Projects 5wKy33: another coupe build thread
Discussion in 'Traditional Hot Rods' started by ls1yj, Jan 15, 2017.
  1. ls1yj
    ls1yj
    from Kentucky
    Thanks HiVolt5.0
  2. brEad
    brEad
    I'm with @Hivolt5.0 - looking good. You did a great job on the driver side window. I always find getting the second one to match the first makes that one more difficult. Carry on, we'll be following.
    loudbang and ls1yj like this.
  3. Perfecting that last 10% takes 90% of the time. Looking really nice
    loudbang, ls1yj and brEad like this.
  4. ls1yj
    ls1yj
    from Kentucky
  5. ls1yj
    ls1yj
    from Kentucky
    akoutlaw and loudbang like this.
  6. ls1yj
    ls1yj
    from Kentucky
    BrEad,
    Thanks... Ive seen a bunch of chopped coupes, and the quarter windows generally are out of proportion to the originals... most have a kink, or wrong radius... they don't look bad, but they also don't look much like original shape... I'm trying hard to keep all the windows flowing nicely
  7. brEad
    brEad
    Your attention to detail is what will make the difference between mediocre and excellent. Thanks for sharing your build.
    craig b blue, loudbang and ls1yj like this.
  8. fuel10922
    fuel10922
    ls1yj likes this.
  9. ls1yj
    ls1yj
    from Kentucky
    Come on over! Not much to look at yet, but you are welcome all the same!
  10. curbspeed
    curbspeed
    Enjoyable speaking with you today Trey. I will flag this build and follow along. Looks like you have the makings of a good car there. Cheers. Oh. and let me know what you need for Caddy speed equipment. Maybe I can convince my guy to come off some of it.
    Outback and ls1yj like this.
  11. ls1yj
    ls1yj
    from Kentucky
    Got a little bit more done... welded seam above rear window, and started filling in over p*** side quarter window...
    Sent from my iPhone using H.A.M.B.[​IMG][​IMG]
    Outback, akoutlaw, brEad and 2 others like this.
  12. ls1yj
    ls1yj
    from Kentucky
  13. ls1yj
    ls1yj
    from Kentucky
    [​IMG][​IMG]
    Got the front section welded on, and started working metal around joined areas...
    Looking for some A pillars, so I don’t have to piece my old ones back together
  14. FlatJan
    FlatJan
    wow this chop is gonna be killer.. I'm in :)
    ls1yj and loudbang like this.
  15. ls1yj
    ls1yj
    from Kentucky
    Thanks for all the positive comments. Got some work done today, cleaning and t******* the tack strip Halo, making it ready to be put back in the hole
    [​IMG][​IMG]
  16. ls1yj
    ls1yj
    from Kentucky
    Came by a small problem tonight... the halo is for a 3W coupe, and is a couple inches short front to back.. I’m going to have to make some pieces, and stretch it a little
    loudbang and Pinstriper40 like this.
  17. Pinstriper40
    Pinstriper40
    The lines on the chop are 1000% better. Nice job so far! I'm digging the drivetrain combo too... I'd love a '34 with a dressed up vintage mill backed by a t-5 and quickchange. Can't go wrong! What ratio will you run in the rear?
  18. ls1yj
    ls1yj
    from Kentucky
    Thanks Pinstriper... I will start with a 4:11 set I believe
  19. ls1yj
    ls1yj
    from Kentucky
    Made a rough hammer form, and banged out a piece to extend the halo. Now to make the other side
  20. murpa
    murpa
    from .
    I'm Digging This !!
  21. ls1yj
    ls1yj
    from Kentucky
    Stretched it a couple of inches, and now fitting it to the hole
  22. AHotRod
    AHotRod
    Looking good !
  23. 30 AV8
    30 AV8
    Amazing ......Sir .... You do excellent work ! watching in eager anticipation this will be one Wicked Looking Coupe
  24. ls1yj
    ls1yj
    from Kentucky
    Thanks 30AV8... I wouldn’t go that far, as I am still learning this stuff as I progress... for years I toiled over doing this myself, but was afraid of the sheer size of job and amount of work. Now I say, anyone who wants to do it should just jump in
  25. fuel10922
    fuel10922
    That is the truth! Jump in and don't be afraid to make mistakes that is how you learn this stuff.
    RODIST, brEad, loudbang and 2 others like this.
  26. 3blapcam
    3blapcam
    I agree... but I think people should spend time looking at the various chops first and have a game plan!
    The roof looks super wavy where it meets the halo... is that because the halo is/was missing? Like it'll come together once you start welding it up?
    3blap.
    ls1yj likes this.
  27. ls1yj
    ls1yj
    from Kentucky
    Yeah the roof is wavy where the old halo is gone. I’ve done some shrinking, but without some structure, I haven’t had much luck... I thought I’d tack the hoop in, and it would stiffen the area enough for me to dolly and planish this area flatter, and smooth it out some.
    The back (2) corners near sail panels looked just like that early on
    Most projects don’t show the ugly sides, but only after it’s done and slicked up... I wanted to get some ugly pics in, so folks can see that just about anything can be fixed, and made to look better
    brEad, rpm56 and loudbang like this.
  28. ls1yj
    ls1yj
    from Kentucky
    akoutlaw, loudbang and patman like this.
  29. ls1yj
    ls1yj
    from Kentucky
  30. ls1yj
    ls1yj
    from Kentucky
    3blapcam,
    I got the driver side welded, and started doing some flattening work. It slow going, as I shrink where needed, then hammer and dolly, rinse, repeat
