Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Fitted...Getting a bunch ready for weld so I can clean My "welding table" and get comfy later
    Mock Up - Thinking of "forging" a bracket & use Existing Bolts.
    Running Lights / Horns will be mounted higher up - inside the hoop.
    Wifey said "Too High"...Good Taste!
    As Low as it can go.
    ~2inches clearance at the closest point...(Can't turn the wheels with the 2x4's)
    I'll Slide it in 1/2 inch forward 1/2 inch...Should be 3+...?
    8:33pm - My Wife on the way out the door says "Do You need anything from O'Riley's?".......Me "Nope!"
    Wait Now - Did She Just Say What?.....................................
    .....................................She's Cool!
    '52 F-3 and AndersF like this.
  2. 340HilbornDuster
    340HilbornDuster
    Welding Table "restored"
    20170610_132445 (Medium).jpg Exploding Cutting Disk and Shorts
    20170610_162036 (Medium).jpg Tacked Nuts 20170610_163612 (Medium).jpg Piclup Hose Trimmed (slight tension so it doesn't rattle)
    Two Down - ONE 1/2 to go!....Lucky it's a long weekend...(Kamehameha Day)
    biggeorge, '52 F-3 and AndersF like this.
  3. 340HilbornDuster
    340HilbornDuster
    20170611_154710 (Medium).jpg Two small pinholes! easy fix!...
    Fricken Sending unit flange is crooked!!!...leakes like a siv! - Not Happy!
    Battery Boxes arrived today...fit's like a glove! - Happy again!
  4. '52 F-3
    '52 F-3
    from Central PA
    nice welding table, I like the grounded vise........... good idea
  5. 340HilbornDuster
    340HilbornDuster
    biggeorge and AndersF like this.
  6. 340HilbornDuster
    340HilbornDuster
  7. 340HilbornDuster
    340HilbornDuster
    Tank Bracket - will be welded to roll hoop with Tabs. Padding on the tank up against the seat back + Straps or Belts will hold tank "in place".
    When I built the sub-frame i started with steel strips bolted to the frame nuts...
    Holes are exactly the same size as bolts....(Some off by / 1/16 inch!)
    20170621_191721 (Medium).jpg Tried to finagle the frame in to place...No work.
    I'll have to lift up the body and enlarge the holes a bit....3/16" bigger.
    Dash board mock up -
    AndersF and Russ B like this.
  8. 340HilbornDuster
    340HilbornDuster
  9. 340HilbornDuster
    340HilbornDuster
    Hand Brake Brackets.
    20170708_172017 (Medium).jpg 20170710_185951 (Medium).jpg 20170710_191605 (Medium).jpg
    patmanta and AndersF like this.
  10. 340HilbornDuster
    340HilbornDuster
    20170721_183049 (Medium).jpg 20170721_183907 (Medium).jpg 20170721_185239 (Medium).jpg
    Matches the Cowl Curve in the back...
    Dannerr and AndersF like this.
  11. 340HilbornDuster
    340HilbornDuster
    I was going to do another pie cut on the bottom to remove the peak.
    Instead I tacked the center & hammered and dollied the double edge straight
    and the bottom edge B4 I finish welded it.
    tomkelly88 and Dannerr like this.
  12. 340HilbornDuster
    340HilbornDuster
    Vacations over ... back to work!
    Model A Bucket Bracket - remove the spring and cut out the "hump"
    Graft Model A "Swivel Humps" on the Pacard Buckets...
    20170924_172522 (Medium).jpg 20170924_172537 (Medium).jpg 20170924_175924 (Medium).jpg Now i can work on the light bracket... 20170924_185550 (Medium).jpg
    kiwijeff, patmanta and AndersF like this.
  13. 340HilbornDuster
    340HilbornDuster
    Rear brackets...attached to shock bolts
    Some bending +
    Another support will go forward and hold a cross bar for horns and fog-lights.
    AndersF likes this.
  14. 340HilbornDuster
    340HilbornDuster
    20171001_151041 (Medium).jpg 20171001_155941 (Medium).jpg 20171001_172612 (Medium).jpg 20171001_172910 (Medium).jpg
    They're a little off....can't tell when it's on...gives it character!
    20171001_181740 (Medium).jpg They were even...still needed a 1/4" adjustment/
    20171001_184221 (Medium).jpg They're Solid & No more holes in my painted frame! 20171001_184701 (Medium).jpg
  15. Murocmaru
    Murocmaru
    from Van Nuys
    I've been following this thread for a while and it's really coming along great! Thanks for the comment on my stanchions, they aren't hard to make, just time consuming.
    How much did you chop your windshield?
  16. 340HilbornDuster
    340HilbornDuster
    The "replacement lenses" are so shallow that,
    Even though there slightly recessed in the bucket
    the bulbs still stick out past the Gl*** Lens!
    32 Packard Gl*** lenses are Straight!
  17. 340HilbornDuster
    340HilbornDuster
    Trying to find SHORT 9007 Halogen Bulbs...
    ANY IDEAS?
    Not too keen on LED's (they're shorter ~1/2")
    may be the only solution....FOR NOW?
    - Not sure i can use 'em? - LED lights not listed...!
    Hawaii §286-26.5
  18. 340HilbornDuster
    340HilbornDuster
    biggeorge, Dannerr and AndersF like this.
  19. 340HilbornDuster
    340HilbornDuster
  20. 340HilbornDuster
    340HilbornDuster
    Ran out of Acetylene at the last bend!! Phew!
    Biggest problem is to get it all aligned, level, straight, flush.... 20171013_194334 (Medium).jpg All tacked in place... 20171013_205159 (Medium).jpg
    May have to stick "a sock" in the horns if it's raining...
    Soldered new wires to to the bulb centers.
    Found Amber W97's on the web!! All yellow will look good!
    Dannerr, AndersF and biggeorge like this.
  21. 340HilbornDuster
    340HilbornDuster
  22. AndersF
    AndersF
    Nice to see some progress again.
  23. 340HilbornDuster
    340HilbornDuster
    Hi Anders...
    I agree with you Man....
    Sometimes Life throws a bunch "other things" in the mix that you gotta do...
    Dannerr likes this.
  24. 340HilbornDuster
    340HilbornDuster
  25. 340HilbornDuster
    340HilbornDuster
    Had to make "hand cuffs" to hold the locks in place...(bad groves) other than that they're good lights.
    Sent from my SM-G930T using The H.A.M.B. mobile app
  26. 340HilbornDuster
    340HilbornDuster
    Wifey help me polish last night.
    They look awesome...some small dents here and there....character!
    biggeorge, AndersF and The 39 guy like this.
  27. 340HilbornDuster
    340HilbornDuster
    Strain relief - (can't find one, make one!)
    20171101_181421 (Medium).jpg Cork gaskets from Steve Frisbee - Mahalo
    20171101_182526 (Medium).jpg Installed
    If these lights were perfect...couldn't do all this **** to 'em...and couldn't afford 'em...perfect!
    Headlights Not aligned yet -
    Just gotta paint the horns and put'em on.
  28. 340HilbornDuster
    340HilbornDuster
    20171102_193130 (Medium).jpg watching paint dry?...watching paint stripper is always strangely entertaining...!
    Look - I dunno....Good for now?
    20171103_151928 (Medium).jpg The wires go through the original bolt hole...
  29. 340HilbornDuster
    340HilbornDuster
    Rub nuts
    The VW guys doesn't ship to Hawaii ... so i made my own "cable shortening kit"
  30. 340HilbornDuster
    340HilbornDuster
    bct likes this.
