Customs finishing off my pre-war cheveee project
Discussion in 'The Hokey Ass Message Board' started by nunattax, Aug 31, 2015.
Tags:
  1. tb33anda3rd
    tb33anda3rd
    sorry to hear about Setzer.
    TFoch likes this.
  2. TFoch
    TFoch
  3. nunattax
    nunattax
    setzer 001.JPG setzer 002.JPG great dog hard act to follow
    scotty t likes this.
  4. bubba55
    bubba55
    Morning Chris - sorry to hear about yer loss of Setzer - take care me friend
    nunattax likes this.
  5. nunattax
    nunattax
    thanks again the build goes on ceremony completed holly tree marks the spot
  6. Leakie
    Leakie
    Sorry for your lose, dude. He would have enjoyed the ride.
  7. nunattax
    nunattax
    hi leakie hard job to replace him but well find another guardian the great memories live on 13 years of them.never a dull moment. life goes on ,the build goes onnot too far away from starting her up.watch this space
  8. nunattax
    nunattax
    spent a few hours today trying to install the p***enger side winder mechanism and replacing broken/missing track.going good so far hope it will look like new when its welded up and painted.its a challenge to keep it looking stock even though nobody will be looking at some of this tuff
  9. nunattax
    nunattax
    window winder plus various 001.JPG replacement window track trial fitted nothing welded just bolted so I can make adjustments if needed untidy floor is a sure sign of loads happening
  10. nunattax
    nunattax
  11. nunattax
    nunattax
    got the bolts machined to take the m*** produced look away,made some plates to weld nuts to,to make ***embling the bed corners less fiddly,some bolts are stainless so ill powder coat them satin black
  12. Leakie
    Leakie
    Those bolts turned out pretty cool, nice touch man.
  13. nunattax
    nunattax
    thanx bud some bolts are stainless m8 others 3/8 unc.machining them gave them a uniform look..worked outwell.bolts are ducafe specials
  14. bubba55
    bubba55
    Hey Chris - finally took me twuck to Alan / Flatlander - he's welding on my ch***is and installing IFS and mounts for my 327 and T5 and 9" rear - while I'm working on my garage - almost finished with the construction and then will have to paint - keep up the good work you Irish Nut !
  15. nunattax
    nunattax
    good to hear you are making progress.before you send your doors for paint don't forget to remove rubber strips from thetop of the metal door cards and in the correspomding place on the doorif you apply heat with a blow torch they become soft and come out easily with a utility knife.its herd workif you don't heat first,if you don't find them let me know ill send a pic of where the y are located gentle heat will do go easy
  16. nunattax
    nunattax
    aidan feightery pass door winder assembly 004.JPG not much to report for today up early and in the hot rod shop.got sidetracked with a visiter from Australia..trial fitted the gl*** felts p*** side.broken tab on p*** side so I made one and fitted it.,riveted it on.and painted it.working well so far tech tip bend the felts around a suitable sized pipe for the corners and get nice even bends.gl*** will fit the openings much better.
  17. nunattax
    nunattax
    new kid in town[​IMG]
    chop job and tb33anda3rd like this.
  18. Leakie
    Leakie
    That was quick! Good looking pup.
  19. nunattax
    nunattax
    we are having great fun with him,disrupted progress on the 38 for a bit all work and no play you know the saying.no name yet
  20. TFoch
    TFoch
    Cute little guy! Looks like a bear cub.
  21. nunattax
    nunattax
    great little guy eager to learn new guardian to the 38
  22. nunattax
    nunattax
    door tracks pass side 002.JPG door tracks pass side 001.JPG fitted p*** side door gl***had some trouble getting the gl*** in due to a small eror on my part but its in now.just a little tidy up tomorrow and paint a few bits,make a little bkt for the rear of the felts to stop it popping out of the tracks when the gl*** is wound up and were there.
  23. bubba55
    bubba55
    Nice Chris - it's good to have a buddy !
  24. nunattax
    nunattax
    top man on the lathe,leakie
  25. nunattax
    nunattax
    made up some alloy plates to fill the voids in the a pillar behind where the door straps mount.1.5mm alloy weigh next to nothing.stuck to the back of the a pillar with adhesive window brackets 002.JPG will keep the weather out
  26. nunattax
    nunattax
    wiring has commenced wiring started 001.JPG 1 day in starter is turning over and charging circuit complete another 1-2 days in it
    chryslerfan55 and TFoch like this.
  27. nunattax
    nunattax
    today trial fitted the inner wings and wings along with the hood.checked for fit...some shimming needed here and there but not too far out.
    chryslerfan55, K13 and TFoch like this.
  28. Leakie
    Leakie
    Wow, looks like a whole truck! Looks good, almost there bud!
  29. redwelter
    redwelter
    Nice work, keep it going.
  30. nunattax
    nunattax
    thanks leakie and red.first dry run on the front is going well,
