Projects A/SR Model A Survivor Drag Coupster
Discussion in 'Traditional Hot Rods' started by RainierHooker, Mar 3, 2017.
  1. rob-redm
    rob-redm
    still no cam yet , wtf ! let me guess what excuse they give you on it. Their cam lobe puller is broken , lol .. I know you want to getting that engine running @Rainier******
  2. RainierHooker
    RainierHooker
    from Tacoma, WA
    No real progress, work, school, and the family have ben taking up most of my time lately. And I'm still waiting on that cam. I did manage to re-arange the garage yesterday. Now both my Model A projects are side by side and much more accessible...
    WC145, Stogy, kiwijeff and 5 others like this.
  3. rob-redm
    rob-redm
    I see a fuel block mounted on the fire wall.:D and correct brake fluid resv. caps... nice.... were is the truck hiding at ? @Rainier******
  4. RainierHooker
    RainierHooker
    from Tacoma, WA
    I swapped spots between the Phaeton and the Truck @rob-redm it's just out of frame to the left.
    The Fuel block is the original Segal one, cleaned up and re-mounted.
    I got my engine hoist back from the friend that was borrowing it, so once I get a spare hour or two, I'll be yanking the engine and ******. It'll get a fresh '39 box with '41 guts, the Albro flywheel, and a new clutch n' pressure plate. Then plumbing, while I wait for that damn camshaft...
  5. rob-redm
    rob-redm
    Have you heard from them regarding the hold up on the cam..I feel your frustration regarding it..
    Sent from my XT1585 using The H.A.M.B. mobile app
  6. RainierHooker
    RainierHooker
    from Tacoma, WA
    Well, the wait is over...
    This little bump-stick was waiting on my porch today. New cam billet ground by Schneider Racing Cams of San Diego.
    Potvin 400 "Climax" Advertized Duration: 284* Intake 284* Exhaust, Duration @ .050": 252* Intake 252* Exhaust, Lift: .400" Intake and Exhaust, Overlap: 52*, Lobe Separation: 113*
    Should be a wicked little cam. The guys at Schneider were adamant that this is NOT a street cam, and said that this was the first new one of this grind that they had done in at least 30 years. The delay was claimed to be from a damaged master that had to be re-done.
    Now there's no excuses but mine to get this little mill fired in anger...
    Jet96, Spoggie, Stogy and 5 others like this.
  7. RainierHooker
    RainierHooker
    from Tacoma, WA
    Engine's back out...
    Thrash is imminent.
    Stogy, loudbang, Runnin shine and 2 others like this.
  8. Nocero
    Nocero
    Awesome find and your the right person to have found it. Looking forward forward to watching this one.
  9. rob-redm
    rob-redm
    right on ! your back in business !
  10. RainierHooker
    RainierHooker
    from Tacoma, WA
    Getting closer. The bottom end has been blown apart, and re-***embled...
    And to replace the Coupster's original waterlogged '39 box, I pulled all the guts out of a '42 side-shift, and shoved them into a good '39 case...
    Now I just gotta get the valve train built and installed, put together the top of the motor, get the clutch and pressure plate installed (I'm waiting on new bolts), marry the engine and ******, and throw the whole mill back in between the frame rails. Then it's cam break-in time...
  11. RainierHooker
    RainierHooker
    from Tacoma, WA
    The cam is in...
    And I cleaned up the original Johnson lifters that came out of this block. They've never been run...
    turboroadster, Spoggie, Stogy and 2 others like this.
  12. RainierHooker
    RainierHooker
    from Tacoma, WA
    Chugging along. Making those valve seats shine...
  13. esrbuilders
    esrbuilders
    Awesome thanks for sharing!
  14. mista
    mista
    from Finland
    How is the hydraulic clutch leverage done in this? Does the gearbox have the rotative arm in it or a fork type arm? I'd like to see some pictures if it has rotative type arm..
  15. Wicked thread, thanks Rainier******
  16. RainierHooker
    RainierHooker
    from Tacoma, WA
    It's all apart right now, but I'll try to explain, until I can get pictures...
