Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. enloe
    enloe
    from east , tn.
  2. loudbang
    Looks like easy access parts were polished but hard to reach spots weren't LOL. :)
    1947knuck, chryslerfan55, els and 3 others like this.
  3. loudbang
    These from bangshift coverage of Speed week
    Max wedge
  4. mad mikey
    mad mikey
    NICE, LOUDBANG!!:)
  5. 402BOSSMAN
    402BOSSMAN
    Another one to my collection. A Herbert Hat Injector 1 of about 60 made. This one is cherry!
  6. ssaza25
    ssaza25
    from arizona
  7. mad mikey
    mad mikey
    FANTASTIC!!!:D
  8. loudbang
  9. loudbang
  10. loudbang
  11. loudbang
  12. loudbang
  13. loudbang
    1947knuck, Stebo27, j-jock and 6 others like this.
  14. choppedtudor
    choppedtudor
    chryslerfan55, els, loudbang and 2 others like this.
  15. mad mikey
    mad mikey
  16. mad mikey
    mad mikey
  17. loudbang
  18. loudbang
    from bangshift coverage of 2017 Syracuse Nationals
    1947knuck, Stebo27, els and 5 others like this.
  19. I am guessing the top one is a 348, but anyway, it reminds me of the time when my buddy left the light on the street, and the throttle stuck open. He was able to power shift it into second, but in the time it took him to reach for the key to turn it off, I thought he was going to blow it up. It was one of the scariest rides I have experienced while I wasn't driving.
  20. loudbang
  21. loudbang
    Can Am
    Y Block duces
    1947knuck, Stebo27, els and 6 others like this.
  22. enigma57
    enigma57
    I love tinkering with carbs.
    Built the induction system in my avatar back in '78. This was for the 400 Pontiac engine I built up and swapped into my '56 Chevy. '66 GTO iron tri-power intake modified to accept Holley carbs. High perf. replacement carbs sold over the counter by MOPAR dealers to replace OEM 440 6-Pack setup. Hand built air cleaner with '70 240Z Datsun filter element.
    Modified Offy intake for small block Chevy. Lots of welding to build up port rooves to match ported Victor Jr. heads and widen carb mounting flanges for either Weber or Holley carbs.
    Something I am working on. This intake is for the 292 inline 6 I will swap into my '57 Chevy.
    What I am doing here is modifying a sidedraught intake to accept Weber DCNF downdraught carbs. This is actually the outboard half of what will be a 2-piece intake. I have an identical unmodified sidedraught intake that will form the inboard half of this intake. These halves will bolt together using what was once the sidedraught DCOE carb mounting flanges.
    Reason for mods is that sidedraught carbs interfere with steering column and master cylinder in '57 engine compartment. But I 'just' have room to fit the modified 2-piece intake with downdraught carbs.
    After welding, my friend Nick shotpeened the intake to give it an 'as cast' look and make it harder to see that it has been welded. Then he did a skim cut on gasket mating surfaces to true them of warpage from heat of welding and bored down through throttle bores to open them up into port runners below carb mounting flanges.
    A bonus is that effective runner length is increased 50% . And I can rebuild and rejet some Weber 42 DCNF carbs I have here from an old Maserati and put 3 of them to good use......
    Best regards,
    Harry
    1947knuck, Stebo27, els and 10 others like this.
  23. mad mikey
    mad mikey
    Great stuff Harry! Thanks for sharing .:)
    els likes this.
  24. loudbang
    GOOD STUFF!!
    els and chryslerfan55 like this.
  25. wrenchbender
    wrenchbender
    Where can I find some history on these injectors this thing is way kool
    Chrome don't get ya home
    els, chryslerfan55 and loudbang like this.
  26. quick85
    quick85
    The Winged Express
    collector, 1947knuck, Stebo27 and 7 others like this.
  27. mad mikey
    mad mikey
  28. mad mikey
    mad mikey
  29. mad mikey
    mad mikey
  30. saltflats
    saltflats
    from Missouri
    Takin at the H.A.M.B Drags.
