Hot Rods Black painted engines
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Aug 22, 2017.
  1. Dasheot
    Dasheot
    from Georgia
    My advice go black , I got 1 of each polished and black. My wife's car is the 32 with the polished motor. There are stupid hours put in to keep it looking good , my car the Pontiac is a 10 minute deal to clean the motor.
    robracer1 and tfeverfred like this.
  2. Allinger
    Allinger
    Donut Dave,
    I am interested in the origin of the black air cleaner you have on the SBC. I made one of very similar appearance to cover an LS motor. I would like to be able to purchase such an air cleaner and modify it to fit... Would you share where it came from?
    Thanks!
    moses allinger@comporium.net
  3. Ron Brown
    Ron Brown
    waiting to install in my avatar after I retire at end of year IMG_1345.JPG IMG_1345.JPG IMG_1478.JPG
    juan motime and kadillackid like this.
  4. Donut Dave
    Donut Dave
    I made the air cleaner in my shop, wanted to cover the carburetor as much as possible. I'm just a "Backyard Barney" builder, not interested in doing work for others!
  5. Allinger
    Allinger
    I understand completely!:) What did you start with and what it is made with? Where did you get the chrome/stainless screen? I am looking at making another one, and if I could find a starter piece, it would be less labor for me...
    I started with a plywood buck and 23 gauge sheet metal to keep it light and easy to form. IMG_0681.JPG IMG_0865.JPG . Cut holes for air filter, Spot welded it all together. IMG_0879.JPG
    Now have to body work and decide on paint. Thanks for the reply and any info you are willing to share.
  6. Koz
    Koz
    078.JPG An "Amen" on the Eastwood Ceramic. it is damn near bulletproof and takes fuel contact very well. Only one I know that endures brake fluid.
    A few I built for clients.........
      362.1 KB
      165.2 KB
    barrnone50 and tfeverfred like this.
  7. willumbilt
    willumbilt
    [​IMG] Ford 223
    Sent from my XT1585 using The H.A.M.B. mobile app
    barrnone50 and mike bowling like this.
  8. Donut Dave
    Donut Dave
  9. Gary Addcox
    Gary Addcox
    I don't remember seeing a firewall done like yours. Very unique and bad***. Super clean ride.
  10. tfeverfred
    tfeverfred
    Nice ride. Who builds those headers? I keep seeing them pop up, from time to time.
  11. Koz
    Koz
    I ***ume you mean the ones on the Coupester. That set I built using mostly Patriot components. Most people I think just use the Speedway ones. The turnouts are just segments of 3 1/2" mandrel U cut to fit. I have blockoff plates inside the U with silicone gaskets to close off the open headers when wanted. I don't care for the appearance of the 4 bolt plates to block the headers. They pull off with a wing nut. I don't get too carried away with perfection on these as PA. require them to be wrapped anyway.
    This was an early build pic on this car with a 4V carb to break in the engine. It was replaced with a set of 'trips after the engine was setup. Very nice driver with a ton of legroom and great profile.
  12. willys36
    willys36
    Can you tell?!?
    lothiandon1940 and chevy57dude like this.
  13. Koz
    Koz
    Saw the original Mysterion when I was maybe 12 years old. Completely ended any hope I had for a normal life...... I've had the hot rod affliction ever since.
  14. mike bowling
    mike bowling
    not without a welding helmet!!
  15. willys36
    willys36
    Right? He fried a lot of our brains with that machine.
  16. chop job
    chop job
    from Wisconsin
    Once you go black you never go back.
  17. blue 49
    blue 49
    from Iowa
  18. Fortunateson
    Fortunateson
    Black paint for heat dissipation? I can see it for increased heat absorption but to dissipate? I would think thin paint would do that job. I can’t understand how the inside of an engine block will know what colour it is on the outside. Please explain this concept works.
    Early Ironman likes this.
  19. George
    George
    That. apparently, was the results of NASCAR studies. Probably why radiators are painted black since day one instead of white.
  20. hrm2k
    hrm2k
    my old T coupe
    Early Ironman and lothiandon1940 like this.
  21. 32Dan
    32Dan
    from Chino, CA
  22. Spooner Clinton
    Spooner Clinton
    Nothin' looks better than a black engine. Trying to locate the origin of an oil leak really ****s on a black engine.
    Early Ironman and hrm2k like this.
  23. brett4christ
    brett4christ
  24. jjjmm56
    jjjmm56
    from FL.
    Here's what I finally came up with[​IMG][​IMG][​IMG]
  25. Looks good. I like the contrast.
  26. Slopok
    Slopok
    Better get rid of that Fram oil filter!:eek:
  27. That reminds me of a tip, if you want to find a difficult to isolate oil leak, clean the area, run the engine and light the area with a UV light. This will find the leak.
    Bob
  28. k9racer
    k9racer
    Many years ago the late Henry '' Smokey"" Yunick said to a paint the engine black .He said for better heat transfer So I have painted almost every engine I have worked on black for almost 50 years. He also said paint fire walls on race cars flat black .....
  29. car doctor
    car doctor
  30. turdmagnet
    turdmagnet
    I was waiting to see how quick someone would jump on that Fram filer !!!!!