    It uses a 1932 lever-type clutch arm with a pushrod coming off of it and going strait back to the slave cylinder that is mounted on the transmission crossmember.
    This picture showing the different clutch arms is from Van Pelt Sales:
    Stogy and loudbang like this.
  17. RainierHooker
    RainierHooker
    from Tacoma, WA
    More progress on the engine. The Schiefer AlBro flywheel is in and safetied...
    ARP studs...
    Initial timing set at 24-degrees for the Harman Collins Mag...
    Copper Head Gaskets...
    And where I got before my camera ran out of battery...
    Bottom end is all together. Heads are on and torqued. Water pumps are back on and the Mag is mechanically timed. Just gotta throw the pan back on, mount the pressure plate, clutch, and ******. And make one good starter out of these two...
    ...then we should be ready to make some noise.
  18. rob-redm
    rob-redm
    keep the updates coming Evan !
  19. RainierHooker
    RainierHooker
    from Tacoma, WA
    I'm really hoping to make noise this weekend...
    loudbang, Poh and porkshop like this.
  20. Love it!
  21. rob-redm
    rob-redm
    no noise this weekend ?:(
  22. RainierHooker
    RainierHooker
    from Tacoma, WA
    My weekends are Sunday-Monday @rob-redm so there's still time...
  23. rob-redm
    rob-redm
    uh huh ! @Rainier******
  24. rodderbilly
    rodderbilly
    from italy
    Can't wait to hear how the climax performs.....people says is better than eliminator....
  25. cmarcus
    cmarcus
    "WE-WANT-NOISE! WE-WANT-NOISE"! (everyone now!!)
    young'n'poor and loudbang like this.
  26. RainierHooker
    RainierHooker
    from Tacoma, WA
    Okay guys, sorry for the hiatus. Things got a little crazy over the last few months, but I'm happy to report that progress was and continues to be made on the coupester. And yes, noise has been made. Here's a catch-up post...
    After my last post, I needed a few small bits in order to ****on up the transmission build. I ended up buying a package-deal of Early Ford transmissions and transmission parts...
    ...with all the parts, I ****oned up the ******, bolted it to the motor and dropped it back in-between the frame rails
    Stogy, turboroadster and Runnin shine like this.
  27. RainierHooker
    RainierHooker
    from Tacoma, WA
    ...and I spent the next few days' lunch-breaks in my work's sheetmetal shop turning an off-cut chunk of aluminum into a dash. The dimensions, layout, and shape are all the same as the original dry-rotted and rat-stained plywood panel, but spruced up just a smidge...
    slv63, Nailhead A-V8, Stogy and 2 others like this.
  28. RainierHooker
    RainierHooker
    from Tacoma, WA
    With the motor and transmission back in the car, we are definitely in the finishing touches mode. I took out my roll of NOS Packard 440 cable and Delco ignition components kit and made up some new old plug wires...
    Then I started bolting the engine back to gather and getting a final mock up of the hoses and other plumbing...
    Topped off the battery with electrons...
    ...and fired her up (movie forthcoming)
  29. RainierHooker
    RainierHooker
    from Tacoma, WA
    With the promised noise having been made, I set about finishing up plumbing the brakes and clutch...
    And finished off the seat...
  30. RainierHooker
    RainierHooker
    from Tacoma, WA
    So, thats got us pretty much caught up. Things left to do before her first trip around the block, in somewhat of an order:
    -Replace Rear Wheel Cylinders
    -Bleed Brakes and Clutch
    -Wire in Dash
    -Wire in Electric Fuel Pump
    -Re-Mount Radiator
    -Finish and Mount New Tonneau Cover
    -Replace Wishbone Rod-Ends
    -Camshaft Break-In Run
    -Big Smokey Burn-Out
    Once those things are completed, I will start thinking about finishing up the interior (door-panels etc.) and adding headlights, taillights, and fenders. I have a feeling that my winter plans are pretty much summed up there.
    Stogy and slv63 like this.
