Hot Rods T Bucket Interiors
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Aug 12, 2017.
  1. steel rebel
    steel rebel
    Fred
    Something you might not have thought of. Very popular in '60s T buckets. Light, fairly comfortable, fairly cheap.
    I still see them in antique and second hand stores for a few bucks. Any color would look good in the "Black Dalia" with no other upholstery. Sure to be outstanding wherever you stop. Just cut off the legs at the height and angle that is right and weld something between the legs and bolt them down. Seven pages on eBay from these prices to thousands.
    Give it some thought. Think it is what I would do.
    Gary
    WC145, Chavezk21, kiwijeff and 2 others like this.
  2. tfeverfred
    tfeverfred
    Thanks, Rebel. That's far enough out of the box to peak my interest. They kind of remind me high school detention. I spent some long hours in those chairs.
  3. steel rebel
    steel rebel
    Then Fred you know how comfortable they are. Or not after you have been paddled.
    raven likes this.
  4. tfeverfred
    tfeverfred
    I went to a Catholic high school. It was the knuckles, man. My soft, tender knuckles. I still have nightmares.
  5. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Or you could take a page from the RR book and cut the legs off a metal folding lawn chair with a hacksaw and bolt them to the floor as crudely as possible.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  6. dana barlow
    dana barlow
    from Miami Fla.
    I do like bench seat my self,just more room for every thing,but angle of both bottom an back are really what makes it work,as matched up to pedals an steering=all must be played with at one time to get it right for your body fit. When I see Bomber seat used,all I think of is how bad they felt in every rod I've tryed to ride in,that had them,adding that to only place they ever looked right to me was a race car. I did do a tech here on HAMB of how to do your own upholstery at home,a few years back. May help or not.?
    https://www.jalopyjournal.com/forum/threads/tech-sew-at-home-upholsrety-hot-rod.604077/
    WC145 and loudbang like this.
  7. tfeverfred
    tfeverfred
    Thanks. More food for thought.
    dana barlow and loudbang like this.
  8. tfeverfred
    tfeverfred
    Ummm....... no.
  9. steel rebel
    steel rebel
    Go Go Dancer
    You have a point but I stand by my post about '50s fibergl*** seats. Mounted correctly, safely and not crudely they would be a standout. If seatbelt's were installed you would stay in them. Maybe a foam cushion and they would be comfortable.
    Fred honestly if I were building what you are I would use them. All colors are out there and any would stand out and look *****in against all the black.
    Nuff said Rebel
  10. RodStRace
    RodStRace
    another one that's not common, a design from the Citroen 2CV
    basic, light, and designed for rough field driving.
    They probably don't support well, and you may not want them removable
    WC145, Atwater Mike, Dannerr and 6 others like this.
  11. 1/8th scale big T kit.
    I might finish this thing this year, it's only been eight years in the making. IMG_20170827_171946.jpg
    Paul and loudbang like this.
  12. flatoz
    flatoz
    Sorry Don't have a photo of the interior by itself, but you can see it in the video linked below. it was done in the 60's and has stood up well. This is my olds mans car, he's here on the HAMB
    kiwijeff and tfeverfred like this.
  13. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
  14. Hackerbilt
    Hackerbilt
    My seating right now consists of the wood top for the rear body inner bracing, the floor and an upward angled front section to position your thighs.
    To divide the seating I added a wooden "arm rest" that actually sits too low to be used but gives you something to grab as you lever yourself up and out.
    The original plan called for a padded full black diamond vinyl cover from one side to the other...but when I went to buy the material from the only supplier in town the entire bolt was on the missing list!
    With no time left I just folded the old gl*** bucket covers and screwed them to the wood.
    The black carpet like stuff you see is very much like the trunk side material in new cars and is plastic backed so its stiff.
    Bought 20 pieces at the local Dollar store and they worked excellent for the worry free interior I wanted.
    I'm actually shocked at how comfortable this sparce interior is!!!
    I think its a result of your body weight being supported pretty much over your entire torso, as you kinda lay in the car as opposed to sitting up on your ****...and its great to be sitting so low. You feel like part of the car, not just along for the ride. Last pic shows just how low we are in the body.
    This winter the lower section gets reconfigured to get me even lower (for a low top thats going on) and the 'gl*** bucket covers will likely be replaced as they won't be long enough.
    BTW...the p***enger side bottom hinges up for battery access.
    WC145, patmanta, tfeverfred and 3 others like this.
  15. Koz
    Koz
    Used to be a guy that always went to Fall Wildwood that had a '29 roadster shortened behind the p***enger compartment and trunk lid to fit a T ch***is. Super neat car that used some '50's era chrome tube kitchen chairs with the legs cut off and metalflake seat pads. Very cool car. Haven't seen him in a while now.
