rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Thanks for coming out to watch.
    els, loudbang and Stogy like this.
  2. seb fontana
    seb fontana
    from ct
    In NY they put signs saying "rough road" and boy is it true ! One place was so bad it was better to drive on the gr***, looked like a mortor round had hit the road..
    els, loudbang and racer-x like this.
    kidcampbell71, els, bobwop and 3 others like this.
  4. Runnin shine
    Runnin shine
    Yeah, a couple thousand mopowers will do that.
    That's a different scale than Horse power often used by non-brands[emoji6]
  5. strokedstang331
    strokedstang331
    from Beloit WI
    That ****s. Was that a common problem with these blocks on fuel? Is your block filled at all?
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
    els and loudbang like this.
  6. not filled. the common problem is they rust from the inside. gene adams told me if they are going to crack this is were it happens. it starts happening around 70 percent.
    kidcampbell71, els, loudbang and 2 others like this.
  7. tomcat11
    tomcat11
    I'm not a Hemi man but I would say that is not long for this world. Even with some block fill.
    The old Chinese proverb says "It is better to press your laundry than press your luck":eek:
  8. seb fontana
    seb fontana
    from ct
    No JB Weld I'd guess...
  9. strokedstang331
    strokedstang331
    from Beloit WI
    That makes sense never thought about it rusting out.
  10. FinnishFireball
    FinnishFireball
    That block is a piece of history, good call not to run a p*** yesterday. Without water mmmmaybe but please fill it as a safety precaution. "It'll hold one more p***" the famous last words on a track...
    els, wingedexpress and loudbang like this.
  11. Johnboy34
    Johnboy34
    from Seattle,Wa
    It's absolutely unbelievable what those old New Yorker motors have been doing all these years!
    els, loudbang and Runnin shine like this.
  12. Mr48chev
    Here are the two photos I snagged off the Hot Rod Magazine photos of the day shots that they posted today .
    I just took them with my camera with my coworkers asking what I was doing as i took them while we were on break. I think they can be downloaded off the page. DSCN6014.JPG
    Floater03, verno30, els and 2 others like this.
  13. Mr48chev
    Floater03, verno30, els and 1 other person like this.
  14. Runnin shine
    Runnin shine
    Is that Steve Dulcich on the left admiring the engine master's work?
  15. squirrel
    no, dulcich has long hair
    We might see him tomorrow at the Zip Tie Drags in St Louis.
    loudbang, els, enloe and 1 other person like this.
  16. rawcjw19
    rawcjw19
    Looking forward to see you make a p*** at rock falls. Your coupe is sweet. Thanks for taking the time to explain all of this to us.I would like to do drag week once. I may have to see what I have to do to make my car legal
    loudbang and els like this.
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brian;
    Sorry to hear of the cracked mill. I do love your at***ude(too bad you can't bottle it n sell it... Hmmm... Brians' Magical Nitro-charged At***ude-Adjuster Elixir... :D ). "Opportunity to ugrade"... :D . Glad to hear you won't tempt fate, chancing a major "spectacular event". I can hardly wait to find out how you get the Donovan to run on the street, since I've figured out that by now, that is "fate accompli"... :D . Hope things go well for you on the rest of the trip.
    Marcus...
  18. 20170915_122407.jpg I have never been one to not deal with car problems quickly once they are identified. Going race after race with the same issues is not my thing. A points mag is a problem. Yes they work and guys use them. They take maintainance and the parts are drying up. They are 70s technology. I used my super mag 4 because i wasnt sure if my ideas would work when i built the car. With the mag problems this past week it was time to go in a different direction. While we were thrashing on the car tuesday i told mark this car will have a pro mag on it real soon. we will also be removing the generator before we go street driving. we think the rough roads killed it. Little did i know how soon. At union grove a guy approached me about some nitro he wanted to unload. He was no longer bonniville nitro racing. I asked if he had other stuff and he mentions he has a pro mag 20 amp he needs to have go away. How conveniant is that. So i bought 30 gallons of uncut nitro and the ignition. He delivered it this morning. We are installing the pro mag today. The water will get drained from the block and we will be at the fallout. With the addition of the pro mag the only missing piece of this nitro puzzle is the donovan. All the parts will be in place then to add some lead; some boost and some percentage. This is getting serious now. i see header flames in my future.
  19. Dick Stevens
    Dick Stevens
    Sometimes it seems that it is preordained to happen, and some people seem to have the parts pop up just when they need/want to buy them! I will be watching closely to see how this all works out for you, good luck, although with your tenacity I'm not sure you need a lot of luck.
  20. BuiltFerComfort
    BuiltFerComfort
    So how do you keep a Donovan block cool on the street? I was poking around the 'net last night and only found drag racing applications.
  21. the problem with a donovan block isn't a cooling problem but more of a cooling containment problem. they were never designed to hold water unlike some late model keith black blocks. the issue is the bottom of the sleeve area won't seal the water. to solve this we want to machine aluminum sleeves that will be pressed into the block then welded into place top and bottom. after welding they will be bored so a steel sleeve can be pressed in. the girdle will be removed and modern caps installed so i can use a regular oil pan and starter. it will take some work but it can be done. this has been done by one other guy successfully so i know it can be done. with a long cold winter coming up soon this project will give me something to do.
  22. DFH-GMC
    DFH-GMC
    from Texas
    Damn man how far will you go
    There is a madness to my methods
    racer-x, loudbang and els like this.
  23. as far as it takes to win the unlimited cl***. we don't mind thinking outside the box.
    squirrel, loudbang, mad mikey and 2 others like this.
  24. DDDenny
    So much for those "honey do's".
  25. Runnin shine
    Runnin shine
    This pic had me wondering about if it does make night flames [emoji91]
    Not to sound too naive.
  26. rottenleonard
    rottenleonard
    Good news folks our favorite car show will be producing more episodes this winter! Looking forward to it Racer-x.
  27. I was curious, when switching from strip to street, do you have to also change the blower drive ratio?
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  28. Gotgas
    Gotgas
    from DFW USA
    If the Donovan (417?) block doesn't work out for some reason, let me know. I have an A-1 '57 392 block that I could deal on, especially to keep this thing moving.
  29. Well so much for getting the gr*** mowed. I wanted to see if it would fit. Its alot bigger than the super mag. I still need to mount the box and coil. This mag makes so much spark i need to make grounds from each head to the box. If for some reason the mag doesnt fire the plug the spark could arc to the cylinder. The result will look like a cutting torch was used. I have seen cases were the entire wall seperating cylinders was removed. These mags have some big time power. They will fire the mixture regardless of cylinder pressure or load of fuel. They can only be timed with a light. A bux box wont work. In the world of cars that go boom this is the ultimate ignition. 20170915_173355.jpg 20170915_173345.jpg
  30. wrenchbender
    wrenchbender
    That's a good mag brian we use one in our Flatcad motor at bonneville and it will definitely burn a big load of nitro that's for sure
