  1. singledownloop
    singledownloop
    57Volvo-010.jpg A friend pointed out that the picture I asked for help with is a 544.It has a one piece curved windshield.The car I bought is a 444 has a 2 piece windshield.I searched quite a bit to find the 444 I bought because it looks more vintage with the split windshield.It also has a lot smaller rear glass.Is there anyway to convert this car to a coupe.Sorry about mistakenly posting the wrong year car.If it wasn't for bad luck i'd have no luck at all.
    I know nothing about photoshop.Can the work done on the blue car be transferred to the red car or maybe the windshield of the red car could be put on the blue car and the blue cars back glass can be removed?
    Peanut 1959 likes this.
  2. themoose
    themoose
    whtbaron and 509garyd like this.
  3. Sancho
    Sancho
    @themoose you sir are a Photoshop master!
    themoose likes this.
  4. themoose
    themoose
    Here's a quick one...I can lower it or do whatever else you want
    kiwijeff, Peanut 1959 and verde742 like this.
  5. verde742
    verde742
    I put running boards on mine, from rear of front wheel opening to front of rear wheel opening, dropped front fenders down to the boards , lowered it to the earth, 14 inch wheels/tires, molded rear fenders, '56 Chevy lenses sunk into rear fenders,etc.
    trying to make it a "small "46-48 ford".
    Finally chopped top,
    but nothing would get rid of that smell of the interior of an early Volvo,
  6. Peanut 1959
    Peanut 1959
    This Hudson pickup is from a build thread here on the H.A.M.B.
    Could one of you fine PhotoShop masters please replace the squared rear fender with the Studebaker rear fender and recolor it to match the rest of the truck? If it's easier, just recolor the entire thing a similar orange.
    For fun with the rolling stock and stance, you could do one custom version, and one rod version. With your blessing, I'll then share them on the other thread.
    Thanks in advance!
  7. verde742
    verde742
    maybe shorten W.B. on Hudson and put the bed, from Stude, w/fenders on Hudson,
    just don't make it any uglier :rolleyes:
  8. singledownloop
    singledownloop
    Wow Moose thank you very much.I'd like to see it 3" or so lower,more if you think it'll look even better.Please remove the bumpers and mudflaps.This version almost looks like a chop is in order but i'm not sure,your opinion?
    verde742 Can you please share pics of your volvo,build pics would be great.I keep going back and forth on running boards.
  9. verde742
    verde742
    LeoH and themoose like this.
  10. verde742
    verde742
  11. verde742
    verde742
    the boards: I welded on UNDER the body to make it appear lower, then brought fender DOWN to the boards,
    LeoH, Squablow and themoose like this.
  12. singledownloop
    singledownloop
  13. verde742
    verde742
    just stood back till it looked right,
    never had a stocker to compare measurements..
    singledownloop likes this.
  14. singledownloop
    singledownloop
    verde742 that's a super slick looking 544.What did you use for engine,trans,etc.?
  15. verde742
    verde742
    completely stock , dual side drafts, 4 speed, regret selling,
    got great mileage and went like crazy.
    Alignment of wheels and tires is distorted in pictures, was not like as they appear..
  16. James D
    James D
    I don't know. Just enought to look right. You can't really leave it stock height though. The top looks much too bulbous that way.
  17. themoose
    themoose
    @singledownloop
    Here's one with a more custom theme just for the heck of it....
    whtbaron, kiwijeff, OahuEli and 2 others like this.
  18. themoose
    themoose
    Here's one version
  19. Squablow
    Squablow
    The boards under the fenders with the fenders brought down to match really looks right, it's an issue I didn't even notice until I saw it this way. Very clever.
    verde742 likes this.
  20. Peanut 1959
    Peanut 1959
    Thanks much, moose! But I'm not sure the Stude fender is any better than the squared off International fender. Thoughts?
    kiwijeff likes this.
  21. themoose
    themoose
    @Peanut 1959 Here it is with a different stance and wheels and tires to help pull things together....
  22. singledownloop
    singledownloop
    Man Moose the custom version is killer.The chop really makes it,do you know about how much of a chop you give it?It's my new screensaver now.I'm going to get started on the conversion soon.Thanks a bunch you have mad skills.
  23. verde742
    verde742
  24. singledownloop
    singledownloop
    verde742 a couple more questions about your pv.How thick did you make your running boards,also did you make them the same width of the front or rear fender or do they angle from the rear fender to the front fender?It's an awesome subtle mod that really ties things together.Thanks for sharing the pics and info.
  25. singledownloop
    singledownloop
    Running boards like yours would look killer.
  26. verde742
    verde742
    They were bent out out 16 ga. with two 90 degree bends, about an inch or so apart, I made the "boards" almost as wide as rear fender and made the outside edge parallel with body, it turned out well, To start with I wanted them wider, but after holding them up, I liked the subtle look, so I "tucked" them under body, I got pieces from VW bug for fender extensions.
    then trimmed the part under the body off.
    On all of my modifications on projects, I like to make people wonder, "what looks different here ? " Just seems like more fun. (i.e. sectioning a car/truck, and leaving door handle and trim..)
  27. singledownloop
    singledownloop
    I'm not real bright are you saying the running boards are narrower where they meet the front fender since the front fender is wider than the rear fender?Did you square off the bottom of the rockers?
    Sectioning a 59 rambler American 2 door sedan ,keeping all the trim and door handles, is on my short list of cars to build.
  28. verde742
    verde742
    after you bend the pieces, hold them up until it looks "right" >> The eye does not lie, the rear, and front fenders stick out further than running boards.
    I did not modify rockers at all, I DID make sure drain holes were open to the underneath.
    You will KNOW when it looks good,
    IF it looks good, nail it, just get piece wide enuff you can move in or out, before you weld.
  29. Peanut 1959
    Peanut 1959
  30. Flamed48
    Flamed48
    Could I see my car in the pagan gold and leave the black please and thank you
    Leon Sandcastle likes this.
