Customs Merc chop progress with compiled project pics
Discussion in 'The Hokey Ass Message Board' started by Verbal Kint, Jun 1, 2009.
  1. drdave
    drdave
    Weird deal. Any reason the intake would be warped or maybe would have been surfaced or something that makes it not exactly on the same plane as the heads?
  2. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    I believe there is a specific 3x2 intake for the 265. I think there are 2 different part numbers offered them. one is 265 only.
  3. Kustomkid
    Kustomkid
    from Montana
    I have the correct intake. C355. The C357 is the larger port intake that they are still making.
  4. Kustomkid
    Kustomkid
    from Montana
    I may finally got the intake sealed. Never had to silicone the gaskets around the water jackets before. Radiator is still full after 48 hrs. The rebuilt wiper works great and I got the wiper washers working to. Hopefully I will get my rearend tonight and get it in Sunday.[​IMG]
    drdave, OG lil E and tomkelly88 like this.
  5. Kustomkid
    Kustomkid
    from Montana
    My rearend is finally done! 3.31 ratio in the original merc housing. Should have it in Sunday!! Finally...
    drdave, OG lil E and 1949 mercury like this.
  6. Kustomkid
    Kustomkid
    from Montana
    Aussiepete., tomkelly88 and OG lil E like this.
  7. Kustomkid
    Kustomkid
    from Montana
    The new rearend is in! Once the kids go to bed tonight, I'm going to get the rear brakes installed. [​IMG]
    OG lil E, tomkelly88 and drdave like this.
  8. Kustomkid
    Kustomkid
    from Montana
    Rear brakes are done, tightened and rolling. Tomorrow will be the front brakes and bleeding. Radiator is still full of water so that's good. Got to tear the back of the transmission apart to see why the yoke won't slide in all the way, but should be able to get a measurement for the drive shaft and get that ordered on Monday. I think I might be able drive the car in a couple of weeks!!!
  9. drdave
    drdave
    Almost there! Whoop, whoop!!
    Kustomkid likes this.
  10. Kustomkid
    Kustomkid
    from Montana
    It's even ****ing gas out of the tank! My old merc couldn't even do that.
  11. drdave
    drdave
    [emoji106][emoji106]
  12. Kustomkid
    Kustomkid
    from Montana
    And the driveshaft will be here Friday! Brakes hopefully will be bled out on Thursday.
    OG lil E and drdave like this.
  13. Kustomkid
    Kustomkid
    from Montana
    drdave and OG lil E like this.
  14. Kustomkid
    Kustomkid
    from Montana
    And the drive shaft is in. It's really nice not having to use a Mercury rear u joint. [​IMG][​IMG]
    I think it will move sometime tomorrow!!!
    Squablow, Aussiepete., drdave and 2 others like this.
  15. Kustomkid
    Kustomkid
    from Montana
    I got the merc to move and drove it back up onto the lift for tomorrow! Got to pull the ****** tunnel and get the dipstick in and get the trans filled, but it moved!!!
    j-jock, Peanut 1959, OG lil E and 2 others like this.
  16. Kustomkid
    Kustomkid
    from Montana
    Got first drive in around the parking lots. The powerglide has problems, I think it's the one I rebuilt in high school and it doesn't have reverse. But was nice to drive it. [​IMG][​IMG][​IMG]
    55Deso, j-jock, Squablow and 6 others like this.
  17. tomkelly88
    tomkelly88
    WOOHOO! Nice to see it out on the street. Great achievement kustomkid!
  18. drdave
    drdave
    AWESOMENESS!!!
  19. Kustomkid
    Kustomkid
    from Montana
    Going to try and get the steering column all put together tonight. Got the turn signal switch rewired and ready to install. [​IMG][​IMG][​IMG]
  20. Kustomkid
    Kustomkid
    from Montana
    Got the wiring through the steering column, went easier than Ithe last one I did.[​IMG]
    The column is tight and the wheel is tight! I think it's going to be nice having the automatic column in the car. [​IMG][​IMG]
    Column wiring almost finish and in the junction box. [​IMG]
    And the horn circuit works. Got to go get some 10 gauge wire and get the main power and alternator wired up.
    j-jock, Squablow, tomkelly88 and 4 others like this.
  21. Kustomkid
    Kustomkid
    from Montana
    The merc is running off of the wiring now. No more hot wiring. Got working horns, spotlights and starter off the original ground ****on. I may have figured out the transmission problem. I think I have a gasket behind the rear pump. Going to try and pull it apart tomorrow and see if I can't get reverse.
    1959Nomad, OG lil E and drdave like this.
  22. Kustomkid
    Kustomkid
    from Montana
    I think I got the powerglide fixed. Rebuilt it my senior year of high school and I'm thinking someone played a joke on me in shop cl***. The rear tail shaft seal was in between the rear pump and the case. Had a 1/8 inch gap between the 2. Reverse is working and it's going into gear instead of it thinking about it. Still got to see if it will shift but no more pushing!!![​IMG]
    55Deso, Squablow, tomkelly88 and 3 others like this.
  23. drdave
    drdave
    Nearly ready to drive to work! :)
    So I have to ask, it looks like your shop is behind/attached to a business. Is it a family business?
    OG lil E likes this.
  24. Kustomkid
    Kustomkid
    from Montana
    I live in a old building. This used to be a creamery from 1935 thru 98. The creamery closed up when they couldn't buy cream any more. It all had to be pasteurized. So I got a small house, big garage.
    Squablow and OG lil E like this.
  25. drdave
    drdave
    That's pretty neat. I had thought in one of the earlier pics it looked like it said creamery or dairy on the side of the building. I always thought it would be "fun" to live in a set up like that. Fitting you have the dairy truck....which I think I should try to talk you out of....although my wife thinks I should be content with the projects I already have stacked up. LOL (she does think dairy trucks are cool though....)
  26. James D
    James D
    Really cool looking car.
  27. Kustomkid
    Kustomkid
    from Montana
  28. drdave
    drdave
    That doesn't look like home, so I'm going to have t ***ume it's driving. [emoji16][emoji106]
    chryslerfan55 and OG lil E like this.
  29. Kustomkid
    Kustomkid
    from Montana
    It is home and it's driving! Hopefully it will be licensed next week.
  30. Kustomkid
    Kustomkid
    from Montana
    55Deso, chryslerfan55, drdave and 2 others like this.
