Projects "Big" -flathead project pics
Discussion in 'Traditional Hot Rods' started by AULIZ, Aug 26, 2017.
  1. AULIZ
    AULIZ
  2. AULIZ
    AULIZ
  3. tubman
    tubman
    Anybody wanna guess how many posts there will be about using that kind of engine stand on an early flathead?:D
    Other than that, there's some impressive stuff there!
    Atwater Mike, Jet96, chiro and 3 others like this.
  4. FlatJan
    FlatJan
    yes there will surely be some hints in that direction ;)
    although auliz last build flatty supported it also, right?
    Jet96 likes this.
  5. captainjunk#2
    captainjunk#2
    lol i cringed when i saw the way the engine was mounted on the stand , but i figured i would nt say anything about it ,there s been enough said about it in past threads
  6. Fordors
    Fordors
    Nice photos Auliz, they show the shop of a serious hot rodder. I see a large, commercial planishing hammer, lathe, some precision tools and lots of quality parts for your blown flathead project. Offenhauser heads with the fins milled off (I like the look, it is different), Ross pistons, aftermarket rods, is that an Isky 400 cam?, and that looks like a steel crank hub/balancer.
    Your McCulloch is either a '39-'40 as you mentioned in your other thread or it could be the variation that some say McCulloch offered at some point. The brochure I scanned shows the outlet portion of the blower (connected to the intake manifold) having exhaust heat running to it and your blower has the heat exchanger that connects to the p***enger side cylinder head, then to the output side of the blower and finally to the radiator. There are two trains of thought with some believing that the exhaust heat was to aid in vaporization of the gasoline in cold weather operation and that it was thermostatically controlled and in the case of the type you have some believe it was for vaporization with others saying it was to cool the intake charge. Maybe someone out there knows for sure.
  7. AULIZ
    AULIZ
    Wooden engine front suppert used. Empty block + crank is not so heavy yet, but board is there all the time (except when took pic).
    Potvin 400 cam. I have use in my Italmeccanica blown engine Isky 400jr.
    Intake runners ported and valves 1.6" pro flo.
    Ex. runners ported smoothly, valves 1.5"
    Eagle 4.25" crank. I do not know quality of those china cranks. I have used earlier early 50s mercury forged cranks.
    aulis
  8. MickD
    MickD
    Chinese made crank???!!! Jeesus !You're game! My experience with Chinese steel has been all bad. I've heard that they use insufficient carbon in their steel. Not that I'd have a clue. I don't know how they make steel. I just know that it all seems to be ****. I hope for your sake you haven't done the wrong thing. I'd be going over every inch of it with a magnifing gl*** looking for splits & cracks and imperfections, if you haven't yet put it together.
  9. khead47
    khead47
    ^^^^ forget the magnifying gl***. MAGNAFLUX !!!!!!!
  10. tubman
    tubman
    AHH! I knew there had to be an explanation from someone who's shop looks as good as yours. I only work on 8BA's, but I'm gonna get one of those sidemount adapters anyway, because I'm sick and tired of installing the flywheel, clutch, and bell housing when the engine is hanging from the cherry-picker.
    sidevalve8ba, Atwater Mike and Jet96 like this.
  11. christmas tree
    christmas tree
    I do not know anything about China steel but I run a **** crank and so far I like it. I turn it 6000 in the traps and thats pretty good for a 4 3/8 stroke.
  12. AULIZ
    AULIZ
    I agree. I have made many Stroke SB and Stroke BB chevy engines and all those ****, Eagle cranks are work fine if HP is under 600-700hp.
    I have sold over 20 Chrysler BB 440 source stroke kits to Finland. Only one crank broken, but that engine was racing use with BDS 8-71 + methanol,.... All those Brandons 440 source stuff has made in China.
    I think nearly all or all Eagle and **** cranks are made in China.
    10y ago **** were in the court. They market USA made cranks, but stuff come from China.
    Jet96 likes this.
  13. AULIZ
    AULIZ
    Note; SFI Spec Engine stand front support.
  14. lippy
    lippy
    from Ks
  15. stillrunners
    stillrunners
    from dallas
    cool.....build on !
  16. bryanyeskie
    bryanyeskie
    from Hixton
    Flatheads are cool no matter what you do to them!
  17. MickD
    MickD
    I 'spose there's gotta be good and bad steel manufacturers in China, same as anywhere. Perhaps the bads outweigh the good. **** must have done their homework to find the better ones. Good on'em.
    I believe there's a state authority in Queensland who tendered out steel for a bridge. Chinese steel supplier won out over a local Australian supplier. Within 18 months or so, the ****** bridge was condemed because the steel was failing! Mind you, I heard all this second hand...
