Projects garagefind/ survivor 40 coupe build. FIRED IT UP!
Discussion in 'Traditional Hot Rods' started by joel, Sep 26, 2014.
  1. The 39 guy
    The 39 guy
    Joel......don't let that pickup distract you for to long, we want to see that coupe in color![​IMG]
    Maybe I should send you a set of these blinders to keep you on track;)
    lothiandon1940 likes this.
  2. joel
    joel
    Wise words, Sam. It's been a couple of weeks since I've sanded on the car and I think maybe that's long enough. Walking into that room is feeling more like possibilities and less like punishment.:) Thanks for watching.
  3. joel
    joel
    Yesterdays progress in the painting department. I started filling up the pits in the vent seal area with prime. I figured it would bond better and be easier to sand to a smooth surface so the new seal would
    work properly.
    IMG_0598.JPG The next pic is what I've been sanding on.
  4. Runnin shine
    Runnin shine
    This 40 is going to be so much nicer than what I pictured back when I subscribed to this thread long ago.
  5. joel
    joel
    I hope you're right and thanks for following
  6. The 39 guy
    The 39 guy
    Good to see you are working on the air conditioning system Joel! That vent can be a real blessing on a hot day and can make for miserable trip in the rain if you can't get it to seal. I agree that a smooth surface will go a long way towards making for a better seal.
  7. joel
    joel
    I bought a pair of rear fenders for the car from geoford41 here on the HAMB and they arrived today( at Fastenal store) . They are better than I had ; the left one is a lot better. I will mount them and see what I need to do. On the right side I may marry the front half of mine to the rear half of the new one. I took a couple of pix
    I'm anxious to get this on the car. It appears to be almost original paint(maybe 1 color underneath). I might sandblast tomorrow.
  8. godlemmy
    godlemmy
  9. joel
    joel
    They were shipped through Fastenal from a store location in Delaware to one near me in Indiana
  10. joel
    joel
    I blasted my new LR fender and made a couple of small repairs . I mounted the fender so I could see what else might need to be done.
    IMG_0613 (800x437).jpg IMG_0614 (800x780).jpg IMG_0615 (800x441).jpg IMG_0616 (800x441).jpg
    The crack in the far right pic will get welded after I can see the shape of the bottom edge.
    By the way, the ****py blasting is due to the fact that I can't find dried silica sand for my blow through blaster any more. This means it is difficult to blast at lower pressure (60psig) that allows less distortion.
  11. godlemmy
    godlemmy
    Thanks for the shipping info. I'll have to check them out.
    Sent from my SCH-I435 using The H.A.M.B. mobile app
  12. joel
    joel
    I took the LR fender back off to stretch a section of the mounting flange between the last 2 bolt holes (back of fender). I'm guessing this was bolted to a car that was hit in the back and the tailpan pulled the fender into a tighter radius. There are no signs of the fender being hit directly from the back.
    Heat and a port-a-power were used to stretch the fender to match the body. It's almost there ( maybe another 1/8 in). The shape of the fender at the bottom edge, as it curves around to the side, is too "fat". I haven't figured out how to do that ..yet.
    lothiandon1940 and RODIST like this.
  13. joel
    joel
    I'm gaining on the fender. The fender matches the body in length now and I spent 2 or 3 hours picking at small dents and smoothing with a shrinking disk.
    The dark spots are low spots, but not much. On the right is the body/fender match.
  14. muldo
    muldo
    What shrinking disc do you use? One of the kits that's out there?
  15. joel
    joel
    muldo likes this.
  16. joel
    joel
    Here is a quick update. I'm catching up on the "new" rear fenders. The left is close and I switched to the right side rear to weld up some cracks and a couple of small patches.
    IMG_0693.JPG IMG_0690 (800x515).jpg IMG_0691 (577x714).jpg IMG_0692 (800x770).jpg
    The cutout in the 2nd pic was required because a crack repair was done by brazing and it broke again. The rust through in the top pic was covered by a glob of lead on a not properly tinned surface. After I get the rear fenders in DP, I'm back to the body. BTW the delay was due to my 41 pickup. ;)
  17. The 39 guy
    The 39 guy
    You are doing a great job salvaging those fenders Joel! They were pretty rough from what I can see in the pictures. The 41 pickup is a worth while distraction from 40 project. After all a guy has to have a truck to chase parts right?
    chryslerfan55 and joel like this.
  18. joel
    joel
    Despite the encouraging words, I have put the rear fenders aside (all 4) and bought a pair from Carpenter. They should be here by the end of the week.
    PAracer likes this.
  19. FOURTYDLX
    FOURTYDLX
    LOVE IT, KEEP GOING.
  20. InstantT
    InstantT
    from SoCal
    I envy your patience. I would have settled for driving with jacked fenders 50 man-hours ago.
    Sent from my LGLS992 using The H.A.M.B. mobile app
  21. joel
    joel
    I couldn't settle and I should have bought the repo fenders 4 months ago. The car would have paint by now, if I could have given up on the original fenders.
    InstantT likes this.
  22. FOURTYDLX
    FOURTYDLX
    You will be happy in end.
  23. joel
    joel
    I got the new fenders from Carpenter early this week and called them to find out about the paint on them. I was told I could wipe it off with Laquer thinner, but I ended up with paint stripper and a razor blade. Then I finished the whole outer surface with a stripping disk . The weather is supposed to be good tomorrow and I should get the DP on them
    IMG_0723 (800x567).jpg IMG_0724 (800x480).jpg IMG_0725 (800x506).jpg IMG_0726 (800x363).jpg IMG_0727 (800x402).jpg IMG_0728 (800x412).jpg
    2bubbas likes this.
  24. The 39 guy
    The 39 guy
    Wow! jealous here.....Are they as nice as they look in the pictures?
  25. joel
    joel
    So far they are Sam. After the DP, I'm going to test fit them.
  26. FOURTYDLX
    FOURTYDLX
    They look good,fit will tell.
  27. Five.0Forty
    Five.0Forty
    from Oklahoma
    Just wondering if you might consider selling the old fenders? I got a p***. rear on my 40 that makes a guy think it would be easier to start from scratch, lol.
  28. joel
    joel
    Stripped the new fenders and sprayed DP on them. Tomorrow I'll try to fit them. IMG_0731 (800x483).jpg IMG_0732 (800x496).jpg IMG_0733 (800x520).jpg
    They still look good;)
  29. FOURTYDLX
    FOURTYDLX
  30. joel
    joel
    I put the new fender on the p***enger side and it looks good. Maybe it's my rose colored gl***es, but I'm excited about the fit. I'll put the other one on after supper and if it fits as well, I'm going to apply K38 to both and start blocking. IMG_0747 (800x599).jpg IMG_0748 (531x800).jpg
    I also checked the tail light for fit to the contour... perfect.
    tomkelly88 likes this.
