Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. rottenleonard
    rottenleonard
    I recently came up with a running and model A ch***is, not really sure what I had planned for it I put together some of the pieces that I had laying around. I formed up this Model A Roadster pickup, and really it just didn't do anything for me.
    In truth I probably should have just went forward with it after all was just a flip project, but I prefer to just let my mind wander little bit and make a project that I was actually excited about. So I extracted all the drivetrain running gear from the model A ch***is. And set the frame out against the fence. After I had all the pieces on the ch***is table and mocked up I came up with a perimeter frame that resembles a Lakes modified made from 1 inch square tubing. The Late Model Model A Grill shell was just too tall so I swapped it out for a 28 29 Grill shell and radiator.
    To really do this right I needed to get my English Wheel Parts out of the attic that I have had for probably over 10 years and never fabricated the pieces to use them.
    First few attempts at metal shaping on the Wheel.
  2. brett4christ
    brett4christ
    I'll bite! Subscribed!!!!
  3. rottenleonard
    rottenleonard
    Design and mockup of parts using .060 aluminum. Cut a piece, fold it up and learn what you need to, adjust the CAD drawing and cut another....makes for interesting s****
    IMG_20170922_081503_896.jpg IMG_20170922_081503_895.jpg IMG_20170922_080502.jpg
  4. rottenleonard
    rottenleonard
  5. rottenleonard
    rottenleonard
    The Mockup pieces including standins for the friction shocks, through the welded front spring hanger.
  6. Ebbsspeed
    Ebbsspeed
    Subscribed. Interesting approach, and the workmanship looks great so far.
  7. fiftyv8
    fiftyv8
    from CO & WA
    I'm in, nice to see someone thinking outside the box so to speak...
  8. Fabber McGee
    Fabber McGee
    I'm signed on for the adventure. I'm enjoying this approach.
  9. rottenleonard
    rottenleonard
    After a good sit and stare i decided that the side wings where I was at attatching my support struts was going to cause an issue with flexing and would require a ton of gusseting to make it work, therefore I decided to cut off those wings and attach my cross support structure differently.
    Plasma cut out some pockets in the back side.
    Cut out some brackets for the struts that would allow tge front structure to be removed from the motor plate.
    Bent 2 sides of a triangle from 1" x .125" for the support struts.
    While i think we are getting to where it will work I think I will keep thinking of a more elegant design.
  10. rottenleonard
    rottenleonard
    Next step I built a substructure in side of the body to transfer the forces from the rear suspension to the front, I built these weld plates that bolt in at the motor plate so that the firewall/motor plate is still removable.
    The upper holes shown above will go through tubes which will sandwich the throttle bracket and into the block for a little extra support.
    If you can look through the Maze of square tubing you can kind of see how it is shaping up.
    This is a shot of how the rear spring will be supported. The gas tank will Mount above it and there will be a gusset to tie the top of the body into the substructure.
    The rear suspension is triangulated into the floor ***embly and this transfers up to the transmission and this is how it will tie into the back of the transmission.
    All of the holes in the gussets are for rosette welds.
    Lil'Alb, Runnin shine, brEad and 6 others like this.
  11. tfeverfred
    tfeverfred
    Looks good!
    kidcampbell71 likes this.
  12. 40ply
    40ply
    Impressive! I'm in.
  13. King ford
    King ford
    from 08302
    Super trick Leonard! I take it you are going to weld a steel " skin" over the structural skeleton to add some additional rigidity?
  14. rottenleonard
    rottenleonard
    Thanks fellas,
    It will be on the bottom but around the outside the body work will be screwed on heavily, and there will be an inner skin also.
    Here is how the rear spring is shaping up. I ditched every other leaf as a starting point. 20171007_141842.jpg
  15. rottenleonard
    rottenleonard
    Working on the steering a little I found that the stock tie rods would nearly p*** above the spring, and at full lock left no room for a cooling fan.
    Back to the sit and stare
    Turned the whole ***embly upside down, this cured the spring clearance issue but required cutting off the drag link arm.
    To fix the fan clearance issue, I turned these inch and 3/4 spacers to go between the tie rod arm and the spindle. I machine them to an interference fit.
    I cut the threads off the original steering arm
    I probably got a little bit greedy with the interference fit and nearly didn't get them drove all the way on, but finally got them driven home.
    DylanHill1931, Stogy and AHotRod like this.
  16. too many fords
    too many fords
    from Las Vegas
    I have no idea what's going on here,but I can't look away o_O
    eddie1, pitman, Frankie47 and 10 others like this.
  17. kadillackid
    kadillackid
    I'm in for this party....impressive work Rottenleonard :cool:
  18. fiftyv8
    fiftyv8
    from CO & WA
    What is the reason/s why this style of build is being done.
    Cos you can or are you trying to save weight or whatever???
    I'm just trying to understand your philosophy behind it.
  19. gnichols
    gnichols
    from Tampa, FL
    A Lotus 7 of hot rods? Sure looks interesting, and it should be very light, eh? I'm in! Gary
  20. vtwhead
    vtwhead
    Dam impressive work! This will be awesome. I'm tagging along....
  21. RidgeRunner
    RidgeRunner
    from Western MA
    Along about post #10 Type 61 "Birdcage" Masaratti [sp?] from back in the day came to mind. Homemade cookie without the cutter, love the concept! Will be following for sure.
    Ed
  22. rottenleonard
    rottenleonard
    Thank you!
    In part it is to make a light car, 40 hp will start to feel like something in a 1000lb car. Also i can make it relatively low without sacrificing leg room. And a good portion of it is what I like to call daydreaming in metal, it's in my head looks like fun...I want to drive it.
    Thanks!
  23. rottenleonard
    rottenleonard
    20171009_150734.jpg the arms after tign on the extensions. The model a's use a square shoulder to keep them from spinning, this required a little additive manufacturing.
    20171009_153128.jpg and work with the hand held milling machine.
    20171009_154147.jpg 20171009_155502.jpg clearance at full lock looks much better
    20171009_155828.jpg clears the crank pulley when centered.
    Runnin shine, brEad, kiwijeff and 5 others like this.
  24. fiftyv8
    fiftyv8
    from CO & WA
    Great work and thanks for sharing your thoughts.
  25. Atwater Mike
    Atwater Mike
    What happened to the KPI when reversing the spindles? Did you bend the axle near the king pin bosses?
    Superb machining and welding...
    Unkl Ian likes this.
  26. rottenleonard
    rottenleonard
    Actually i just changed the steering arms side to side and upside down, the spindled are still in their stock location.
    Atwater Mike likes this.
  27. AHotRod
    AHotRod
    Excellent craftsmanship and vision
    rottenleonard likes this.
  28. flynbrian48
    flynbrian48
    Wow. I feel like such a hack. ;-)
  29. gnichols
    gnichols
    from Tampa, FL
    I'm sorry to say I can't remember the fellow's name, but a very similar car was recently built down under (light green roadster). It was an amazing build, and you might get some tips from him. Anyone help with the link to the HAMB build files? Gary
  30. rottenleonard
    rottenleonard
    I would like to see it for sure.
