Projects Not Your Average Coupe Build: ‘37 Chevy Unearthed
Discussion in 'Traditional Customs' started by oneratfink57, Jan 31, 2017.
  1. oneratfink57
    oneratfink57
    from Wisconsin
    Worked on the trunk tail pan a little today. In hindsight I could of probably mad this out of one piece, instead of three, but this way I kind of follows suit with how the rest of the transitions were made
    Started out with cardboard templates and rough cut the patterns out of steel
    Bead rolled a lip so this panel will be flush with the rest of the trunk pan
    Traced my design onto the panel and beadrolled it
    Finally made a seam cover similar to what I did on the trans tunnel, and cleco pinned in place
  2. oneratfink57
    oneratfink57
    from Wisconsin
    I left early today to go help a couple buddies with a cracked motor mount on an old tracker fishing boat boat. So when I got back a few hours later I figured I was done for the day, but the garage was such a mess I figured I'd make it a little dirtier before I cleaned up!
    Welded my rear tail pain up.
    Now the tail pan trunk corners are all I've got left before I can seam seal and prime the floor
  3. oneratfink57
    oneratfink57
    from Wisconsin
    The floor is now ready for primer!
    Finally got the last portions of the trunk floor made up.
    For access to the body mount bolts, I use a 1" hole saw to punch some holes in the new panels I made
    To make the dimples, I wish I had a dimple die set; however I made due with the stuff below
    I plan to make removeable plugs for the body mount access ( thus the reset dimples) I just don't know what I'm going to use yet. The washer works pretty darn good though!
  4. JB36LaSalle
    JB36LaSalle
    Just started looking at your thread and all I can say is WOW. You're doing a great job. Makes me feel like a slacker. Keep up the good work!
    gsnort and oneratfink57 like this.
  5. oneratfink57
    oneratfink57
    from Wisconsin
    Primed the floor and transmission crossmember today. Mixed a little extra epoxy primer so I laid it on the driver side of the coupe for the heck of it, even though I'll blast it off later
  6. 1blown57
    1blown57
    from Florida
    Great Job ! Makes me happy I saved the old girl ! [emoji847] But your hard work and talent is preserving this Chevy for future generations !
  7. Doctorterry
    Doctorterry
    I love these cars
  8. oneratfink57
    oneratfink57
    from Wisconsin
    For those who may have noticed, I took a break from my 37 build updates. I haven’t lost interest! It’s just I have his perfectly good 57 Chevy sitting 15 ft to the right of the 37. I’ve been spending some time getting that back to roadworthy condition.
    I put a factory gas tank back in it and am redoing some things I did when I was a kid. I’ll be rewiring the car (and using the old harness for the 37) and replacing the rear shock cross member. It has one because I relocated the leaf springs way back when
    I’ll probably throw a couple 57 pictures up on here when I feel like it.
    I suspect I’ll start working on the 37 again (likely making rockers) sometime after Christmas.
  9. rusty1
    rusty1
    ...glad to see you're back, don't matter what yer workin on...
  10. ratrod40428
    ratrod40428
    I just read your entire thread... not gonna lie, when I saw the first couple pictures of the car I thought you had lost your mind haha. Most people would have seen that car, said "what a shame" and walked away. Your drive and skills are inspiring to say the least. Great work! Ill be doing a slight channel and floor pans in my 55 Ford wagon next summer, I'll be revisiting your thread for inspiration and ideas.
  11. oneratfink57
    oneratfink57
    from Wisconsin
    Well gents, after a long break to get my 57 back on the road, I’m back to the 37.
    The doors were the last part of the car that was questionable if they’re worth being saved. And I decided not to, which says a lot if you are familiar with the build.
    That being said, I’ll be salvaging the inner skins and part of the window structure as you’ll see later.
    I had been looking for a set of doors for a few years that were worth saving, but not so nice that it would be a shame cutting them apart, and fellow H.A.M.B. member kbcookout had the perfect set.
    I bought a set of sedan doors off cookout a few weeks ago after going back and forth through pictures of his inventory. The inner skins had been cut out and they were a little rough around the edges, but they fit the bill perfect. (Thanks again!)
    Today was the day I mustered the courage to cut apart a perfectly good set of doors! So I started slicing and dicing.
    For those who don’t know, sedan doors are 4” longer than coupe doors, and the b pillar is a different geometry. This means they had to be shortened, as well as chopped since the roof is chopped.
