Projects CONVERTING A 1933 FORD FOUR DOOR SEDAN INTO A 5 WINDOW
Discussion in 'Traditional Hot Rods' started by H-O-O-V-E-R, Aug 10, 2017.
  1. Gavin Tittle
    Gavin Tittle
    Wow, what a fantastic show of skill! thanks for sharing.
    H-O-O-V-E-R likes this.
  2. rpm56
    rpm56
    Real nice work!
  3. el Roach
    el Roach
    Great job!
  4. Squablow
    Squablow
    Looks great, I'm subscribed! I have a '34 4 door and a collection of pieces to build the exact same thing.
    Are you willing to sell what's left of those coupe quarters? Because I'd be very interested in those. Not sure where you're located but the leftovers could be cut into smaller pieces if it needs to be shipped. It would further my project a bunch. Thanks either way!
  5. Very interesting project, and great skill on display.
  6. Pete
    Pete
    Great project, love the detailed pics too.
  7. sloppy jalopies
    sloppy jalopies
    ditto on the pix... I like the clecos holding the door gap and beltline alignment... good stuff.
  8. waxhead
    waxhead
    from West Oz
    Outstanding work.
  9. oldfordtin
    oldfordtin
    Amazing great work
  10. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Taped off and cut 1 inch out of the window, only on the hinge side does this need to be done. I actually ended up cutting the whole top of the Window off because I am going to chop it and it will just get in the way.
    Measured the b pillars and taped them off as level as I could. Did this the same to the donor 5 window piece as well. Measuring both off of the belt line should give me an acurate spot to cut.
    I welded this piece above the trunk in before we found the 5 window donor. Had to cut it back out. Will end up needing to weld some back in if the 5 window doesn't meet up perfectly.
    This is just loosely payed on top. Will cut and fit more and more to get it into its position as much as possible.
    This side is gonna take some work and rebuilding.
    Thanks for all of the kind words and support!!!
  11. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Thank you! Sorry, I told the guy we bought it from as part of the deal we would give him the leftovers. Would love to see the 5 window you are building!
    kidcampbell71 and Squablow like this.
  12. dodored
    dodored
    from Concord NC
    Great work! Lots of hours for sure. I am working on a 5W as well and feel the struggle. Subscribed.
  13. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    we both have a long way to go! You have some skills man, next thing you know you will be driving it down to the beach with your surfboard! Keep it up brother!
    kidcampbell71 and j-jock like this.
  14. Squablow
    Squablow
    Fair enough, thanks for letting me know.
    This is the '33 I have stuck together, didn't have much for quarters on this one so it's pretty rough but I did what I could with what I had, now I have a nicer '34 to start with so this one is getting sold off and I'll do the '34, same thing, starting with a 4 door sedan. I look forward to seeing yours come together, it's already looking good! I'm jealous of that roof section!
    This is what I started with. It does have doors, just not on there when these pics were taken. I saved the floor out of this '33 to use in my '34, it was surprisingly decent!
  15. King ford
    King ford
    from 08302
    Tramps like us ...baby we were born to run! Nice work,....good taste in tunes
  16. dodored
    dodored
    from Concord NC
    Actually I finished that car and am working on another that was not so bad. The black car is the finished product.
    It is an inspiration the work you are doing. I had often thought about doing that, but never came up with the pieces to pull it off. (32 4door to coupe)
  17. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Will score the 5 window donor once it gets fitting perfectly then slide it into place to weld it.
    Sanded down the b pillars until the gaps were perfect. Was able to get the p***enger side done. I am pretty pleased with how it's fitting.
    You can see the 5 window quarter window section laying over the top of the quarters.
  18. dodored
    dodored
    from Concord NC
    I can imagine it would be a challenge to get the doors to shut correctly. How have you dealt with that?
  19. Bugguts
    Bugguts
    I am loving the whole process and the pictures are great! Subscribed.
  20. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    I have had the doors on and off and they are shutting great. That is with the top of the window cut off. I imagine it will get trickier the tops on. The new section I am grating in will definitely need to be fitted and in the right place before its welded. As of right now it sits really close. But with the door on it give me a perfect reference where the top part of the b pillar needs to sit before its final weld.
  21. 56 Dodge Pickup
    56 Dodge Pickup
    Fantastic this is awesome I love to see metal fab Hobo Jim
  22. flamingokid
    flamingokid
    Simply impressed and subscribed.
  23. H-O-O-V-E-R
    H-O-O-V-E-R
    from Utah
    Was able to fit the drivers side today. I am getting excited because it's actually starting to look like a five window!
    The critical part is to get H the outer skin to match perfectly, you can see here that the b pillars outer edge is looking off. I will cut the lower half an pull it in to match perfectly.
    Wanted to show a close up of the roof section. Decided that I will just take previous pieces that were cut off and graft them back in to patch where I need to. The two roofs were hitting eachother and not allowing the quarter windows to sit properly.
    I also found out that the front half cutout of the roof is not the same shape as the five window. Will have to be cut and spliced to match perfectly.
  24. Squablow
    Squablow
    Do you happen to have that upper lip from the new roadster quarters that you had to cut off to fit them to the coupe body? I could use those pieces if they're intact yet.
    I also look forward to seeing how you get the roof sections together. That was a sticking point on my '33 that still needs to be addressed.
    H-O-O-V-E-R and ls1yj like this.
  25. Nailhead A-V8
    Nailhead A-V8
    If you already know the 4 dr. upper door section is higher toward the rear then it stands to reason that the fordor roof angles "up" from the A pillars so in reality there needs to be a pie cut done at the top corner of the A pillar (which will probably look funny) it will also have to be pie cut to pinch it "in" since the 4 door rear roof is much wider at the back than the coupe.... unless you gave those front coupe roof pieces back why mess with the fordor stuff at all?
    Outback and kustomkatt like this.
  26. Squablow
    Squablow
    It's not the B pillar height that was the issue for me as much as the width seemed to change abruptly (like if you were standing in front of or behind it, the joint at the roof would be bulged out to the side, not just the top from the B pillar height).
    Another HAMBer bought my '33 and took it home this weekend but I've got another '34 to do and I'm still curious to see how this comes together.
    Outback, ls1yj and Nailhead A-V8 like this.
  27. swade41
    swade41
    from Buffalo,NY
    Great detailed build thread, quality work too.
    kidcampbell71 likes this.
  28. Can you PM me about the panel I see in the background?
  29. What a *****in thread! Kill work!
    I will be doung the same thing pretty soon here, just found a bunch of parts that will help in our build!
    Watching and learning here for sure!
    -Shiny
    Outback and H-O-O-V-E-R like this.
  30. Fantastic thread! You guys are metal magicians.
    Bob
