Hot Rods Y block ford to early 3 speed adapter
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Sep 25, 2017.
  1. Kiwi 4d
    Kiwi 4d
    Ok. Have had a Mcbar brand y block to flathead 3 speed in the corner for 10 yrs . And now was the time to use it.So you can see by the pics we have a y block to flathead adapter bolted to a flathead to T5 adapter length and look good. The Mcbar adapter has never been used , threaded transmission holes but starter holes never threaded.
    I am very uncomfortable with the starter mount face , it should be flat but has machined lows and un tapped threads plus recessed portions. We are using a power master gear reduction startet .
    In the end I think we will look for another adaptet. Any leads much appreciated on a Y block to early flathead 3 speed adapter appreciated.
    Have surfed a little and come up empty. 20170926_165116.jpg 20170926_171131.jpg
  2. squirrel
    Looks like the adapter has witness marks from a stock starter having been bolted to it (and probably run for a while). Probably had a bolt and nut on the bottom hole?
    They were low precision setups....
  3. Kiwi 4d
    Kiwi 4d
    I don't think so but again anything is possible. good spotting though. The bottom hole appears more like poor casting with a burr on the side , and sitting in a recess where it should be flat all around, though its been sitting a long time it is still possible the recesses are in fact wear from a sloppy fit starter with 5/16 bolts where 3/8 threaded fittings are required to match the starter. As you said low precision ,so really i doubt this adapter will be up to the job.The transmission to adapter holes were threaded but the adapter to starter were unthreaded . I started one blank hole to tap till i realised the face was off. The face should be flat as i see it ,not with the high and low spots.
  4. 26 T Ford RPU
    26 T Ford RPU
    Have you tried Graham Berry? Im sure they made them and may have something still. Worth a shot. JW
  5. prez
    prez
    Ive got a B/C housing fellers
    Talked to Grahame about it
    He cant remember making them ....
    Kiwi 4d and 26 T Ford RPU like this.
  6. 57Custom300
    57Custom300
    from Arizona
    The recess shown is exactly how a stock Yblock bellhousing/convertor housing is made. A stock yblock starter fits into the recess and the ears of the starter fit flush against the outer part of the housing. Bolt holes are a little confusing. 5/16 bolts usually fit there.
  7. squirrel
    yeah, 5/16" bolts on those 3 bolt Ford starters.
    If you can't see the witness marks...huh....they're very obvious to me, in your photo.
    Kiwi 4d likes this.
  8. Kiwi 4d
    Kiwi 4d
    As usual squirrel your vast knowledge proves correct. I didnt check the threads on the old steel bellhousing which are infact 5/16. I just looked at the new power master starter and 3/8 fitted the holes perfect. I couldnt tell from my old starter as one ear was missing and the other holes ovaled , but in fairness it worked fine for us over 13yrs of driving and we had no issues in starting so didnt know we were close to failure.
