Technical ***September 2017 Banger Meet - A Change of Seasons***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 31, 2017.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. Bluto
    Bluto
    OK...... Time to finish last Winter's projects ..... or not........ this Winter
  3. noboD
    noboD
    Hershey is right around the corner, in more ways then one.
  4. checked in.............or out, either way I am covered.
    J
    Dannerr likes this.
  5. winduptoy
    winduptoy
  6. waxhead
    waxhead
    from West Oz
  7. GASSERBOB
    GASSERBOB
    from USA
  8. ROCKER77
    ROCKER77
    G***erBob the rpu is still looking good. How's it running?
  9. GASSERBOB
    GASSERBOB
    from USA
    Thanks Rocker. Its running real good. I'm still breaking it in. I only have about 100 miles on it yet. Hope to get some paint on it some time. No hurry I guess. Been bare metal for about 5 years now. How's your banger truck doing? Do anything new to it ? Good to talk to you again Rocker. Take care. Bob................
    Russ B likes this.
  10. ROCKER77
    ROCKER77
    Been working on my other ch***is, just finished the juice brakes so tomorrow gonna start swapping everything over. We are planning our own little reliability run out to El Mirage on the 10th so 8 should have it all dfialed in by then
  11. GASSERBOB
    GASSERBOB
    from USA
    That's cool Rocker. Hope you will post some pictures. Have a good time. Bob...............
  12. stillrunners
    stillrunners
    from dallas
    actually moved some early parts out of my O/T car I was storing them in....1 nice piston with a rod with new babbit poured at one time....some valves and small stuff....not sure where I got the stuff....selling the O/T car hopefully..... IMG_20170809_191310.jpg
  13. RussTee
    RussTee
  14. Checking in, before take off to DSRA Nats: [​IMG]
    The Ole-Henry has been running real rich lately, which is why, rear wheel is so blackened. Dunno if it the electric fuel pump or eco-friendly gasoline, but something seems to have ruined the Weber carb- used to run twice it's current gas milage... another project for the winter, I guess!
    At least, he's running! [emoji16]
  15. denis4x4
    denis4x4
    from Colorado
    Redoing the MC on the truck with a dual cylinder.
  16. By the grace of God, Coors lite and a nightly shot of Christian Brothers I'm here
    Jet96 likes this.
  17. If I get on my roof I can see El Mirage bout 10 miles as the Crow flies and if there's dust
  18. brjnelson
    brjnelson
    Boxing myself in, with Peroid Correctness, I agonized over keeping the car pre-war parts only.
    I have chosen to go with modern tube shocks. After having the stock model a shocks and friction shocks over the years I cannot believe how good it rides now.
    I used some 1949 ford rear Houdille tube shocks, now I can say my A is all pre 1950 parts.
    Jet96, burl, chryslerfan55 and 5 others like this.
  19. winduptoy
    winduptoy
    uhoh, looks like you have floaters, maybe not all... but you are right, you can still say it
    in my car the driver isn't pre 50's just barely
    besides safety upgrades don't count in my mind you get a p***
  20. V4F
    V4F
    from middle ca.
    is the rust pre '50 ?
  21. brjnelson
    brjnelson
    :D I do not know the brackets history, :p found em in a pile at Little Dearborn
    windup, I too give a p*** to safety, and to filters and parts that can not be seen from the outside of car ;)
  22. A grumpy old man made it into my paddock area at Monterey! He brought his old helmet and goggles with him! (photos by Bringatrailer.com) RMMR2017.jpg RMMR2017-2.jpg
  23. jim1932
    jim1932
    Here's hoping September gets the car back on the road.....
    Dannerr likes this.
  24. peter schmidt
    peter schmidt
    from maryland
    New to bangers but got started working on mine fineally. Got all the studs out and pulled the head to find 100 over pistons. It showed great compression before but its getting a good cleaning all new gaskets and paint plus a police head downdraft zepher intake 97 carb a dizzy from bubbas and finned aluminum valve cover. I also have a t5 and adapter that may find its way in eventually. 20170902_200503.jpg 20170902_200417.jpg 20170902_200404.jpg
  25. The37Kid
    The37Kid
    LOOK WHAT I FOUND!!!!!!!!!!!!! Never knew these existed. Bob DSCF0699.JPG DSCF0700.JPG DSCF0701.JPG
  26. Binger
    Binger
    from wyoming
    Checking in too. Busy Saturday moving into our new house. Boxes galore. Going to be loving the garage space. [​IMG][​IMG]
    Jet96, chryslerfan55, woodz and 3 others like this.
  27. ROCKER77
    ROCKER77
    Binger that looks like a mighty fine garage
  28. Bluto
    Bluto
    I started buying helmets 40 years ago. They all have wonderful stories. Many I have used over the years.
    Bill..... There are times when I am "Alki fueled" too. A gl*** of dry red wine lowers my blood pressure.
    I'm still not getting thread UPDATES so sorry for the late comment timing.
    Crazydaddyo, Jet96, burl and 4 others like this.
  29. Jiminy
    Jiminy
    PM sent.
  30. Binger
    Binger
    from wyoming
    I am excited about the new space. It is a wide 3 cars and about 2 1/2 cars deep. I will fill it up quick I imagine. The best part is that is 7 houses down the block to my other work shop. It will be nice to make extra working space and get a couple of things out of the weather.
    chryslerfan55, Dannerr and ROCKER77 like this.
