Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. enloe
    enloe
    from east , tn.
    I've been to Garlit's museum a few times and it is definitely worth a long look:)
    els and loudbang like this.
  2. I ran a weiand 8-71 for several years both blown and unblown. It was one of only 25 made in 1959. It mounted eight stromberg 97s. We had some very trick custom parts in the carbs 20130717_102449.jpg 20130616_202149-2.jpg that made it work great.
    1947knuck, Stebo27, j-jock and 6 others like this.
  3. Jet96
    Jet96
    from WY
    IMG_6603.jpg Loudbang- It looks like a MEL
  4. Jet96
    Jet96
    from WY
    1947knuck, Stebo27, j-jock and 3 others like this.
  5. enigma57
    enigma57
    :) Roger that! In the late '50s to around 1960 or so, running a pair of large (for the time) 2bbl carbs on straight (non-progressive) throttle linkage was the thing with transporters. Gave very good results and excellent throttle response at speeds over 85 - 90 MPH when hauling a heavy load of 'shine up in the hill country.
    :rolleyes: Don't ask me how I know that,
    Harry
  6. quick85
    quick85
  7. loudbang
  8. els
    els
    I am so jealous right now. Garlits museum is on my bucket list. Thax enloe and loudbang.
    mad mikey and enloe like this.
  9. enloe
    enloe
    from east , tn.
    Budget a whole day for both of the museums.
    mad mikey likes this.
  10. loudbang
    One SBC with many injector stacks or two SBCs???
  11. Speedwrench
    Speedwrench
    Camera angle ?
    BHR301, loudbang, els and 1 other person like this.
  12. mad mikey
    mad mikey
    I spent 3 days there, could have stayed in there for a week to look. LOL. Its FANTASTIC!!:D:D
    loudbang and els like this.
  13. Dean Lowe
    Dean Lowe
    Yes, its the camera angle. A C/Dragster would only have one engine.
  14. els
    els
    Cool mad mikey, My avatar is the old BEELINE DRAGWAY sign from Scottsdale Az. I had talked with Garlits museum to give them the sign. Don was pretty interested in the sign in the museum. I told him I would be proud to donate the sign to his museum. I plan on going there soon. I m excited you got to go. Like I said before, BUCKET LIST. I'm sure I will have a great time. I may spend the week there.
    mad mikey, Speedwrench and loudbang like this.
  15. jnaki
    jnaki
    June 24, 2017 Lions Dragstrip Museum second cacklefest
    Hello,
    The Burkholder Bros. go way back to 1959 in their racing history. The cars they had were varied, but the mainstays were the altereds. If you have ever been to one of the Cacklefests or Hot Rod Reunion events, this car always puts on a great show. This photo shot at the June 2017 Lions Dragstrip event was part of the huge Cacklefest going on outside in the parking lot, later on in the early evening. The other photos are from 2011 to the present.
    thanks to Greg Reagan for the You Tube movie clip. It was from the first cackle show early in the day at the Lions Dragstrip Museum event in June. . I was able to take photos of the second, "giant cackle" later in the early evening. It is/was an impressive race car…
    Jnaki
    Going to the Barona Dragstrip Nitro Revival on September 30? Check them out…
    upload_2017-9-10_8-4-12.png 0ct 1961
  16. Dean Lowe
    Dean Lowe
    The Burkholders always ran that pipe organ injector stack deal on their Hilborns. I could never understand what the attraction was. Does not look as effective as a scoop.
  17. mad mikey
    mad mikey
    Looks good and different from others. One of my favorites , the car is outstanding!:)
    els likes this.
  18. 340HilbornDuster
    340HilbornDuster
    Looks WAY COOL!
    Cut Line works perfect with the car!
    Incredible Car!
  19. loudbang
  20. loudbang
  21. loudbang
    As every fan of cl***ic American oval racing knows, Offenhauser never, ever built a six-cylinder engine. Well, here it is. The unique piece was commissioned by Chicago-area racer Joe Lencki. Originally laid out as a two-valver in 1938, the six was updated the following year with a four-valve head. In most details the engine was essentially a 270 Offy, but with two more players an Offy in all but name.
    In theory the Lencki should have been superior to a standard Offy four due to its greater valve area and lower piston speeds, but for whatever reasons, things never worked out.In the engine’s first Indy 500 start in 1939, installed in Lencki’s own ch***is (above), the fuel pump failed with 12 laps to go, kicking off a multi-year run of bad luck. Between ’39 and ’47 the car qualified for the 500 a total of five times, but it’s unclear how many of these starts featured the six-banger, since a standard Offy four was often subs***uted.
    Mickey Thompson Contrary Engine
    There was also a naturally aspirated version of M/T’s contrary V8 using a pair of Carter AFB four-barrel carburetors. Since the conventional V8’s cylinder firing sequence would create some carburetion problems with this arrangement, it’s possible that a 180-degree crankshaft, aka flat crank, was used. This would transform the Pontiac V8 into two separate-but-equal inline four-cylinder engines on a common crankshaft.
  22. loudbang
  23. loudbang
    Slant 6 tower of power
    1947knuck, Stebo27, j-jock and 5 others like this.
  24. loudbang
  25. loudbang
  26. loudbang
  27. loudbang
  28. loudbang
  29. Jet96
    Jet96
    from WY
    IMG_6499.jpg I can't remember if I posted this before
  30. seb fontana
    seb fontana
    from ct
    I wonder how it ran..History some wheres?
    els, loudbang and mad mikey like this.
