Projects Coil mount opinion ? UPDATE
Discussion in 'The Hokey Ass Message Board' started by 48stude, Sep 13, 2017.
  1. 48stude
    48stude
    I am building a mounting bracket for my coil. Can't decide which way to mount it. Which ever way I decide will determine how I build the brackets. What do you think? Thanks, Bill 2017-09-13 13.32.42.jpg 2017-09-13 13.33.56.jpg
  2. Straight up then if you lunch a coil on the road it won't matter what kind you get, remember some won't lay on their side.
  3. topher5150
    topher5150
    not sure how you lunch a coil, but i didn't think some had to positioned in a certain way?
  4. Chiss
    Chiss
    from S.C.
    x2 on the straight up, They are full of Fluid not that I think that would matter, unless the top cracks.
  5. bigheadbaxter
    bigheadbaxter
    Can you utilize those existing bolts there by the coil location to mount instead of drilling more holes? I was able to use bolts/bracket for heater hoses
    AVater likes this.
  6. bonzo-1
    bonzo-1
    Most of the OEMs mount them sideways. I think it would stop water being trapped inside the coil wire well.
    Mac VP likes this.
  7. Chevy Gasser
    Chevy Gasser
    Mount it like the lower picture, horizontal. Move it up and to the right center line with the body seam. use the two existing bolt holes and use stainless sheet metal. This will shorten your coil wire up while it also hides the seam and the two existing bolts. This will allow you to hide the wires underneath the seam.
    jim815 likes this.
  8. Jalopy Joker
    Jalopy Joker
    do a search here for "Horizontal Munted Coil" - misspelling of mounted by OP
    48stude likes this.
  9. gimpyshotrods
    gimpyshotrods
    Parallel with the top of the valve cover.
  10. Truck64
    Truck64
    from Ioway
    Oil filled coils are supposed to have the + and - terminals horizontal when installed on their side, the epoxy filled coils seem to work fine and won't ****** when they fail.
    48stude likes this.
  11. el Scotto
    el Scotto
    from Tracy, CA
    Make it stick straight out of the firewall
    61Cruiser likes this.
  12. LM14
    LM14
    from Iowa
    Mount it behind the firewall and just run the wires into the engine compartment to make it clean.
    SPark
  13. 48stude
    48stude
    Like this?
  14. 48stude
    48stude
    I appreciate every ones input. I am trying to resemble an early sixties build. Around here it seemed that the more stuff you had mounted on the firewall the better. Not exactly what I am trying to achieve, but voltage regulators and coils were the norm. I have a faux regulator to mount on the drivers side and because of that I am looking some symmetry or balance. Bill
  15. rjones35
    rjones35
    I'd say straight up.
  16. gimpyshotrods
    gimpyshotrods
    I like that look. Just throwing it out there as an option.
    48stude likes this.
  17. czuch
    czuch
    from vail az
    I had a 1946 Military dodge that we put a Red Ram 270 inch Hemi in one night.
    The coil was horizontal and stuck out from the firewall. One night I ran outta gas. (One night in particular)
    I went to get a can of gas and when I came back, I could smell it for a block. I had left the ignition on and the coil had puked a very foul ancient oil all over the motor. I still have some of the plates that were all over the motor.
    Just 2 blocks home, nothing good ever happens when Bacardi 101 is involved.
  18. 48stude
    48stude
    Before Al Gore invented the internet , I would have to wait until I could team up with a buddy to run some ideas past him. Then along comes the HAMB. You can get on here , throw a couple ideas out there and then in a short time you get to see see which way they bounce. I just love this place :D:p:rolleyes: Bill
    krbstr and wackdaddy like this.
  19. Lowdownfab
    Lowdownfab
    Diggin' that idea [emoji1303][emoji1303]
    Where'd you find that mount??
  20. el Scotto
    el Scotto
    from Tracy, CA
    The interwebz! I googled "Mopar Firewall mounted coil" and it came right up!
    Lowdownfab likes this.
  21. Lowdownfab
    Lowdownfab
    Found it! I dig this style mount. Thanks for posting it up.
  22. bobss396
    bobss396
    Mine is horizontal, the best use of the space I had on the firewall.
  23. 48stude
    48stude
    Well, this was a hard decision . Something as simple as orientation kept me on the fence . I basically flipped a coin. So this is where I ended up. I think I can live with this. So I just thought I would share with all the guys that offered me their opinion. I liked everybody's ideas but really had a hard time making a decision. Thanks to all you guys , Bill 2017-09-15 13.38.50.jpg 2017-09-15 13.39.05.jpg
  24. Jalopy Joker
    Jalopy Joker
    location looks good - be sure to run wire covers on coil terminals
  25. ClayMart
    ClayMart
    You can't go wrong mounting your coil at the same angle Squirrel does... :rolleyes:
    48stude likes this.
