1952-59 Ford 53' Mercury rear end swap?
Discussion in 'Off Topic Hot Rods & Customs' started by Heavy Metal, Sep 16, 2017.
  1. Heavy Metal
    Heavy Metal
    I have a 53' Mercury Monterey 2dr HT and *think* I would like to update the rear end. The PO told me always carried a spare axle with him as he had broken a couple of them. Debating if I should swap out the rear for something that is a little sturdier and with more modern brakes? If so, what rear end is a fairly easy swap? My fab skills are limited, though I do have some resources for help if needed.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. 56longroof
    56longroof
    Jeff, I know you've posted this before but is the Explorer rear axle a direct swap or are there mods needed? Also is there a year that had drum brakes?
  4. Paul2748
    Paul2748
    For 52-56 Fords, the 57 and 58 nine inchers are a direct swap . Same for a 65-66 Mustang 8 inch. 59 9 inch may also be a direct swap, but not sure of this because of the spring pads. I don't know if this holds true for the Merc's. You would have to measure the Merc and compare it to a Ford of the same year.
    I believe that the Explorer swap may require modifications, so read the article mentioned.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    The 1957-59 9" are the same they are a direct fit except for the rear U-joint but these only have 28 spline axles and are non-locker aka Posi but due to demand over the years they can be way up there in price as is the early Mustang and Maverick 8". If you read thru the 8.8" link I posted from rangerstation.com it lists the widths in this chart http://www.therangerstation.com/tech_library/Ford-8_8-axle.shtml Best fit with only the relocation of the spring pads is the 1990-92 Ranger rear at 56 1/2" width you can swap the disc brakes from an Explorer to a Ranger rear. The Explorer rear could be used if you were to use wheels with a positive offset as it is about 1 1/2" wider than your Mercs,the other option is in these two videos.
  6. Heavy Metal
    Heavy Metal
    Thanks for the great feedback. Looks like have a little research to do. Thanks for the info from the ranger station, this is a big help. I have a u-pull yard near where I work, I will check in there and see what they have.
