Projects 1957 Corvette M/SP Project
Discussion in 'Traditional Hot Rods' started by Baron, Jun 7, 2013.
  1. hoop
    hoop
    Baron ,Time flies when your`e having fun.
    Baron and loudbang like this.
  2. Baron
    Baron
    All back together. I'll order the new driveshaft Monday and hopefully all will be good. Also rewired my kill switch so now it works as it should( alternator wire was back feeding the system). 20170603_171758.jpg
    els, swade41, Finn Jensen and 5 others like this.
  3. Baron
    Baron
    Car's back up and running. Rear end is nice and quiet. 4.11's pull even better than I though they would over the 3.73s in the stock rear end. All good news. 57 Corvette olds rear end 6 14 17.jpg 57 Corvette new driveshaft  6 14 17.jpg 2017-06-07 18.48.25.jpg
    els, catdad49, cactus1 and 12 others like this.
  4. jackal396
    jackal396
    You been holding back? whats up with the COE?
    jp
    els, Baron, Bowtie Coupe and 2 others like this.
  5. Mike Colemire
    Mike Colemire
    I just seen this thread, that is one awesome car, stance and everything is perfect.
  6. swade41
    swade41
    from Buffalo,NY
    Back up and running better than before is good news !
  7. Baron
    Baron
    Built the COE in 2010 just after finishing my 55 Chevy. 47 COE cab I mounted on a 1990 1 ton dump truck dually chassis. Shortened up the wheelbase from 136" to 106". I'm running a 1984 Corvette 350 (now Holley Carbureted) with 400 trans, mounted under the front seat( about 18" back from the stock location of the six cylinder) which makes it almost mid-engine. Been a great shop truck.
    Thank's Mike
    That's as good as it gets. Trying to log some miles on it before I give it a good thrashing. :) 2016-07-16 16.11.11.jpg
  8. Baron
    Baron
    Took my friend Tony out for a "quick, little ride" in the Corvette this morning. Tony owns the Caddy powered 55 Thunderbird Gasser. Here is a short video. 454 is running good.
  9. jammer
    jammer
    I'm next , where do I sign up ???
    loudbang and Baron like this.
  10. SUSQ
    SUSQ
    Man I love this car. Well done!
  11. elgringo71
    elgringo71
    Great job Baron, that video put a big smile one my face.
    OahuEli, loudbang and Baron like this.
  12. jimdillon
    jimdillon
    Good stuff Baron. Looks and sounds great.
    els, loudbang and Baron like this.
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Awesome video. Awesome Corvette.
  14. YJ4000
    YJ4000
    Yoo Hoo that was fun!! Sounds great,
    Ryan.
  15. loudbang
    Guessing you missed the "SPEEDING FINES DOUBLED in construction areas" sign as you were getting on the highway. LOL :rolleyes: But wow that thing RPMs FAST.
    els, enloe and Baron like this.
  16. Zeke 32
    Zeke 32
    Just watched the video....The BALLS Baron....
    Thanks for the ride.
    Hayseed would be proud.
  17. Cosmo49
    Cosmo49
    That American flag in third gear shifting into fourth does it all for me! Great car, thanks for the ride!
  18. Cosmo49
    Cosmo49
    Feeling a little blue today so I took another little ride in your car...all better now, THANKS.
    Baron, Bowtie Coupe and loudbang like this.
  19. movin/on
    movin/on
    Baron: not trying to ask too many questions but I will ask this one.
    My engine will have just over 600 Ft/lb of torque which is probably just under yours. Did you do anything to re-enforce the frame from twisting or is a stock C1 frame strong enough? I'm using a dropped 31 Chevy or Dodge I-Beam or maybe a narrowed early Econoline I-Beam. Rear axle is a Ford 429 CJ 9" with a 4.57 spool. 35 spline. Will the stock frame hold it for agressive street driving and a few 1/4 mile strip blasts? It's a "decluttered" 60 Vette. Thanks for any ideas.
    Movin/on
    Baron and kidcampbell71 like this.
  20. catdad49
    catdad49
    Baron, thanks for the ride!
  21. Baron
    Baron
    The frames on these C 1's are pretty rugged, especially with the heavy X-member tying the frame rails together. When I removed the stock front end, I made a new radiator support that bolts to the bottom of the rails and then I put a piece of 1 3/4" tubing that bolts to the inside of both rails which stops the frames ( from the firewall forward) from twisting by keeping the frame rails parallel to each other. Other than that, I think you'll be fine. The cars are light(mine weighs 2800 lbs ). Any questions or pictures you'd like to see what I did, just email me at csx1965@comcast.net
    More than happy share any info I have. Good luck with your build.
    PS Check out Crazy Grandpa's 57 and Jackal396 's 59 Corvettes. Both are killer cars, super fast, and both have twice as much HP/TQ than I do.
    19702107_1365453380198643_5516200291044808555_n.jpg 20160601_165804_resized.jpg
    catdad49, nxpress62, swade41 and 7 others like this.
  22. movin/on
    movin/on
    Thanks for the reply. I'll be changing things and re-inforce the X member to install a non-Chevy but torque type engine of the 1960's era. But it will present my 60 Vette nicely. More to come next year but a picture of the intake.
    The engine will be a stroker @ 454 cubes. Oregon Cam, Arias pistons , H-beam rods, Vertex Mag and original Cast Iron exhust manifolds with a forged RC bell housing big in & out top loader. Vette purests will literaly hate me.
    FE6X2Stromberg WW.jpg but -- THF?
    Just Movin/on
    catdad49, els, Bowtie Coupe and 5 others like this.
  23. loudbang
    FE POWER yay :)
    els, Baron and OahuEli like this.
  24. jimdillon
    jimdillon
    The purists may hate you but many of us will not be in that camp for sure. I also am a FE fan and with the right cam they really sound great (and run be pretty darn good as well). Good luck with your build.
    Not sure how much you really have to beef up the C1 frames. The 60 Vette frame I dragged home from Alabama a few years ago sported a BBC that ran in gas and modified production that ran for years down south. Not only did the prior owner not beef it up he actually cut a bit of the x member down a bit to make it easier to pull his Doug Nash 5 speed out at the track for work and clutch changes. They are pretty stout frames (basically a shrunken version of a 49 Chevy) when weight was not as much a consideration. I actually remember guys removing the x member back in the 60s which I did not get then or now.
    If there is a weak spot it may be in the kickups as the frames get dirt and water trapped in them (especially in some of northeast states with winter) and they rust out. I recently replaced the metal in the kickups for that very reason in a project. If your kickups are good that will be a plus for sure.
    catdad49, els, Bowtie Coupe and 3 others like this.
  25. movin/on
    movin/on
    I haven't looked at the frame kickup's but the car has been off the road since the late 60's and always stored inside.
    Not a bit of rust on the engine compartment rails or cross members. It still has the "canvas" rear axle straps.
  26. Baron
    Baron
    Two hot rods, different time zones. 20170605_125330.jpg 20170728_103429 crop.jpg 57 Corvette WP.jpg
  27. elgringo71
    elgringo71
    Killer Baron, Absolutely Killer
  28. Baron
    Baron
    Thanks Jason. I did not get a chance to race it this year, but looking forward to next season.
    els and elgringo71 like this.
  29. elgringo71
    elgringo71
    Rising up like a cutter through ice
    els likes this.
  30. hoop
    hoop
    They both look great.Nice work Baron.
