Technical The Painting at home in the driveway or garage thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Sep 15, 2014.
  1. John Stimac
    John Stimac
    !cid_A05EBA20D00F458B9FE784AC2085584D@StimacPC.png !cid_2F9CCBFEEF3841FAAEB3C8F10612926B@StimacPC.jpg !cid_ECCC9C8C8951467A8684EF23F1BC4C80@StimacPC.jpg Everything I do is in the alley
  2. lowcoe
    lowcoe
    [​IMG][​IMG]
    Grille , bumper and tailgate in
    Primer. Next is to blow it all apart and put it in color.
    RockinRivi, Ulu, loudbang and 2 others like this.
  3. Ulu
    Ulu
    from CenCal
    Wow you're not just painting in the driveway your painting in the drainage ditch!
    It looks like you had quite an interesting situation there.
    So anyhow, what's the rollover trunnion ***y for?
  4. A Boner
    A Boner
    The trickiest thing is to get a day that isn't too hot, isn't too cold, isn't too humid, isn't too windy, isn't too buggy, isn't a day with pollen, or leaves falling from the nearby trees, and have all the prep work done before you get one of these days!
    Also, if you don't have shade, a cloudy day helps.
  5. lowcoe
    lowcoe
    Ulu. I like to call that a rotisserie... although it won't rotate 360 degrees...
  6. ClarkH
    ClarkH
    Been meaning to post to this thread for a while. Painted my speedster just about exactly a year ago. Sealed the carport with plastic and installed several blowers and fans with furnace filters. Epoxy base, 3 coats of build primer followed by three coats of color.
    Started in August and it was a race against time. My makeshift paint booth was up for about 6 weeks, and at the end I was re-taping plastic every couple days, as the original duct tape slowly failed. My buddy Steve took a day off on the last 70-degree day of the year to shoot the color for me.
    By the way, it turns out you can have too much airflow. Had to shut one of the blowers down when shooting color. Another tip is that it’s OK to cover wheels and such with plastic when shooting primer that you will sand. But when it’s time for color it's better to use canvas, because paint can bounce off plastic and back into your fresh-laid paint. This is only an issue if you have a situtation like mine where the surface of the open wheels face the surface of the body.
  7. Ulu
    Ulu
    from CenCal
    I have a stainless electric rotisserie I use to cook chicken on my BBQ. What you got there is a rollover fixture on trunnions.
    One of my first engineering jobs was to design some big hydraulic ones ones to roll over a piece of heavy construction equipment as the counter weights were being welded into the ch***is. It was very substantial and it had to handle tons of weight.
    I will probably end up building a roll over to do the body welding on my old Plymouth, but it will not be a permanent welded ***embly.
    It will be bolted up and I'll design it so that it can be dis***embled when I'm done with the thing.
  8. lowcoe
    lowcoe
    Thought i was final sanding the primer coat when I decided the fenders needed to be wider so I could turn the fat wheels, one step forward, two back.....[​IMG][​IMG][​IMG]
  9. Blue One
    Blue One
    from Alberta
    Since I started this thread, here's the paint booth that I built in my garage.
    IMG_0913.JPG IMG_0915.JPG IMG_0919.JPG IMG_0920.JPG IMG_0921.JPG IMG_0924.JPG IMG_0925.JPG IMG_0926.JPG IMG_0927.JPG IMG_0928.JPG IMG_0930.JPG
  10. Blue One
    Blue One
    from Alberta
    And some of the results of using it.
    IMG_0971.JPG IMG_0973.JPG IMG_0975.JPG IMG_0987.JPG IMG_0990.JPG IMG_0991.JPG IMG_1023.JPG IMG_1030.JPG IMG_1031.JPG IMG_1036.JPG IMG_1039.JPG IMG_1042.JPG IMG_1045.JPG IMG_1046.JPG IMG_1048.JPG IMG_1049.JPG IMG_1050.JPG IMG_1052.JPG IMG_1153.JPG IMG_1154.JPG IMG_1156.JPG IMG_1158.JPG IMG_1159.JPG IMG_1161.JPG IMG_1163.JPG IMG_1164.JPG IMG_1169.JPG IMG_1170.JPG IMG_1180.JPG IMG_1181.JPG
    Tow Truck Tom, D-Russ, 32Dan and 11 others like this.