    Perhaps an Aussie member might know a bit more about that one?
  18. AULIZ
    AULIZ
    IMG_4345.JPG IMG_4346.JPG View attachment 3639845 I knew this problem. ****. Need to "chop" magneto.
    I can turn angledrive little to left. There is little space between supercharger and magneto. I want to use 2 belts from crank up to supercharger. Just rebuilding one pair 2row truck waterpumps and Im gonna use this truck crank pulley too.
    Fluidamper is nice (and expensive), but not work with 2 belts. Need to use fluid in some another engine.
    I can chop angle drive maybe 8-10mm. Hope those help to get all work.
    I do not want to change another style ignition.
    Maybe fixed advance vertex/ronco/scintilla -magneto is little lower?
    A View attachment 3639844
    LOU WELLS, v-v and AndersF like this.
  19. tubman
    tubman
    I wish I had your problems!:D
  20. You do beautiful work and I love your sense of humor! Cool build!
  21. AULIZ
    AULIZ
    Ha haa, I know these are small problems. I have solved big problems 2003 (when divorced)....
    sidevalve8ba likes this.
  22. theHIGHLANDER
    theHIGHLANDER
    I 1st thought raise the supercharger, but as I look it all over can't you just space the mag fwd a bit? I know it involves a couple machined parts but it looks like you're up to it. **** and Eagle, 1 of the owners is a close friend of one of my cl***ic Packard friends. They random check their metallurgy on a regular basis to ensure a quality product within their design parameters (like max HP). No worries, except I can't recall if it's **** or Eagle. There's Eagle cranks floppin around in 8 sec. cars here near Motown.
  23. The 39 guy
    The 39 guy
    It is good to see you posting again Auliz! Great looking Flathead project! I look forward to watching you solve all of the fitment issues and turn this impressive group of parts into a strong running flathead.
  24. AULIZ
    AULIZ
    Thanks. I like this new Project engine, something new for me.
    My Italmeccanica engine is so strong and takes very fast top RPM.
    I sold my Panel Delivery (1940) to Germany and 1953 panhead to Finland. Now need to built new engine before new hot rod Project (easy Project) is arrive from Iowa US to Finland. Also need to weld 5w coupe Project ready,....but engines first.
    Aulis
    nb. Yes, I know also many street racers (8 - 9sec cars in 1/4mile) who are use Eagle or **** cranks. 4.25" stroke is long. Piston speed is huge.
  25. AULIZ
    AULIZ
    Finally engine Project is continue...
    Italmeccanica blower engine has been working fine, but 1.5weeks ago another Navarro head was broken (outside).
    Those heads are 70y old and possible to rebuilt.
    I decided to change brand new Navarro heads. First make chambers ready and then polished before bolt on.
    This weekend Installed "Big" flathead pistons and rods, valves....
    Oilpan is nearly ready. Need to work with it little more than normally, because this 4.25" stroke crank needs more space than 3.75 and 4.00 crank,....
    AndersF and Stogy like this.
  26. AULIZ
    AULIZ
  27. Johnny Red
    Johnny Red
  28. AULIZ
    AULIZ
    Thank You Sir.
    Yesterday i finally get oilpan ready. 4.25" stroke makes little extra job, but now all are in and oilpan has lost little more aluminum inside.
    Next need to make Schiefer flywheel ready, NOS stuff, and bolt it on before can install oilpan finally.
    Yesterday I note that one valve quide is upper than others. I do not know why, but once more I lilfed valve out and shim spring 2mm. Maybe they have machined quide lock "bed" upper than other? If I look in In-runners, one quide is 2mm upper than others. Strange.
    aulis
  29. AULIZ
    AULIZ
    Decided that Im not use that NOS Schiefer Alum. flywheel. Changed new teeth ring on Albro Alum. flywheel. Flywheel was in deep freezer and I BBQ ring.
    Clutch is 10". New pressureplate new disc.
    Offy heads are bigger job. Today I started to work with them. Need to "cut" 2mm from chambers.
    High lift cams are not work with old 40´s-50´s heads.
    Oilpan ready and bolted on.
    IMG_4384b.jpg IMG_4385b.jpg IMG_4389b.jpg IMG_4390b.jpg IMG_4391b.jpg IMG_4393b.jpg IMG_4394b.jpg
    dwollam likes this.
  30. flatheadpete
    flatheadpete
    from Burton, MI
    Yeah man! Great build. Keep on going and make sure to post video of it running.
    Lättähattu likes this.
