Hot Rods OH NOOO! 32 WRECK!!
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Sep 17, 2017.
  1. hotcargo
    hotcargo
    thats where the cowl was cut to do the radical chop ...........the tear would be typical from impact on the heat affected zone of the weld
    very sad to read about the demise of this great little car , glad the lad is reasonably OK ........and maybe rebuild
    Steve in Oz
    Hombre and ls1yj like this.
    Yep X2
    Hamtown Al and ls1yj like this.
  3. TomT
    TomT
    Man, so sorry to hear/see this but you are here to relate the story and that's the best news .....
    Hamtown Al likes this.
  4. The37Kid
    The37Kid
    Henry Ford used the same basic setup on 15 MILLION Model T rear axles. Forged perch, rounded inner edge and a rounded chamfered hole. Bob DSCF9715.JPG DSCF9716.JPG DSCF9717.JPG DSCF9718.JPG
  5. The37Kid
    The37Kid
    While looking at the crack in the cowl don't overlook the important part, the door posts look fine. Fairly sure the chop wasn't just a cut and **** weld, the inner structure was rebuilt, then the outer skin went on. Bob
  6. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    It is good to hear that you are ok Ben. So sad to hear about the ride. You surely had a few angels ridin with ya that day.
  7. Baumi
    Baumi
    Holy sh*t, this is giving me shivers.... I´m glad you walked away in one piece.You built it once, I´m sure you can do it again... it´s a shame to see this car mangled up like this, but it surely did it´s best to save your life.
    hotcoupe and 31Vicky with a hemi like this.
  8. So-cal Tex
    So-cal Tex
    Glad to hear you are alright and survived the wreck pretty much unharmed...............repair the ch***is and order another Brookville body for flop to chop, the pale rider will ride again!! .................Also for everyone else questioning the suspension design that Doane Spencer created (and the Rolling Bones adopted). I would not be afraid of it since the Rolling Bones run it on every car they build with 10,000 of thousands of miles has certainly proved it is a sound design,My concern is looking at the perch pin and the fact Ben mentioned it had multiple cracks ( cast?) then sheared would indicate was a cast repro not a forged original which may have made a difference with the load on it.
    The37Kid likes this.
  9. Chucky
    Chucky
    @31Vicky with a hemi posted a photo which made me scratch my head. I'd never seen a non-tapered spring perch before. So I reverse googled the image and ran into the article about this "not to be afraid of" awesome front end. Not so awesome in my opinion.
    Atwater Mike likes this.
  10. Jeeeez dude, glad your ok!
    Yes it's hard to tell exactly but It's looking like its more turned 90* than left tapered.
    Tim_with_a_T likes this.
  12. Rand Man
    Rand Man
    I would like to hear from the owner Ben. I want to make it clear I realize nobody likes an "I told you so", but I agree with others. That radius or taper is critical. The perch pin in the photo looks like a forging to me. Even a forged part will shear off, if enough force is applied at a single point. That taper is on there for a reason. Don't remove it. Hindsight says to taper the bung to match.
    RODIST, Speedwrench and X38 like this.
  13. Doane spencer influenced MUCH and inspired MUCH. Sure it's running a suicide front end.
    All low slung spring behind suicide front ends are NOT created equal.
    The pics aren't the best and there is a lot going on there. But look at what you can see. Not to many guys copy it.
    Z in the front gets ride height lower and uses stock curved crossmember.
    1- That makes sure the spring doesn't ever bottom out on a flat crossmember. 2. Makes room for the tie rod
    3. Gives room to mount/move/hide the shocks inboard with short arms that work.
    4. It gives a bump up for the motor mount pedestal so they aren't on break away towers.
    These are obviously not split wish bones with a bolt thru them- but hairpins on batwings. There is plenty enough real estate to build a dead perch on the drivers side and a big gusseted Spring perch or shackle mount on the p***enger side.
  14. Fortunateson
    Fortunateson
    Yeah, that's one of the first things I noticed. Looks kinda rotten to me or maybe it's a clean sheer with a little filler making it look worse than it is.
  15. X38
    X38
    It was a new body.
  16. big duece
    big duece
    from kansas
    No filler.... that body was metal finished to perfection. You need to read the entire build. 63a5885e3964e29b45f7417539f7e66d.jpg
  17. Oh it wasn't rotten there,
    That's where it was cut, patched and metal finished
    Dennis Lacy likes this.
  18. Stogy
    Stogy
    This Hotrod was in a catastrophic accident. Weakest links are going to give. That is a given. This was a suspension anomaly that caused mayhem and should be the main focus. We watched this build in detail and this workmanship was built to stand normal operating conditions I have no question about it. As eluded the structure actually aided in the preservation of life and owes knowone any apologies.
    Bubba1955, LOST ANGEL and clem like this.
  19. Pete Eastwood
    Pete Eastwood
    from california
    Yesterday, when I saw Ben's pictures on face book, My thoughts went to all the topics that have been discussed on this thread so far. I'm glad to see people thinking about this & what the cause & effect's are. Hopefully something will be learned from this so there won't be a repeat situation. I'm really glad Ben is OK.
    I have my own thoughts on this, & will be interested in the forensic conclusion / out come on this.
  20. Pete Eastwood
    Pete Eastwood
    from california
    Amen !
  21. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Rebuild it and do a follow along on here. Glad you are OK.
  22. Pete Eastwood
    Pete Eastwood
    from california
    What is the ***le of the build thread on this car? I'd like to look through it.
  23. Stogy likes this.
  24. Torana68
    Torana68
    from Australia
    No , machining there to 90% will create stress risers and cracking , should have a radius, but, probably a market here for matching tapered bungs so the part fits like original (and no cheap casting's)
  25. The37Kid
    The37Kid
    The world will never run out of junk Model A wishbones, why not cut off the ends of the yokes and turn them down to use the factory tapers and install them in the split bones with good factory perches? Cutting a slot and welding in a flag like some race car axles isn't a bad idea either. Bob
  26. Is there a good reason one couldn't forgo the talk about tapers and such and just weld up the taper area to equal the bushing diameter shown, drill a hole through the wishbone and weld the larger diameter perch in from both sides. (Won't work so well on cast parts) That perch should never have to be removed, right?
  27. The37Kid
    The37Kid
    If you weld the perch in how do you know it is in the same plane as the spring? Caster is determined by the split wishbone placement, lots of things to think about before welding it together, think I'd go with a adjustable perch some Loc***e and a nut. Bob
  28. Hackerbilt
    Hackerbilt
    Just for consideration and discussion.
    Ben's car uses a cross steer setup.
    If a drag link, or better a cowl steer design were used the car would drop and slide with much less steering direction change as the axle shifted sideways.
    Also...T bucket suicide front ends use a bolt on spring hanger that appears far less robust than a factory style perch bolt. They have a machined flat for mounting.
    Thoughts on those???
    Hotrodt15 likes this.
  29. I'm fairly clueless about the front end bits-- but perhaps someone should dare Jim Sibley to straighten that body out. Tell him "this can't be fixed" and then stand back.
  30. JimSibley
    JimSibley
    I am flattered, but after reading the build post I am more than confident that Ben can put this car back together to as good or better condition.
