Hot Rods Drag week 2017
Discussion in 'The Hokey Ass Message Board' started by racer-x, Dec 9, 2016.
  1. els
    els
    mad mikey and loudbang like this.
  2. The points were junk. We think the horrible road conditions took it out. Next year we will remove the generator each day. Squirrel and i worked on it all day. We decided to run it and see what happens. We had 38 degrees of lead and it sure liked it. The tires hiked up and it took off. Unfortunately the mag started to act up. It was misfiring bad so i ended the run. We loaded up and headed out. Now the lencos 3rd gear is smoked. We are now out. I hooked up a ride to get the trailer. We might be back at the grove.
    loudbang, Stogy, bobwop and 1 other person like this.
  3. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Damn, X, that ****s. Too bad about the Lenco.
    I missed Squirrel's run this morning when I stepped away for a moment and then waited for yours.
    There's always next year.
    You are my hero.....
    kiwijeff, loudbang, Stogy and 3 others like this.
  4. 57 Fargo
    57 Fargo
    That ****s! I can't wait until that car makes a clean p***!
    You and Jim continue to set the bar high for the rest of us.
  5. It will happen. This wont stop us.
    loudbang, Stogy, mad mikey and 4 others like this.
  6. DDDenny
    Hello.......Donovan Engineering
    loudbang, mad mikey, squirrel and 2 others like this.
  7. Mike Colemire
    Mike Colemire
    Damn I hate to hear that, I watched some today and never seen you. Ra***ude 55 chev done one heck of a wheel stand and screwed up either 1 or both front wheels. Seen another 55 g***er having problems, he tried to make a p*** almost at the cut off, missed bad in the burn out and stated pumping white smoke out of both sides.
    loudbang and els like this.
  8. We ran late in the all run session. Ddd its funny you should say that a guy overheard me talking about needing some points. He gave me a card to call a guy who has points along with a donovan. Its going to happen.
    loudbang, mad mikey, Stogy and 5 others like this.
  9. DDDenny
    :cool:
    loudbang, Stogy and els like this.
  10. David Gersic
    David Gersic
    from DeKalb, IL
    That's a drag, Brian. Go Squirrel!
    loudbang, Stogy, grantrobert and 2 others like this.
  11. pigfluxer
    pigfluxer
    Hang in there Brian,and go Jim go.
  12. FinnishFireball
    FinnishFireball
    Drag week for sure is a tough event for cars and drivers as well. You'll do better next time and none of us doubts that.
    els, loudbang and Stogy like this.
  13. mad mikey
    mad mikey
    Sorry to hear you are out Brian, I did see your run today. Thats Drag Week, can not wait to get there, can not wait to leave. A toll is starting to take hold on a lot of cars. It really is a hell of a test of car and driver.
  14. mad mikey
    mad mikey
    Thats Finnigans aluminum injected hemi, 55. Hope he can fix and continue!
    els and loudbang like this.
  15. mad mikey
    mad mikey
    Thats Dennis Taylors 55, They had wheels on the way to fix the car and continue. Very strong running car!
  16. Dan Hay
    Dan Hay
    Finnegan's Blasphemi 55 Chevy dropped a valve during the burnout. Hole in the piston. They were going to try to limp on 7 cylinders but the piston is seized in the bore. He's done.
    els, loudbang and mad mikey like this.
  17. squirrel
    Well....my little Chevy made it to the hotel near Byron, so I should be racing in the morning.
    this is a tough game
  18. mad mikey
    mad mikey
    Damn, The carnage continues! Tough game to say the least. GO JIM!
  19. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    els, loudbang and grantrobert like this.
  20. Looks like hemi joel is out. The zallagas are still going.
    surf10, els, loudbang and 2 others like this.
  21. milwscruffy
    milwscruffy
    You should do a bed & breakfast for Squirrel tonight ! :cool:
  22. mcmopar
    mcmopar
    from Strum, wi
    Brian is that your sons green car? ****s to here about the Lenco. Will it be ready for rockfalls?
  23. I'm home now. i had to check on my lenco stash of parts. i had them sitting by the door to go on the trailer. at the last minute i set them to the side. sure enough two new sets of clutches still in the bags. we will have it fixed later today.
  24. i offered to put up jim. he p***ed on it. tricky steve and cheryl are staying here tonight. my son has a 69 super bee thats green.
    mad mikey, loudbang and els like this.
  25. mcmopar
    mcmopar
    from Strum, wi
    Did your son do drag week. I thought I saw his car. Are you going to continue drag week.
  26. H380
    H380
    from Louisiana
    Made the highlights
  27. my son has done drag week in the past but not this year. Im home now with the car and trailer. I will go to the grove. Not sure about running it yet. It looks like i have the parts to fix the trans. I will be tearing into it today.
  28. rgdavid
    rgdavid
    In your video i see squirrel playing with his nuts....i mean tightening his wheel.
    10.09, pretty damn good !
  29. malibumonte78
    malibumonte78
    Only two cars in B/Gas this year? And Chisholm and Stasiak aren't there. Dang this could have been my year, if only I had gotten mine done!
  30. FinnishFireball
    FinnishFireball
    Finns with VIP dropped another valve and are out too. Tough times they were second in ultimate iron. And it happened on the road and low rpm. They may try to fix it and race in Cordova outside drag week if in luck
