Technical wire tie ?
Discussion in 'The Hokey Ass Message Board' started by 383deuce, Oct 10, 2017.
  1. 383deuce
    383deuce
    When using the plastic wire ties what do you guys use to snip the ends off with? So it does not leave a sharp edge that cuts the **** out of your hand when you have to go back under the dash to do some work.
  2. mike in tucson
    mike in tucson
    from Tucson
    use a regular pair of wire cutters.....trick is to slide the cutters down the tail of the tie so the cutters cut flush
    against the tie body..... See Snap On E709BCG cutter for an example of a flush cut design.
    LOU WELLS and Hnstray like this.
  3. 4wd1936
    4wd1936
    from NY
    Electricians have taught me to twist them off with pliers with the threat of physical violence if I don't.
  4. Joe H
    Joe H
    Take a match and heat the end, then tap it with a flat tool, they smooth right up and don't cut you. A razor knife cuts them even with no sharp edges.
  5. bangngears
    bangngears
    from ofallon mo
    Waxed string works better, can not cut and looks better also. If its good enough for f15 fighters, its good enough for a hot rod
    Texas Webb likes this.
  6. deucemac
    deucemac
    Panduit tie wrap gun. Perfect cut at the lock with no jagged edge to get snagged on. Always some available on EBay. I used them forever on aircraft and convinced lots of other car guys to try mine. They all liked it.
  7. 383deuce
    383deuce
    Mike, Nice tool and looks like it sure would do what I am after....But 63.00 is a little pricy to me. Anyone make this took at a fair price for a home builder?
  8. squirrel
    flush cut side cutters, like mentioned. There are lots of different styles/prices available. The electronics mentor on our robotic team has one of those tighten/cut tools for cutting them off.
    My favorite trick on a traditional car is to not use plastic wire ties, at all.
    Truckdoctor Andy likes this.
  9. Mike VV
    Mike VV
    from SoCal
    383 -
    Might be a little high in cost...but after about the 3rd or 4th tie cut...you'll say..."money well spent"..!
    The tie "load" (or tightness) is adjustable, clean easy cut, very professional looking when done. We use them at work all the time (Aerospace).
    Mike
    AKCJ and deucemac like this.
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I didn't want to plunk the good money for a fancy cutter. I found a cheaper style on ebay, it pulls tight and cuts, but doesn't do either very well. I think the more spendy one is a good investment. Otherwise side cutters all the way down works well enough for me
  11. Here's the best you will find: 90708 at Harbor freight. It's small and gets rid of the evil sharp edges.
  12. 383deuce
    383deuce
    wfo! you are the man!!!!! this is what I was looking for. I am sure it will do the job for me and I like the price. Thank's
  13. J. A. Miller
    J. A. Miller
    from Central NY
    Geez, I thought cuts were traditional. Lol
    scrap metal 48 likes this.
  14. H380
    H380
    from Louisiana
    Pay no more than $5. The best cheap ones are Hakko made in Italy. Only cut TyWraps with them and they will last the rest of your life. The trick is to pull on the tail with one hand. Then push on the Wrap head with the jaws. Then snip the tail under tension. That way the tail is just below the top of the head.
    Look at Hobby and Electronic shops. They carry them too.
    https://www.amazon.com/Hakko-CHP-17...07657327&sr=8-2&keywords=flush+cutting+pliers
  15. I still use bread sack ties.
    OK that is an out and out lie, but I have been wanting to say that for a long time. LOL
    I guess I am as backward as the day is long but if I can get at the loom I use electrical tape. Sorry fellas '60s kid here. If I have to use a wire tie I cut them flush like has been mentioned.
    trollst and Hnstray like this.
  16. I use one of these:
    https://www.be-electronics.com/product_p/f10625.htm
    It tightens and cuts the tail off flush all in one motion. I like it alot! There are more expensive versions out there, but this one has worked well for me for many years. Once you've used one, trust me, you won't go back.
  17. squirrel
    I've used one of the fancy tools, and I still haven't bought one.
  18. bobss396
    bobss396
    I may have one of those tools around the shop. I usually use diagonal cutters and turn the jagged edge where I won't make contact with it. This is from stock car 101.
    Hnstray likes this.
  19. DDDenny
    Don't tell the wife but I use her toenail clipper.
    Cuts closer and works better than any sidecutters you can find.
    kidcampbell71 likes this.
  20. Joliet Jake
    Joliet Jake
    from Jax, FL
    Truckdoctor Andy and bct like this.
  21. Bandit Billy
    Bandit Billy
    I snip them off with side cutters and then run the soldering iron over them to round off the edges completely. Or if I'm in a hurry I heat up a flat blade with a propane torch and do the same thing. Stinks a bit but it works nice.
  22. trailerpark
    trailerpark
    Twist them off.
  23. hrm2k
    hrm2k
    j-jock and rust runner like this.
  24. kidcampbell71
    kidcampbell71
    hrm2k and scrap metal 48 like this.
  25. I do got some advice for anyone who is crazy enough to listen. Do not use fence pliers to pull cheap ties tight. :eek:
    warbird1, Hnstray, reagen and 2 others like this.
  26. DDDenny
    Yeh, I laughed too when my mom showed me what "old people" have to use when their toenails get a 1/4" thick:eek:, now I'm 63 and not laughing.
    reagen likes this.
  27. okiedokie
    okiedokie
    from Ok
    X2
  28. rjones35
    rjones35
    I cut them at an angle so there's a razor sharp point sticking out. Makes it more of a challenge working on stuff then. Don't want it too easy, then any yayhoo could work on my stuff.
    Lone Star Mopar, trollst and hrm2k like this.
  29. Atwater Mike
    Atwater Mike
    ****, Benno!!! WTF did you wire the car with, Barbed???
    Klein is the right thing, wife Joey uses them for her under-dash wiring. She was using Snap-On sidecutters, then went into the hobby shop and grabbed our Klein flush-cutters. (tools for large Control Line scale model planes!)
    Much better, but have also used waxed string tied, (my Dad was an awning man, always waxed his thread for longevity: Bee's wax) Bangingears... Right on about that one!
  30. I've been using a small pair of end cutters for years. They do a good job and will cut flush, but you have to take a second and make sure you're holding them flush to the tie. They look something like this:
