Projects brainfreeze 1930 model A
Discussion in 'Traditional Hot Rods' started by brainfreeze, Dec 8, 2014.
  1. brainfreeze
    brainfreeze
    *** REPOST TO SEE IF PHOTO BUCKET WORKS ***
    so been getting a little bit done on the coupe recently, mostly just welding the frame and sorting out the subframe. still need to get some pics of the front end so i can get some advice on the tie rod hitting. not sure if i like the look with the mccullough blower on it though.. what do yas think?
    I've got the subframe all welded up and spotted together, its stiffened right up and I'm really happy with how it came out, i had the rails folded up in 2 pieces and then i spotted it all together with my tig, it has a spot weld setting so it only strikes the arc for a set amount of time, works well. i also machined a dimple die so that i could countersink the high tensile bolts into it... heres a test piece i made up to see how it goes and so i can show the inspectors when they come to check it out
    heres a few pics of the subframe in the body, still needs a bit of tidy up work and t******* though
    rab71, AHotRod, Jet96 and 3 others like this.
  2. brainfreeze
    brainfreeze
    another thing i did was modify a set of ladder bars to clear the floor, first i cut out the centre brace, made a jig and then i could heat and bend both top tubes to the same angles. i made a new centre brace and tie welded it back in...
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    and a cheeky weld photo, look alright i guess
    finally a few pics of the ch***is, i haven't taken many cause its not finished yet
    [​IMG] [​IMG]
  3. jackalope
    jackalope
    Looks great! Your frame and suspension and mine are very similar. Keep it up!!
  4. brainfreeze
    brainfreeze
    thanks jackalope! i hope all the pics came through
  5. brEad
    brEad
    I can see pics in both versions of your posts (Facebook and Photobucket).
    Frame, subframe, ladder bars all look good!
  6. quickrack-alan
    quickrack-alan
    from Ireland
    Same here. Cool Coupe
  7. 51box
    51box
    from MA
    Nice work on the ch***is stuff, I'd run the blower for sure
  8. dirt t
    dirt t
    Thanks for sharing.
  9. brainfreeze
    brainfreeze
    awesome! i might just keep doing the Facebook pics cause its easier!
    Thanks brEad i think they're coming together nicely!
    thanks quickrack-alan
    I'm really thinking about it, ill have a look again once i get the 32 shell mounted
    anytime! ill post as much as i can when i remember to take photos
  10. sloppy jalopies
    sloppy jalopies
    IMO... from here I really like the look of the channeled A body with [3] 2's on any engine... even if you only run the center one... its the look.
    brainfreeze likes this.
  11. Tim
    Tim
    from KCMO
    You can use the app or the mobile version of the website to upload your photos right to your thread and skip any photo hosting site.
    Either way can’t wait to see more! The proportions look spot on
  12. brainfreeze
    brainfreeze
    one thing i noticed is a lot of people tend to lengthen the wheelbase to fit the v8's in, or even lengthen them to a 32 wheelbase... i decided to keep mine as close to stock as possible, i think they look more well proportioned at the stock length
    but this is my first build so I'm kinda just winging it haha
    X38, Stogy, Tim and 1 other person like this.
  13. AHotRod
    AHotRod
    Your 'stance' is spot-on ... and I agree with you on the wheelbase.
    What is the height of your front and rear tires?
    I love your Coupe as I see it now.
  14. Tim
    Tim
    from KCMO
    Absolutely! So many builds would be eon’s cooler if they had left the wheelbase where it started
  15. sloppy jalopies
    sloppy jalopies
    Ditto, and it seems so much easier and cheaper to reverse the firewall instead of stretching the wheelbase...
  16. brainfreeze
    brainfreeze
    So I'm running 16-6.00 firestones on front and I think they're 16-7.00 firestones on the rear, maybe 7.50 haha I'll check in the morning!
  17. brainfreeze
    brainfreeze
    That's a task I haven't tackled yet haha its not going to be easy, and with the y block having the dizzy at the rear will make it even more difficult. I haven't welded in the engine and hearing mounts yet as I'm considering swapping out to a manual trans and also want to get the grill in place and eyeball if I can squeeze the engine forward anymore
  18. brainfreeze
    brainfreeze
    So here's the problem I have with the tie rod, I've used socal deep drop steering arms and using a 4" drop axle, using stock split bones the tierod hits on the under side of the bones and I still have maybe a quarter inch still to go into the steering arms. IMG_2672.JPG IMG_2673.JPG IMG_2674.JPG IMG_2675.JPG
    I scored a set of original square back spindles I think I'm going to swap out, heat and drop them but should I also go for the later 37-41 wishbones aswell, the ones that step down after a few inches?
  19. Tim
    Tim
    from KCMO
    46-4? Ford pickup tie rod ends are your solution :)
  20. Tim
    Tim
    from KCMO
    Speedwaymotors.com part number
    910-48640
    1948-1964 ford truck
    brEad and brainfreeze like this.
  21. sloppy jalopies
    sloppy jalopies
    buddy ran the tie-rod on top... and very CAREFULLY tapered reamed the steering arm's hole from the top by hand... t handled tapered reamer...
    asked a buddy, he thought they made a short tapered sleeve to slide in behind the reversed tapered hole... HIH...
  22. brainfreeze
    brainfreeze
    holy ****! that looks like exactly what I'm chasing! would be the easiest fix! and still be high enough from the ground not to worry about!
    thanks Tim!
    Tim likes this.
  23. AHotRod
    AHotRod
    Won't you smack your head on those roll bar down tubes?
  24. brainfreeze
    brainfreeze
    thats just the braces while the floor is out haha they'll be coming out when i finish the floor and weld it in
  25. quickrack-alan
    quickrack-alan
    from Ireland
  26. brainfreeze
    brainfreeze
    So I've made a little progress in the middle of my busy life! Managed to get the body back on and s***ched to the subframe for the final time, gotta lift it off onto some stands to weld the underside to the body! Feels good to have the bracing out for now! [​IMG][​IMG]
    Next thing is get the engine and box bolted back together and sat back in so I can do the engine mounts!
    Also need to find some shock mounts for the front and sort some for the back!
  27. brainfreeze
    brainfreeze
    Also got my dropped tie rod ends in the mail today so I'll test fit them tomorrow and see how it looks! Hopefully fixes that problem, just hope the tierod doest end up too low
  28. AHotRod
    AHotRod
    Fantastic job, the stance, height ... is all spot-on.
  29. brainfreeze
    brainfreeze
    Got the engine back in so I can start on the hurst style engine mounts
    Also I scored this W&H DuPoint distributor last month, hopefully works well!
  30. brainfreeze
    brainfreeze
    Started mocking up the 32 grill shell today, took 5" out of the sides but I think it still needs to come down atleast another inch.
    It looked great without the hood on but with it, the body line on the good side runs uphill compared to the body line on the car!
