Hot Rods GM chevrolet a starter problem solution found
Discussion in 'The Hokey Ass Message Board' started by 325w, Sep 11, 2017.
  1. 325w
    325w
    tried to turn the 307 over with the starter. 168 tooth flywheel. Staggered bolt starter nose. Rebuilt four field starter. New solenoid and drive. Used flywheel. Flywheel,is on correctly. Hit the key starter tried to edge and hung in the flywheel. Loosen the starter bolts and the drive comes loose. After .160 of shims it still hangs but goes farther into the flywheel. Any ideas as to what's wrong. Engine turns with flywheel tool are at the crank pulley.
  2. Do you have the correct mounting bolts with the knurled shaft.
  3. 325w
    325w
    Yes correct bolts
  4. 325w
    325w
    Already added .160 shims. That's way,too many so something's not right.
  5. tfeverfred
    tfeverfred
    Has the block been machined?
  6. Mr48chev
    That's one I never considered before.
    I have seen some rebuilt starters that came from parts houses that have had the mating surface machined so much (maybe more than once) that they are a pain in the **** to shim right.
    One thing, if you think something is hinky with the end frame on the starter new Delco starter end frames aren't very spendy.
  7. BigDogSS
    BigDogSS
    from SoCal
    I did the research and found that a small, high-torque, permanent-magnet FACTORY Chevrolet starter from a 1999 C/K pick-up (5.7) is a bolt-on affair. I bought a NEW ACDelco starter from Rock Auto for about $100 w/no core charge. Compare these to expensive "mini-starters". I've done 2 installs with no shims within the last month.
  8. I've done several for customers in the early to mid 2000's, the only downside (a very small one at that) is it doesn't have the 12v kick up for the points when cranking.
    garyf likes this.
  9. 325w
    325w
    The flywheel has a counter weight on it. So I'm thinking I messed up there.
  10. 400 fly wheel ?
    Good thing it's on correctly:p:D
  11. H380
    H380
    from Louisiana
    That is the 3/4 ton 2500s for sure (and maybe the 3500s not positive). 1998 was the last year in 1/2 ton 1500s.
  12. uncleandy 65
    uncleandy 65
    I had the same problem with a new Delco. Come to find out these are made in Mexico now and I went with a high torque small and it works great with no shims
  13. 325w
    325w
    Well ----! Flywheel changed and the problem is better but a problem. Got mad and quit. Will try using a washer on one side then the other as a shim next. After that throw a fit!
  14. e1956v
    e1956v
    Alliance Vendor
    The marine solenoid has the r terminal for the 12v boost.
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
  15. King ford
    King ford
    from 08302
    Ditch the " correct" bolts , shimming down gains a small amount of " out" away from the flywheel, with the smaller bolts you can actually cheat it out a little bit and if necessary twist it a little bit to get the drive further from the motor and the brush end of the starter closer
  16. 325w
    325w
    Have used every style starter nose that's for 168 tooth flywheel and nothing has worked. Shimmed everyway I can think of and nothing works. Cast iron nose aluminum nose straight and staggered. So what now. Guess I'll try the 153 tooth flywheel. Starters are heavier than they used to be.
    belair likes this.
  17. blowby
    blowby
    from Nicasio Ca
    Same gear on the starter all along? Long shot but...
  18. 325w
    325w
    Changed the bendix to an American made. Same ole stuff.
  19. blowby
    blowby
    from Nicasio Ca
    What trans? Can you see up there? Take the solenoid off and pull the gear in by hand? If you leave the starter bolts tight but rock the crank does it pop back out? Nose hitting inside of bell housing?
  20. Ok so let's back up a bit to the first post.
    Specifically to the part of 0.160 shims.
    If everything is ok and as it should be - with out the shims, there's no way the starter could have ever engaged that fly wheel to hang up. It would go thunk thunk into the face of the gear. if the 0.160 shim still had it hanging up, then there's a problem. You said without those shims it engaged but got stuck.
    Try a completely different starter, not just a nose.
    INVISIBLEKID and Hardrider77 like this.
  21. bobss396
    bobss396
    Is it a manual? I use Chevy truck bellhousings since the starter mounts to that instead of the block. Been using the same combination since around 1983 in various cars.
  22. 325w
    325w
    UPDATE solution to starter not fitting!!!!
    New 350 crate motor will be here maybe tomorrow. If not it will be here Monday. Will change from the powerglide to a turbo 350 while I'm at it. So much for good deals!!
    HemiDeuce and cpd682 like this.
  23. belair
    belair
    That's a pretty drastic fix, but I like it.
    upspirate likes this.
  24. squirrel
    That's one way to do it.
  25. That's one approach !
    You'll need a flex plate and a starter for the new stuff too.
    Back in the early 90s I bought a 79 harley with a bad vibration in 3rd gear, I got it cheap because of that. Well the transmission was beat up and my friend rebuilt it. All good right ? Nope because 500 miles later it started again. It was certainly an alignment issue. I tried all kinds of ****, new inner primary case new clutch basket new primary belt drive - big money! And not a cheap harley any more. Well it wiped 3rd gear again. ( that's 2 times for me now) so I buy a brand new rev tech transmission $& $. All good now, nope. 200 miles and it's getting goofy so I park it. Couple months go by and by chance I find myself looking at a parts diagram for a different bike and notice the transmission bolt is speced as a "bolt" just a carriage bolt but the same Trans bolts on my 79 had a part number. 38 seconds of research and we discovered it's a special bolts for that 79 and 79 only. The dealer had them in stock at around $2.00 a piece. They are a carriage bolt just like any other but with one corner ground down to the flat. Swapping in the bolts solved that alignment issue.
    Take what you will from that.
    chevyfordman and Hnstray like this.
  26. 325w
    325w
    New crate motor and turbo 350 in the car. Just had to try the starter. Note to self crated motors have plugs in the exhaust and spark plug holes. When you hit the key. It sounds like a small explosion. Let's quit for the night.
    lothiandon1940, Hnstray and cpd682 like this.
  27. The spark plug caps fly out pretty good
  28. mgtstumpy
    mgtstumpy
