Technical Any Weekend Goals?
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Feb 25, 2017.
  1. ct1932ford
    ct1932ford
    Saturday!
    Sunday
    Lime rock 8th Annual Royals Garage Car Show
  2. Fordgasser1
    Fordgasser1
    from Jersey
    wheeldog57 likes this.
  3. bobss396
    bobss396
    Still having the monsoon thing going on... and a 4-day weekend coming up. My hood will come out of the acid bath on Friday and I'll ***ess what is next, but would like to get the T-Bolt scoop at least bonded on. May try to get my door weatherstrip on if I can find a helper (free lunch...). Going with my buddy to the machine shop on Saturday to drop off his LS engine.
  4. The37Kid
    The37Kid
    Try to accomplish last weekend's goal, watch the INDY 500, remember the true meaning of Memorial Day. Bob
  5. wheeldog57
    wheeldog57
    48fordnut likes this.
  6. blackout78666
    blackout78666
    Just got to meet and shoot the **** with 1/shot, member here in the board just outside of Dallas Tx. Hella cool guy and help with some puzzle pieces on my sprint car project. Thanks Frank!!! Next time your turn at my place.
  7. Racer29
    Racer29
    Run through the hills just not sure which car. Black Hills National Cemetery on Monday for Memorial Day ceremony.
    Sent from my A520L using The H.A.M.B. mobile app
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Finish weld the stainless exhaust, paint the firewall and put the body back on the frame. Glad it's a 3 day'er.....
  9. dirt t
    dirt t
    Car show today on 66 down town Kingman.
  10. Gene Boul
    Gene Boul
    38 Standards are nice. I did it my way! See mine below (actually in front of sons bar) IMG_0895.jpg
    bobss396 and scrap metal 48 like this.
  11. hemiboy
    hemiboy
    Actually got the cars out of the garage, 91 degrees and sunny! Tomorrow finish cab mounts for the '40 pickup. So much better than 4 feet of snow.....
  12. Koz
    Koz
    Trying to get my front suicide perch plotted for the proper ride height and the parts made. I've been putting this off for a while now. Definitly a "high risk/high reward" project.......
  13. bobss396
    bobss396
    Friday was warm and I got a lot of my hood prep done. Saturday I fibergl***ed the inside support where it rusted through, looks strong. The T-Bolt scoop is on, bonded and pop riveted in place using countersunk rivets.
  14. Racer29
    Racer29
    No car goals other than driving it. My son and I are heading to the hills this afternoon in the '29 after work to do some camping for Father's Day. Then Sunday afternoon between Church there's some sort of hot rod show in the Hills. We'll head to that also.
  15. bobss396
    bobss396
    Clean the car out and vacuum it, getting bad. I have a pull to the right issue, need to make sure my a-arms are tight and check a few other things. I may change the oil too. But I'm working on my yard and patio, trying to get that right before it gets roasting hot.
  16. gimpyshotrods
    gimpyshotrods
    I will have to see just how hot it is. Temperatures are expected to be 20º-25º above normal.
    I have some work to do on a tail light surround, and a wheel arch on the Falcon. Full-leather welding gear in 100º heat does not seem wise.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Going to the L.A. fathers Day Car Show tomorrow.
    The one on the east coast...The Lower Anderson Car Show! :D HRP
    Racer29 likes this.
  18. typo41
    typo41
    HRP. sorry I had hoped to meet you this weekend, before I melt in the expected heat wave of 110 degrees
    This will be our first Roadster show with a roadster
  19. Chavezk21
    Chavezk21
    Going to work on the coupe this weekend. Gonna do some finish welding, get door tops and b pillars tacked in.
  20. Cliff Ramsdell
    Cliff Ramsdell
    Well, after a few months out of the garage because of demands of the house and family through the summer months I was able to get back into the garage today.
    I had gotten quite a bit done with the car but never got it back on the road this year, yet.
    Today I ****ed it up and chopped the top 3", I got it off, cleaned up and set back on with most of the s***ch work done. Ran out of .030 wire for the welder.
    Before, after and a rear 3/4 shot.
    Cliff Ramsdell
  21. UNSHINED 2
    UNSHINED 2
    Good job --- nice look
  22. Cliff Ramsdell
    Cliff Ramsdell
    Got the top stiched together and working on the doors. Both are hung and the tops welded back on.
    Got some welding and grinding left and then a skim coat. Maybe prime and paint soon.
    Cliff Ramsdell
    chop job and chryslerfan55 like this.
  23. Crankhole
    Crankhole
    I unsuccessfully tried to get my Model A banger to stop leaking from that damn hole used to hold the oil pump in place. I'm considering filling the hole with JB Weld. Someone please talk me into it.
  24. bobss396
    bobss396
    Spent the summer driving the Ford with small issues here and there, brake light switch, solenoid on the firewall. All new parts that were ****, from Napa. My front end pull was a loose lower control arm. I had tightened up the one side when the wheels were hanging, a mistake.
    Next up is to finish the door seals. The p***enger side is in. Need to do the driver side. It should make the car quieter inside and cut down the drafts.
  25. chop job
    chop job
    from Wisconsin
    Cliff Ramsdell likes this.
  26. car doctor
    car doctor
    Took the Willy's all back apart so I can finish body work and paint everything. 14894509641931588976588.jpg IMG_20171029_094415.jpg IMG_20171029_115533.jpg IMG_20171029_115739.jpg Just finished painting the frame this weekend.
    Cliff Ramsdell and chop job like this.
