Projects 65 comet fx build
Discussion in 'Traditional Hot Rods' started by rocketsled59, Aug 14, 2017.
  1. rocketsled59
    rocketsled59
    by god she's white. Time for a few beers. Boys chemo this weekend. Tmrw it's all about my boy and my responsibilities Peace out
    loudbang and saltflats like this.
  2. Mike Colemire
    Mike Colemire
    Sorry to hear about your boy, prayers sent. Car is looking good.
  3. bonlesshotdog25
    bonlesshotdog25
  4. bonlesshotdog25
    bonlesshotdog25
    Rocket sure makes the **** look good car takes some big jumps to the finish line with him on board
    loudbang, saltflats and rocketsled59 like this.
  5. rocketsled59
    rocketsled59
    Easy killer , I've been known to fall outta the boat too
    loudbang, Tickety Boo and saltflats like this.
  6. rocketsled59
    rocketsled59
    Thanks for the thoughts. Much appreciated
  7. rocketsled59
    rocketsled59
    IMG_0596.JPG Gotta get this thing outta my paint room.
  8. rocketsled59
    rocketsled59
    Nothin up my sleeve... presto!! Now patch a 57 Chevy door and then back up to the hospital He's coming home tmrw!
  9. lostone
    lostone
    from kansas
    Looking good! And my prayers go out for your son.
    loudbang, rocketsled59 and enloe like this.
  10. saltflats
    saltflats
    from Missouri
    Nice work......And prayers sent for your son and family.
  11. Hot Rod Dan
    Hot Rod Dan
    from Texas
    I like the color combo. Praying for healing for your family.
    loudbang and rocketsled59 like this.
  12. rocketsled59
    rocketsled59
    Thanks guys.
  13. rocketsled59
    rocketsled59
    Would like to pick some brains if I can. Salty this be right up your alley. Our plans are a 357" Windsor 12:1 with a c4. Flotek 180 cc aluminum heads. Victor jr and a 650. The plan was a flat tappet cam but he has showed interest in a roller. It's a 78 block. That's gonna be expensive. Plus the heads are set up for .550 lift. I don't see where it's going to have enough benefit for the loot. Am I thinking right??
  14. saltflats
    saltflats
    from Missouri
    Do you give cl***es in this?
    You sure have made short order of this.
    I need to bring the Salt Shaker to you and have the lowers redone.
    I have been looking at it (not that I would know what I am looking at) and think it could be pulled off without gettin into the lettering.
  15. saltflats
    saltflats
    from Missouri
    You will want to have the springs checked for either cam.
    The roller is a big hit on the wallet but you can free up some H/P and more torque.
    A solid flat tappet would work good and be a good stepping stone for a new driver and leave money for a helmet and seat-belts maybe even a jacket.
    When you order a cam if flat tappet have it nitrated.
  16. rocketsled59
    rocketsled59
    I only give one short lesson in body and paint... RUN! FIND A REAL JOB!! That's for the young guys. If we were a little closer I'd come look at it
  17. rocketsled59
    rocketsled59
    That's right where my mind was when we started this plan. Does someone other than comp nitride cams? Does this eliminate the god forsaken break in? What a pain in the ***
  18. saltflats
    saltflats
    from Missouri
    Its a big help.
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    The most power comes from the best head air flow you can afford, then play catch up with the rest of the motor later.
    This would be a good time for Scott to chime in.:rolleyes:
    loudbang, rocketsled59 and BBC Cobra like this.
  20. Doctorterry
    Doctorterry
    I love the paint scheme! Wish I could move faster on my project, but this gets me excited!
    Praying for your son! I pray for healing for him!
  21. rawcjw19
    rawcjw19
    Nice build. You guys said you drink some beer, but man you sure get a lot done! My boy is still collecting parts for his , but we should be starting on it soon. Praying your son. Cancer does ****!
  22. rocketsled59
    rocketsled59
    Thanks so much for your thoughts. It means a lot! Yeah we're makin big strides but it's gonna slow down cause ****s getting ready to get pricey. Hot dog needs something to ogle over to keep his interest. If we left it lookin like an all day train wreck his enthusiasm would dwindle faster than his bankroll
  23. 48fordnut
    48fordnut
    The roller cam offers big benefits. It is expensive to put in a 351 block. Your block is thinner than the 69 73 blocks. I made 645 hp with a flat tappet cam in a 351.
    Just break it in right. No crank, crank and not firing. Start right up so the lube does not get wiped off the cam.20 25 min at 2k rpm to break the cam ,oil, filter change reset valves and you are good to go.
  24. Tickety Boo
    Tickety Boo
    from Wisconsin
    Could you tell us what heads and cam that are you using on the 645 hp build?
  25. 48fordnut
    48fordnut
    The heads were TFS ,one of the first sets they made. Ported by Powered By Ford in Orlando. Used a super victor intake port matched. Heads ,cam and intake are what make hp/. I was using a comp cams cam ,don't remember the grind. This was at 7500 rpm .It was still climbing but we decided to shut it down.
  26. rocketsled59
    rocketsled59
    IMG_0609.JPG IMG_0612.JPG Ok. Need to do decklid and lettering ... and a ton of other shirt
  27. I think you're kinda limiting yourself with the carb. Big heads, big valves, big cam, big intake, and not so big of a carb.
    I'd suggest a 750 vacuum secondaries. With a 3500 converter and 4.10's , you can make it leave cleaner and harder by playing with the sec. spring.
  28. rocketsled59
    rocketsled59
    IMG_0627.JPG IMG_0628.JPG IMG_0629.JPG Been playing around with the brush.
  29. 38Chevy454
    38Chevy454
    Great work so far! Like the paint scheme you have done. Is much street driving planned? If so, 12:1 may require some expensive higher octane gas than pump premium. Or E85 as an alternative to get the octane. If staying pump gas (really the E10 that comes out of pump), you may want to consider lowering compression. It will take some of the snap and power out, but its all a trade.
  30. rocketsled59
    rocketsled59
    Strip only. Except for the holeshots on the country road in front of the ranch. And the lightly traveled two lane that led to the coal mine that's defunct. Kindly referred to as " macoupin county dragway". Less than a mile from me !!