  11. Blue One
    Blue One
    from Alberta
    And finally, the remains of the booth when it was all done. :cool:
  12. Blue One
    Blue One
    from Alberta
    Anyone else doing any painting ?
  13. TagMan
    TagMan
    No painting, but my arms are sore from sanding fenders, doors, etc. in the driveway. I love forming & installing patch panels, but this grunt work ****s !!
    lowcoe, JOYFLEA and loudbang like this.
  14. K13
    K13
    I guess I should post some of my pictures. :D All painted in my garage. Slowly going back together now.
  15. 270ci
    270ci
    Sprayed in the garage....
    Then cured using an efficient solar oven.
    gotit, JOYFLEA, brad2v and 2 others like this.
  16. luckys8ba
    luckys8ba
  17. greaser 35
    greaser 35
    from FRANCE
  18. brad2v
    brad2v
    51box and loudbang like this.
  19. deathrowdave
    deathrowdave
    from NKy
    This was an outside driveway print job . 25 years ago . I could not afford to pay to have it painted . So could or bad I did it and it is good enough for me .
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I did my pickup in my back yard. It is the LAST paint job I will do that way. From now on I will rent a booth. Today's paint - in this case two-tone with a clear coat, are just too complicated to do in one day, which I tried to do. Looks OK from twenty, but has lots of minor flaws.
    46trk07bondo.jpg 46trkbodypaint01_1.jpg 46trkbodypaint02_2.jpg 46trkbonnet03_3.jpg 46trkhood01_4.jpg 46trkhood02_5.jpg ins08.jpg USAC 02.jpg
    The checkerboard / flame job was done on a previous day. ins02.jpg
    Tow Truck Tom, AHotRod, Ulu and 4 others like this.
  21. Can you expand upon what we are seeing in that first picture?
  22. loudbang likes this.
  23. oldrelics
    oldrelics
    from Calgary
    I'm wondering too, spread body filler with a mortar trowel?
  24. Dick Stevens
    Dick Stevens
    Appears he is sanding the top with a longboard to get it just right before spraying color! :)
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yes, that is correct. I use a long piece of plywood. I cut apart a sanding belt from a belt sander, wrapped it around the ends and affixed it to the board. I use a set of mold sweeps to get the curvature consistent. O/T, but I used two roofs for the 3" top, with only one seam across the top.
    As far as the troweled on bondo, I like to do the first coat like that so subsequent coats will show when sanding them down I am nearing the original surface of the metal. It helps me gage the thickness of the bondo applied.
    Also O/T, the cycle-tank-turned-air-cleaner was rescued from hurricane Wilma debris and striped using a carpenters laser level, as was the inside of the hood.
    Tow Truck Tom and loudbang like this.
  26. Man... this is cool. How much do you think the booth cost you for everything?
  27. thirty5window
    thirty5window
    from Colorado
    Hanging plastic and wetting the floor keeps the dust low. This is single stage PPG.
    D-Russ, AHotRod, Ulu and 9 others like this.
  28. Blue One
    Blue One
    from Alberta
    The lumber and plastic was about $200 and the 12" vent fan was $120 and 25' hose was $70.
    I spent another $100 on a 10' x 16' canvas tarp for the floor.
    I didn't use a cheaper poly tarp on the floor because of the static factor.
    The booth wasn't big enough for a full sized car at 15'x 9' x 80" tall, but it did the trick nicely for my RPU painted in pieces.
  29. mgermca
    mgermca
    Top to bottom of this page, NICE WORK GUYS!
    RockinRivi, loudbang and brad2v like this.