    I separated my coupe door skins and hung the outer skin on the sedan door to give me a good line to trace, I added 1/2” to the length to give me room to fold the end of the door for a flange for the inner skin.
    Next, I planned how I wanted to bring the b pillar forward, and I made sure to cut between the body lines so I could metal finish later.
    Cut 4” out of the lower portion of the inner skin that was still in the door
    Next I cut some pieces off my coupe door, remembering to keep enough of the sedan window structure so I could lengthen it to accommodate for the chop
    Ive just got them tacked for now until I finish adjusting the door. (You can see the body line at the rear of the door doesn’t matchup) And I couldn’t help but mock up the fenders for a photo op.
  12. King ford
    King ford
    from 08302
    Greetings Oneratfink!....great worksmanship and perseverance!...I see one of those air chisel planishing hammers in your last photo, how do you like that tool?
    kidcampbell71 and oneratfink57 like this.
  13. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks King ford! It serves its purpose. It doesn’t stand up any where near to the quality of a more expensive unit. I think the big difference is the quality of the dies and cycles per minute of the air hammer. I’d pay $100 again for it, knowing the time it’s saved me
    kidcampbell71 and Bowtie Coupe like this.
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Thanx for the update. I've been looking for a set of coupe doors to scavenge the 'B' pillars from to do something similar. I want to put the slanted posts from a coupe on my sedan. Your pictures and explanation show the process exactly as I had envisioned it.
    I tried to buy a whole coupe body from the auction site but the seller wouldn't answer my request to have someone come and look at it.
    I'll find some eventually, probably right after I sell the sedan. :p
  15. oneratfink57
    oneratfink57
    from Wisconsin
    That’s usually how it works! Lol
  16. harley jim
    harley jim
    I just read all 17 pages of this build in one sitting. Great floor work that's the way to save a car. I'm subscribed cant wait for the next installment.
    Sent from my smart*** phone using The H.A.M.B. mobile app
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    How much chop would you say that is?
    oneratfink57 likes this.
  18. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks Harley!
  19. oneratfink57
    oneratfink57
    from Wisconsin
    It’s about 2 1/2”
    Bowtie Coupe likes this.
  20. jimmy bruns
    jimmy bruns
    from Chatsworth
    *****in work! Heres a few shots of our 37' we built a few years back... 562281_10151161183528362_968203127_n.jpg 468732_10151200271663362_2013099907_o.jpg
  21. oneratfink57
    oneratfink57
    from Wisconsin
    Wow very cool! One of these days I hope to get there, thanks for sharing!
  22. Jacksmith
    Jacksmith
    from Aridzona
  23. Lines
    Lines
    from Germany
    Great job. done a lot of work. Nothing easy to do what you have done.
    Keep on. In the end a picture of how it started and the end result will give the biggest sucsess.
    oneratfink57 and 54delray like this.
  24. rusty1
    rusty1
    ...you do very nice work and should be proud that you "saved" that coupe,..quite an accomplishment....can't wait to see it further along. ...love those 37-8 Chev coupes.
  25. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks rusty1, it means a lot. One piece at a time!
  26. oneratfink57
    oneratfink57
    from Wisconsin
    I did a horrible job do***enting progress today, but I was excited to get into the garage after a brutal Wisconsin winter.
    I started to adjust the drivers door I chopped and shortened earlier this winter. First picture was no shim. Second was the shin. Third is post shim. I could only shim the upper hinge to bring the door up in the rear. I’m trying to brainstorm how to move the bottom hinge toward the back of the car to finish the job.
    Before I started slicing and dicing to finish drivers door adjustment, I moved onto the p***enger side.
    Removed the inner skin of the roached p***enger door
    Used the outer skin as a layout template and started cutting apart the p***enger sedan door to convert it to a coupe door
  27. rusty1
    rusty1
    ...while you're at it, why not correct the hood side louvers so they are as they should have been made...?...like this...
  28. oneratfink57
    oneratfink57
    from Wisconsin
    One of these days! Lol
  29. Wow! That's going to be a great save
    On the hinges
    We see those as bend to fit hinges.
    Body mount shims have a lot to do with it too
  30. oneratfink57
    oneratfink57
    from Wisconsin
    I’m glad to hear that! I think that’s the direction I’ll have to go. I contemplated cutting out the hinge mount on the door and moving it to where I need it to be
