Projects Phoenix reborn. Model A rebuild after near fatal accident.
Discussion in 'The Hokey Ass Message Board' started by Swiss50chevy, Jan 22, 2017.
  1. Swiss50chevy
    Swiss50chevy
    That is a good idea. Right below the rear gl*** where the deck lid meets, there is a slight low spot on both side. Sort of like crushed a oil can.
  2. Swiss50chevy
    Swiss50chevy
  3. GordonC
    GordonC
    I think as the force of the impact went into the body it pushed the roof up and back. Looks like it did from the kinks over the B pillars and the fact the top of the quarters dropped down like that. Take measurements on the door opening and compare it to a stock non hit coupe at front and rear of opening. Also check the floor rails at the B pillar. If the roof went up I would be willing to bet so did the sub rails at that point. If you can some how brace the top at the B pillars and bring the roof down to square up your door opening it might help with the kinks in the roof and the quarters. Fitting the cowl may be another story after doing that though... A lot of metal to move around there but not impossible.
  4. Swiss50chevy
    Swiss50chevy
    Dude I believe you are correct. Looking at some previous pictures I can see where the roof could have shifted rearward and caused the bulge in the rear quarters.
  5. 30tudor
    30tudor
    The sheet metal on this car has suffered greatly between this build and the previous one.
  6. Swiss50chevy
    Swiss50chevy
    Finally had a free Sunday to tinker in the shop. Decided to get started piecing together the rear axle. I'm going with a 41 banjo. I've collected enough banjo parts in the past 4 years to build one good one. The gear ratio comes out at 3.63? Anyone know a good place to buy bearings and gasket kit for these?
    kidcampbell71 likes this.
  7. Swiss50chevy
    Swiss50chevy
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Still had enough time in the day left to tear into the mercury flathead I pulled out of this 51 F2 a couple years ago. Tried to get in running last year but no luck. Ran compression check on cylinders today. 60,90,60,30 on RH bank and 30,60,30,0 on LH bank.
    Pulled the intake and verified no stuck valves. Ran a leak cylinder leak down test on cylinder with 0 psi of compression and found air leaking into crankcase(stuck rings). Went ahead and pulled the heads to inspect. I am very satisfied with the condition of the cylinder walls. Standard bore 3 3/16. Guess it's either gonna be a rering or complete build[emoji848][emoji848][emoji848][emoji389][emoji389][emoji373]
  8. Swiss50chevy
    Swiss50chevy
  9. Swiss50chevy
    Swiss50chevy
  10. Swiss50chevy
    Swiss50chevy
  11. swiss39coupé
    swiss39coupé
    Hi Swiss
    How is progress? Long time no heare. I was a bit away due family pause. But now back for wrenching.
    What's about you?
    Regards from Switzerland.
    Dani
  12. spanners
    spanners
    As a retired truck driver but a panelbeater/spraypainter in a previous life, the bent ch***is has forced the firewall up and bent the body like a banana. It's too late now but before cutting the firewall off you needed to bolt the cab to a jig and pull the front back down while applying a touch of heat to the kinks in the body. I know it doesn't help now but the information might help others that tackle something similar.
    Build or borrow a frame jig and bolt down the front and rear and jack up under the rear bulkhead area while GENTLY warming the body kinks with a gas torch. Hopefully that excess in the quarters will reduce. Don't let the pressure off till everything cools down. You might have to do this several times. Good luck.
    Bugguts likes this.
  13. junkman8888
    junkman8888
    Spanners is right; when repairing any kind of body/frame damage you want to pull things back into shape before cutting anything apart.
    As I see it you have two options; take the body to a frame shop and have it pulled back into shape, if you can't afford that, see if you can find an AA truck frame (or any big truck frame from the '40's-'50's) to turn into a body straightening jig. If the body is bent up like a banana at both ends, you'll have to "elevate" the body using 2 x 4 blocks in the middle, then draw the ends of the body down using long bolts, working the wrinkles out as you go. If the top needs to be pulled forward, you'll have to weld or bolt a "post" to one (or both) of the frame horns so you can have something to pull to. All is not lost, don't give up now.
  14. Swiss50chevy
    Swiss50chevy
    Thanks but I no longer have this body. Let us go to a more ambitious owner.
  15. Swiss50chevy
    Swiss50chevy
    [emoji1309]Hello, wie gehts?
    Yes I have also been away from building hot rods for a couple years. Mostly busy with work and family. November of 2018 wife and I took trip to Europe and spent some time in Zurich! Loved it!! We will be back.