  16. steel rebel
    steel rebel
    Not to mention grocery carts made into seats. They didn't seem to look too comfortable to me though.
  17. gdaddy
    gdaddy
    from nw fl.
    parents or grandparents must be flathead fans
    WC145, blackjack, volvobrynk and 2 others like this.
  18. tfeverfred
    tfeverfred
    I did some searching on the Corbeau bench seat. The video shows a seat with mounting holes for a Bronco, but the regular seat is universal mount with 4 tabs on the bottom. I'm showing this because it shows the "suspension" for the seat and it looks like it could be adapted to a DIY seat. The construction is really rather simple.
  19. tfeverfred
    tfeverfred
    I've been getting some body width dimensions from a rep at CCR. Looking at the pic, the cross bar for their seat is 37". However, as the outer frame is round, I may gain another 2" on each side. Keeping in mind that the body widens, as it tapers up. The 42" Corbeau seat is 41" at the top of the seat structure, coming off a 36" base that is 6" tall. My math says either the 40" or 42" Corbeau seat should fit. The 40" seat has a 5" base. I also have an idea on how to make the seat removable. As always, if the seat frame needs to be tweaked a little. The BF hammer will clean things up.;)
    CCR measurement at cross bar:
    Scroll down the page index for the 42" seat measurements:
    https://corbeau.com/bench-seats/42-baja-bench.html
    Disclaimer: As always, this is an idea. Nothing is set in stone and ideas may or may not change.
  20. steel rebel
    steel rebel
    Nice seat it will look great.
  21. Blue One
    Blue One
    from Alberta
    Is an opening drivers side door an option on the body Fred ?
    If so I would really recommend getting it done. Climbing in will get old (so will you ;)) :D
    wbrw32 likes this.
  22. tfeverfred
    tfeverfred
    It's an option on the p***enger side and right now, I'm not considering it. One reason is the cost. While the door and substructure they add for it is VERY well done, it's a $600 bump to the price of the body, which is $1,650. I'm long legged and this build is a little lower than my first T Bucket, so stepping into to it shouldn't be a problem. But as I get closer to ordering my body, it is on my mind. I'll cross that bridge, when I get to it. Here's another look at it. VERY tempting!
  23. Blue One
    Blue One
    from Alberta
    Looks good :cool:
    Since I'm an old fart I'd get opening doors on both sides. I'd appreciate them just as much as any of the ladies appreciate it on the p***enger side :D
  24. tfeverfred
    tfeverfred
    Trust me, Blue. When I look at that door ***embly, I'm also looking at my wallet, the list of other parts I still need and my knees!:D I get a good work out at my job, but what will I be like in 10 years? All things are being considered.
    When I visited my friend, who has the same body with doors, I was very impressed. Time will tell. Now, since you opened up that can of worms, I'll have to read all the posts declaring that the door should be a must.:) Thanks, ole buddy.:rolleyes:
    dana barlow likes this.
  25. Blue One
    Blue One
    from Alberta
    No problem, what are friends for Fred. ;)
    I know where you are coming from with the budget issue.
    I'm just trying to help you out with a good decision.
    I'd hate to have you build your car and then need a 3 step kitchen ladder to get into it :D
    It would be a bummer to wish that you had put doors in it later on down the line.
    Isn't this fun ? :D
    Does your friend have doors on both sides?
    As I said that would be a must for me.
    If so, how does he like it?
    Glad I can help, I have a good can opener :D
    tfeverfred and dana barlow like this.
  26. volvobrynk
    volvobrynk
    from Denmark
    Hey Fred
    It's always nice to dream, and I most confess, Im no bucket fan.
    But I like track roadsters, and I've been having wet dreams about a channeled '32, with a very appealing interior, that might get you creative juices flowing.
    And yes I know a '32 is bigger then a bucket, but it gets a lot smaller when channeled.
    I know the dash might not be of interest, but it's a little special, but also show how little room there is under dash.
    http://www.kustomrama.com/index.php?***le=Roland_Larsson's_1932_Ford
    WC145 and Dannerr like this.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    $600 for a door is dirt cheap IMO...Ladies like 'em too.....drivers side door in a '23-'25 style tub is pretty much useless as the steering column is usually in the way...
  28. Blue One
    Blue One
    from Alberta
    That's why they make quick realease steering wheel hubs.
    They're not just for racing you know.
    tfeverfred likes this.
  29. upspirate
    upspirate
    I had a 26-27 t that the old guy who built it put a p*** door in......I would do that. Made it much easier for me to basically walk in and sit down . ( and I was
    28 yrs younger then) Do it now, much cheaper than later....just stay on the clock a few more hours or sell something!!!:D
  30. tfeverfred
    tfeverfred
