdaddy like this.
  24. theHIGHLANDER
    theHIGHLANDER
    I'm in the same line as joey, semi-flat. You also get the added benefit of additional heat disipation and oil leaks are easier to find. The best material? Semi-flat Krylon over clean cast iron. I wash the parts with solvent after a good bath, then a nice brush cleaning with lacquer thinner. Apply just enough for complete coverage and it won't burn off. My old race block even held up to a hot tank over most of it. Yes, some came off and I simply touched it up. Apply all your natural aluminum parts or polished stuff, kind of hard to beat in the looks dept. If not black I prefer the stock color of whatever it is.
    Someone asked for suggestions. Chrome yellow and lots of contrasting black, aluminum and chrome parts and brackets. Any bright candies like red, gold, blue green. The secret there is again, light application so as not to peel from heat. Heavy primers and coatings can't take the heat cycles as well and don't last very long. Keep it simple and you'll keep it a long while.
  25. vtx1800
    vtx1800
    I don't remember for sure but I think my 63 Fairlane 260 block was black with Orange? valve covers, that was in the mid sixties, later I built a 289, I painted the block black, aluminum Weiand manifold and Cobra valve covers, if I have any pictures, not sure where they are.
  26. Koz
    Koz
    Beautiful finish on this one! Bobbooth from post #37. What was the technique/ finish material/ process if I might ask? Great looking flatty. A lot of time spent on those heads I'm sure.
    juan motime and mike bowling like this.
  27. George
    George
    Seem to recall that. Any engine I don't paint Ford Blue gets Black.
  28. alfin32
    alfin32
    from Essex, Ma.
  29. I'll show you mine if you show me yours.
    This engine is sort of traditional and a non traditional sort of a way and has been black for about 20 years. Some motors are purdy and others are just old mules I suppose.
