Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. tfeverfred
    tfeverfred
    Progress is progress, man. Nice work.
  2. Black Clover Custom
    Black Clover Custom
    Looks good man. But dont forget that on the front of the piece you just welded there is a cup built into it (welded onto it) that takes the ball end of the front bones. Two bolts hold it together. I will post a pic of it later tonight for ya. Otherwise your ball end with rubber cup wont have anything to slot into.
  3. topher5150
    topher5150
    Thanks but I'm splitting the wish bone
  4. Black Clover Custom
    Black Clover Custom
    Nice. What motor and trans will you be using?
  5. topher5150
    topher5150
    I'm going with a SBF, and an AOD, or C-4
    1Nimrod and Black Clover Custom like this.
  6. dirt t
    dirt t
    If you were in Kingman, AZ or near I'd have given you the frame free.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  7. topher5150
    topher5150
    If I was in Arizona I'd be buying all of those cars that everyone out west considers "rusty"
    1Nimrod, brEad and jimgoetz like this.
  8. topher5150
    topher5150
    I'd say the rivets are the strongest thing on this car
    1Nimrod and treb11 like this.
  9. topher5150
    topher5150
    Jimmy, slv63 and Crusty Chevy like this.
  10. RMONTY
    RMONTY
    Quit eating Beijing Beef and Chow mein and get to building!! :cool:
  11. topher5150
    topher5150
    I don't expect to get to much done this winter. Probably just going to start buying some parts for when it gets nice out again
    Sent from my XT1254 using The H.A.M.B. mobile app
    1Nimrod likes this.
  12. phat rat
    phat rat
    Winter is when you're supposed to work on it. That's why we have it. LOL
    1Nimrod, Tim and Thor1 like this.
  13. topher5150
    topher5150
    1Nimrod likes this.
  14. phat rat
    phat rat
    Years ago a friend of mine used tarps over a wooden frame for a place to build his car over the winter. I thought it was a bit crude but it worked for him. He built a decent little A roadster
    1Nimrod and Kustomline54 like this.
  15. lakeroadster
    lakeroadster
    from *
    Just checked out your project... truly a back yard hot rod build. Destined to be a neat ride.
    1Nimrod and topher5150 like this.
  16. topher5150
    topher5150
    I need a quick measurment. So according to these drawings the Merc frame, which i have, is 4" longer than the Ford frame. The plan is to move the plan is to move the cross member back..... Can anyone get me the measurement, from a Ford frame, of the distance from the transmission mount, our some other point of reference, to the front cross member?!??
    1Nimrod likes this.
  17. topher5150
    topher5150
    Just got my C.E. motor mount kit, didn't realize how thick those plates are. Can anyone help me with my previous post?
    1Nimrod likes this.
  18. razoo lew
    razoo lew
    from Calgary
    I cant help with the measurement but have been wondering the same thing about my 118” wheelbase 46. Seems to me that to reduce the wheelbase by 4 inches would require the front crossmember to move back 4 inches. I have yet to find a dimensioned drawing of each frame to confirm this though, the extra length in the Merc frames looks to me to be between the steering box and front crossmember.
  19. topher5150
    topher5150
    I was think that to. I guess I wanted to have a difinitive awnser
    1Nimrod likes this.
  20. razoo lew
    razoo lew
    from Calgary
    You have at it and I’ll monitor your results! Or with luck, someone will have a measurement.:)
    1Nimrod likes this.
  21. topher5150
    topher5150
    Laid everything out with the speedway cross member back a set of holes and it looks like it all works out. I'll have to do the same with the steering box plate.
    1Nimrod likes this.
  22. razoo lew
    razoo lew
    from Calgary
    Is the steering box in a different place from the 114 to the 118 inch ch***is? I figured it was the same to keep the relationship with the body/ dash etc and used a different drag link. And again, I really dont know.
  23. topher5150
    topher5150
    Someone PMd me some pics awhile ago about and it looks like the steering plates are the same just in a different position
    1Nimrod likes this.
  24. sawzall
    sawzall
    the rails themselves are IDENTICAL from ford to MERC..
    IF your still in need of dimensions.. I have one of each frame now in my possession.
  25. razoo lew
    razoo lew
    from Calgary
    The drawings that I look at appear to have extra length for the 118 in wb compared to the 114 inch. But they are drawings, not a photograph. I can’t see the 118 inch Merc rails being the same as 114 inch Ford, but I do not have one of each to measure. (there is a 114 inch Merc as well, I am sure that this is the same as the 114 inch Ford are we all talking about the same thing?)
    1Nimrod likes this.
  26. sawzall
    sawzall
    if I recall correctly.. the Ford parts book shows the same part number for rails for both mercury and ford. honestly it wasnt until I had a pair side by side that I realized how ford (merc) did everyting..
    the merc has a "unique" bracket that moves the wishbone pivot forward, the steering bracket is in a different position (if I recall correctly) and the mercs have their own (longer) steering column..
    the front crossmember is FORWARD of its usual location in a ford (with equally unique motor mounts that are somewhat "cantilevered" off the front crossmember in the merc frame. . it really doesn't make sense.. but from what I can see those are the notable changes..
    1Nimrod likes this.
  27. razoo lew
    razoo lew
    from Calgary
    Ok @sawzall that makes sense. My 118 in WB frame has the cantilevered motor mounts exactly as you describe. I ***umed that the steering box location was the same for 114 and 118 inch frames but the longer steering column would work too. Good information, thanks.
    1Nimrod likes this.
  28. topher5150
    topher5150
    just thinking out loud here....I was talking to some people about my front suspension, and some one suggested that I can get a decent drop with a lowered reversed eye spring. I was thinking, at least for the time being just run the stock axle/spindles with a lowered spring and dropped crossmember. I was also wondering has anyone used the CE wishbone kit that keeps the wishbone intact on a lowered suspension?
    1Nimrod likes this.
  29. phat rat
    phat rat
    Are you aware that CE has closed and gone out of business?
    1Nimrod likes this.
  30. topher5150
    topher5150
    I know...there's still CE stuff floating around on ebay and such
    1Nimrod likes this.
