TECH: Easy Disc Brake Covers
Discussion in 'The Hokey Ass Message Board' started by D-Russ, May 24, 2007.
  1. Mayor of G-Vegas
    Mayor of G-Vegas
    Awesome thread ... Im with the others you should make a kit!
    D-Russ likes this.
  2. Mattilac
    Mattilac
    Excellent post Russ. I like how you laid out the illustrations and got right to the point.
    D-Russ likes this.
  3. Steves32
    Steves32
    from So Cal
    I'm glad to see this thread brought back up. It's one of my favorites.
    I took the more lazy & expensive route by calling 1-800 So-Cal buick drums w/ Willwood discs. ;)
    Your drawings are fantastic.
    D-Russ likes this.
  4. Jack Luther
    Jack Luther
    I like this idea, and this thread hasn't been up in a while, so bttt.
    D-Russ likes this.
  5. tfeverfred
    tfeverfred
    Still one of the best techs ever done.
    D-Russ likes this.
  6. 55willys
    55willys
    Great idea! I am looking in to making a wide 5 disc brake hub
    D-Russ likes this.
  7. Sky Pilot
    Sky Pilot
    great visuals ,**xcellent idea ! keep it going
    D-Russ likes this.
  8. cody1958
    cody1958
    from wichita ks
    first time seeing this thread. I really like the way you hid the brakes. Great job!!!
    D-Russ likes this.
  9. 32ford5
    32ford5
    from Australia
    Great tech - looks superb. Deserves a bump; it's been a while.
    D-Russ likes this.
  10. D-Russ
    D-Russ
    Sorry for the down time. All linked images in this thread originally hosted by Photo****It have been relinked to the HAMB servers.
  11. chevy57dude
    chevy57dude
    D-Russ -thanks for taking the time. Dead horse, I know but photosux is shooting themselves in the foot by F ing the people.
    Great thread and super idea, BTW!
    D-Russ likes this.
  12. 2deuces64
    2deuces64
    I follow directions real well backing plates.jpg backing plates2.jpg backing plates3.jpg backing plates4.jpg
  13. D-Russ
    D-Russ
    Wow, those look awesome! You must have one heavy duty louver press!
  14. 2deuces64
    2deuces64
    The louvers came from a hood off of a farm implement, I welded them in. I picked the finned drum covers up at a swap meet for cheap money. I made another set using a brake drums from a 36 ford, I'll see if I can't get a picture .
    Tim, Fordor Ron, D-Russ and 1 other person like this.
  15. in the weeds
    in the weeds
    from Kansas
    I thought I would give it a shot with a pair of junk Buick drums I had. It took some time to lathe out the old cast liner but I got it done. something different and cool!!. faux buick cover.jpg faux brake cover 2.jpg faux brake cover 1.jpg faux brake cover 1.jpg faux brake cover 1.jpg
    39custom, Tim, Tim_with_a_T and 24 others like this.
  16. cfmvw
    cfmvw
    As always, I am impressed with the creativity and craftsmanship I see on the HAMB!
    Bugguts, Fordor Ron and D-Russ like this.
  17. Elcohaulic
    Elcohaulic
    That really makes the front suspension look smooth and like was said its not trying to hide, cheat or fake it clearly shows the car has discs but better looking ones..
    Nice job..
    D-Russ and High test 63 like this.
  18. 2deuces64
    2deuces64
    The drums don't turn they are attached to the backing plates with tabs and 4 bolts.
    D-Russ likes this.
  19. Koz
    Koz
    Checking "out in the weeds" variation on the theme. Now I'm interested......... OP and the Buick looking ones are just the nuts! I'm having serious doubt as to my ability to stop my Vick with early Ford brakes. This may be the solution.
    Thanks guys for the excellent muse!
    D-Russ likes this.
  20. Blues4U
    Blues4U
    from So Cal
    I would be concerned with this mod blocking the air flow from vented discs, leading to over heated brakes.
    nunattax, lostone and Ned Ludd like this.
  21. 2deuces64
    2deuces64
    I bet those louvers would take care of your concerns.:)
    D-Russ likes this.
  22. Blues4U
    Blues4U
    from So Cal
    They might help some, but heat rises, those vents are in the lower half, I think they're better for looks than for cooling. Ventilated discs expel heat from the center out, the cover blocks that heat from flowing freely. It's probably not a problem for the vast majority of us, unless you do a lot of mountain driving. But losing brakes due to heat is an experience I'd rather not ever have again.
    lostone likes this.
  23. Bugguts
    Bugguts
    [QUOTE="I thought I would give it a shot with a pair of junk Buick drums I had. It took some time to lathe out the old cast liner but I got it done. something different and cool!!.
    Cool idea on the Buick drums! Can we get a picture of your set up with the wheel removed. I'm not sure I understand the process and would like to know more. Thanks.
  24. 2deuces64
    2deuces64
    Ty isn't on here very often . If you look at post #72 this will give you an Idea what he did, only he used Buick drums and machined out the centers and the steel inserts for the brakes. This helped reduce the weight.
    Bugguts and D-Russ like this.
  25. rusty rocket
    rusty rocket
    I did a tech post years ago when I built some for my sedan. I think the thread was called fake brakes.
  26. pprather
    pprather
  27. 32 hudson
    32 hudson
    Question are the front and rear backing plates the same concerning bolt circle hole locations large hole diameter ? Or front specific backing plates needed to do this modification ?
  28. D-Russ
    D-Russ
    I'm 99% sure the only difference in front and back juice backing plates is the provision on the rears for a parking brake cable.
    GordonC likes this.
  29. HOTRODPRIMER
    HOTRODPRIMER
    Man, this looks great! HRP
    GordonC and olscrounger like this.
