Technical 1948 CHEVROLET TRUCK 3/4 TON GAS TANK
Discussion in 'The Hokey Ass Message Board' started by 1965CHPCSP, Sep 24, 2017.
  1. 1965CHPCSP
    1965CHPCSP
    I have a buddy who is restoring his grandpa's old farm 1948 Chevrolet 3/4 Ton Truck and is in need of an original gas tank. The tank on the 3/4 ton trucks mounted under the front side of the bed on the p***enger side. He's having a hell of a time finding an original or replacement tank. Any help or pointed in the right direction would be much appreciated.
    Thanks
  2. scrubby2009
    scrubby2009
    A picture, as the saying goes, would be worth a lot of typing... Does the 1/2 ton model that Chev's of the '40's sell come close?
    1965CHPCSP likes this.
  3. 1965CHPCSP
    1965CHPCSP
    The tank is missing. I believe the 1/2 tons were behind the seat in the cab and the 3/4 ton tank was under the bed. Thin and narrow to run along frame rails. No photos to share at the moment.
  4. round2it
    round2it
    from duvall wa
    check out brothers truck parts. they show a tank for a '48 pickup & suburban that is the same for a 3/4 ton.
    Also check out All American Cl***ic in Vancouver WA. they may have mounting brackets & straps.
  5. aerocolor
    aerocolor
    from dayton
    '47-'48 1/2 ton tanks were inside the right frame rail in front of the rear axle.
    Never seen an aftermarket tank.
    Shouldn't be too tough to fab.
    It is a tight fit between the driveshaft tube and frame.
    That's why most aren't reused.
  6. jcmarz
    jcmarz
    from Chino, Ca
    Going, Going, WRONG!
    The AD trucks, 47-48, had the gas tank under the bed, with the filler neck on the p***enger side. This includes 1/2 tons, so that replacement tank from Chevs of the 40s will work on the 3/4 ton. In 1949, the gas tank was moved from under the bed to inside the cab.
    Sent from my SM-J700T1 using The H.A.M.B. mobile app
  7. Steve 48 3/4 ton
    Steve 48 3/4 ton
    TOTALLY WRONG Chevys of the 40's does not have a tank that will fit a 1948 Chevrolet 3/4 ton truck, but they still sold me one for $480. Tank that they sent me and the original tank that came with the truck. 20190529_141042.jpeg 20190529_181051.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  8. Steve 48 3/4 ton
    Steve 48 3/4 ton
    What are owners of 1948 Chevrolet 3/4 ton trucks using for replacement gas tanks? And still trying to keep it as original as possible?
  9. chopped
    chopped
    Boat tanks come in a lot of shapes and sizes. Maybe?
    Steve 48 3/4 ton likes this.
  10. tb33anda3rd
    tb33anda3rd
    the tank shape looks a lot like the tanks that came in 37-47 chevy trucks but with a different filler neck location. 20190529_181051.jpeg
  11. tb33anda3rd
    tb33anda3rd
  12. MO54Frank
    MO54Frank
  13. rusty1
    rusty1
    ...you mite try the TANKS website for something else that would work;...3/4 ton Chevs have a narrower frame aft the cab than 1/2 tons in those years....or you could put one in the cab behind the seat...
  14. 41rodderz
    41rodderz
    from Oregon
    My buddy has a 1952 Chevy 3/4 ton and got one from Tanks that he mounted in the rear.
