Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Stogy
    Stogy
    Bu Bu Bu Bu Butcher...Ouch...:eek:...Not uncommon in the depressed good ole days where it just had to work and be affordable and didn't need to tighten anything.
    Nothing else has gotten in the way of moving forward. Braze really complicates things. Cut out and replace involves multiple layers. Whats @dumprat's fix?
    Runnin shine likes this.
  2. dumprat
    dumprat
    from b.c.
    Grind it out, drill the screw stubs. Beat it straight. Replace the screws and go from there.
    kiwijeff, Runnin shine and Stogy like this.
  3. Six Ball
    Six Ball
    from Nevada
    I did some things then that I would not do now. Many of us had very limited tools. A torch set was a big deal. Brazing was easy and plenty strong for most things. Never welded any hinges though. We had a little access to the metal shop in high schools stick welder and the like.
    Stogy likes this.
  4. dumprat
    dumprat
    from b.c.
    Well after shimming the body to get the alignment of the door right i pushed, and pulled and beat and pried the door into place. The overlap gaps are not awesome but it lines up and doesn't hit the drip rail anymore. On to latches, hinge screws and dovetails.
  5. sloppy jalopies
    sloppy jalopies
    If you mean the door hinge to cowl screws..... metalsmith "flop".... has pix of those screws laying on the roof of an A coupe... he welds onto the slotted end of each screw... when he gets about a 3/8" lump he welds a nut to the lump... not only do you have a good grip but you have heated the screw red hot... I would let it cool to cold as the metal has had some carbon baked out of it and will shrink.... should come right out...
  6. dumprat
    dumprat
    from b.c.
    Sloppy. They actually braised the screws into the body after they broke the heads off. All fixed now. Waiting on the right screws, temps are in to get latches figured out.
  7. dumprat
    dumprat
    from b.c.
    IMG_1928.JPG Bust chasing kids to play dates and things, but managed to spend some quality time garage sale shopping and found a local guy who buys up tools from estate sales. He is a wood worker and has little use for mechanics stuff or body tools. So I picked up a few bits from him to round out my collection of hammers. $70 Canuck bucks for two proto, a snap on, a real nice old dolly, a new vixen file blade, and a snap on 3/8's ratchet.
    They all need some touching up but are all serviceable.
  8. dumprat
    dumprat
    from b.c.
    Interesting tidbit. The dolly is a "jobborn" made in canada. The company went out of buisiness in 1951.
    Stogy likes this.
  9. Runnin shine
    Runnin shine
    Old tools rule!
    Oh yeah so does you truck.
    I won't care if it's in that yellow primer when it makes it to Colorado.
    Woogeroo and dumprat like this.
  10. Okie Pete
    Okie Pete
    Some M***ey combines and tractors ran the tack drive off the generator . Also old fork lifts.
    Stogy likes this.
  11. dumprat
    dumprat
    from b.c.
    I am still on the hunt for a proper tach drive. Sill be looking hard at the swaps in the spring.
    Wayatt. The cab should go out for blasting within a month. And if get our usuall Indian summer I can fill and sand after that. If not it will sit in epoxy until I finish the frame boxing and final. And if I have to brush paint it black I will.
  12. dumprat
    dumprat
    from b.c.
    Talked to the wife about the hillclimb. She will likely p***. Will make for great reason to pull Tommy out of school wor a week, I am sure that will break his heart.....
    brEad and Stogy like this.
  13. 27TV8
    27TV8
    I have been following along. Here is a ratty Gen ,maybe off a power steering unit of a 58 Chev. They drove a hydraulic pump off the gen. It turns but needs some help. It is yours if you can use it.
    The spline drive could be adapted.
    Tim_with_a_T, Stogy and bct like this.
  14. dumprat
    dumprat
    from b.c.
    Thanks for the offer Thomas. I may just take you up on that. I have a 12v Chrysler genny that I need to have tested. It has a little tin plate on the back that I should be able to make a drive to replace. That is a little ways down the road.
    tb33anda3rd likes this.
  15. dumprat
    dumprat
    from b.c.
    IMG_1528.JPG While one part of my twisted little brain is searching for 34 roadster parts I am still fiddling away on truck stuff. If you have been following along the original latches were hacked out with a torch sometime in the past. I have the latches installed in the doors and have been working towards getting the posts attached to the cab. I have it figured now and even just tacked up the door closes tighter than the wife's Beamer.
  16. I thought I was the only one that saved oddball stuff like that.
    Bob
  17. Are you using a Chevy latch?
    Bob
    daylatedollarshort likes this.
  18. dumprat
    dumprat
    from b.c.
    Western star truck latches. Big heavy duty jobs.
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    The bends are larger radius than the stock manifold and the long runner box plenum has been done before. Hope to have it running next year. It's not about how fast you go, it's how you go fast.
    Sent from my SGH-T999 using The H.A.M.B. mobile app
  20. That is a score. very nice dolly, hard to find multi purpose with superior heat treat. I wonder why they went out of business, or were they absorbed? What's the sellers info:rolleyes:
  21. dumprat
    dumprat
    from b.c.
    This project ain't dead yet. More to post tomorrow maybe. Lol
  22. Jethro
    Jethro
    Looks like you've lost some weight.....take some time to have a bite now and then, don't work so hard.:D
    Woogeroo, ratrodrodder, brEad and 3 others like this.
  23. dumprat
    dumprat
    from b.c.
    Gastric byp*** gone wrong.....
    ffr1222k likes this.
  24. Dick Stevens
    Dick Stevens
    I certainly hope this is a joke, not reality! I have personal experience with complications from surgery for gastric cancer and while it is effective for weight loss I certainly don't recommend it!
    Stogy and Runnin shine like this.
  25. dumprat
    dumprat
    from b.c.
    Sorry. A joke of course, possibly in poor taste.
    Stogy and Dick Stevens like this.
  26. dumprat
    dumprat
    from b.c.
    IMG_2047.JPG IMG_2046.JPG One of those jobs that seems to take forever and doesn't look like much. Fitting the Plymouth pedals around the ford floor and getting a pedal box built. Once complete it will be held on with stainless screws and have rubber boots around the pedal shafts to keep some of the water off the carpet inside.
  27. bct
    bct
    I'm in sooke right now and think that rubber boots are a good idea for you island folk!
  28. JimmyD3234
    JimmyD3234
    from PA
    how is that truck coming is it DONE
  29. JimmyD3234
    JimmyD3234
    from PA
    looking good nice fab/work good luck with it
  30. Stogy
    Stogy
