Projects Front engine dragster-Chassis Research 1958 -"Moon Rocket"
Discussion in 'Traditional Hot Rods' started by TheTumbleweeds, Jul 18, 2013.
  1. 9sectruck
    9sectruck
    Looking great, get it finished for next July and bring it to Santa Pod raceway for our Dragstalgia event, we had a few g***ers over from Scandinavia this year.
    Sent from my SM-T550 using The H.A.M.B. mobile app
    TheTumbleweeds likes this.
  2. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Well that would be fun!!
    I need to speed things up to make that happen ;-)
  3. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    20171005_090830.jpg The bushing is adjusted so the steering is turning smooth 20171005_090847.jpg
    Dog_Patch likes this.
  4. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    20171003_215822.jpg Got a gift from a friend, some early belts 20171004_061540.jpg realy cool
    9sectruck and Dog_Patch like this.
  5. saltflats
    saltflats
    from Missouri
    Glad to see some updates.
  6. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    20171005_205152.jpg Tested panel and ****erfly and tried to find out where to put brake handle 20171005_204154.jpg I put the front end on the ch***i and sat like an hour in the ****pit just to feel the air and dream
  7. wrenchbender
    wrenchbender
    Kool digger man can't believe I've missed this thread trust me when you have the front wheels in the air on a launch you will have the time of your life here is mine at meltdown 2017
    Chrome don't get ya home
  8. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    [QUOTE="wrenchbender, post: 12252019, member: 382"Kool digger man can't believe I've missed this thread trust me when you have the front wheels in the air on a launch you will have the time of your life here is mine at meltdown 2017
    Chrome don't get ya home[/QUOTE]
    Wow!! That is so cooool man!!!
    You even let the backtires lift from the ground :p
    thanks the thread is getting warmer again, so the digger maybe wakes up and breath, feels good!
    thanks for the inputs too
    Countn'Carbs likes this.
  9. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Screenshot_2017-10-07-17-13-42.png Some work done on this brakehandle. a braket to weld on fram. Not much but something
  10. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Sittn in the fed and discover that Im missing a old school gas pedal..
  11. UK Slingshot
    UK Slingshot
    It’s coming along well. Still have a way to go on mine.
  12. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    20171010_091531.jpg Made a new thread for my shifter, so I could mount my moon knob :)
  13. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Screenshot_2017-10-12-18-35-40.png Made this tube today for the steeringbox, felt good Screenshot_2017-10-12-12-35-10.png The tube is bent up so the gas pedal have room enough
  14. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    I think next step is to mount the real engine in the rail
    can't wait to fire it up !
    Im waiting for the magneto and nozzles for the fuel.
    see if I can mount the engine this weekend so I can sit and dream for a while. Do you have a eelco or CR gas pedal? Or maybe some other cool brand?
    saltflats and Countn'Carbs like this.
  15. wrenchbender
    wrenchbender
    I had a old moon pedal for the right and just bought a new left one for the clutch they looked exactly the same so I just buried the new one in the garden for about a month (a trick an old car restorer once told me) and it then looked old enough to match I think the new one only cost about $60
  16. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    I have looked at the moon pedals, they are nice with the right age modify :)
    If I go for moon, I think I buy both left right , and let my left foot rest on the left pedal. (No clutch, just solid mounted)
  17. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Sittn in the dragster ****pit for a while yesterday, and couple of beers down the throat...Today , I bent the brakehandle to get some more beers at the shop and feel out the new position 20171023_163728.jpg 20171023_164236.jpg 20171023_164242.jpg
    Countn'Carbs and Gammz like this.
  18. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Screenshot_2017-10-25-21-23-12.png Found This on ebay, perfect for the build I think!! But selling only in US...
  19. cowboyinachair
    cowboyinachair
    from colorado
    knowing you are gonna be sitting on that would a 9 inch make more sense
  20. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Yeah I need to realice that the old banjo belongs to a flathead..
    I go for 9 inch, then I dont need to worry about the rear end. And parts gears bearings is common stuff Screenshot_2017-10-26-11-41-42.png
  21. cowboyinachair
    cowboyinachair
    from colorado
    yeah and you wont be missing your man hood after the first launch
  22. dreracecar
    dreracecar
    from so-cal
    Chrys 8 3/4 (742 or 489 case) is more in size to the early 49 olds, plentifull , in-expensive. exlint parts availabity, strong enough for about 1200 hp. For the 9" make sure you go with a "N" or aftermarket case or you will blow the pinion carrier out the front of it.
    For using the banjo, good parts are getting harder to come by, but is was the QC units that were prone to grenading the gear section off the back end. By using a spool, there is nothing to blow up or escape the housing, you will just knock the teeth off the gear set leaving your "manhood" intact
    rod1 likes this.
  23. dreracecar
    dreracecar
    from so-cal
    The positioning of the 9" will change the line up much different then the banjo as the pinion is much lower on the 9" requiring a taller tire or re-mounting the engine
  24. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Yeah, its going to be low in the back, in worst case I need to re do the mounts like you said. I just love the old style banjo, but I think the niner is safecard and can be busted all day and night
    Thanks for your words guys
  25. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    And going for aftermarket housing
  26. cowboyinachair
    cowboyinachair
    from colorado
    look up quick performance they sell good stuff at a good price
    TheTumbleweeds and Gammz like this.
  27. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Wow yeah, good stuff and good prices! Like a complete drum set with everyting 300$
    Thanks for the homepage advice!
    Im pickin up the 9 inch house here anyday then I can start ordering stuff
  28. cowboyinachair
    cowboyinachair
    from colorado
    they are good people to work with
  29. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Found a nice cast old aluminium gaspedal on a auction site, cheap, well nothing to lose. Haha, when I got it, it was super small! IMG_20180831_172342.jpg
    So Im trying to build One right and left foot pedal instead. Im going to drill holes to keep a good look and of course, save some weight to.
    IMG_20180906_065054.jpg and Im doing some brackets to weld on.
    The shape is going to be trimmed a bit
    saltflats likes this.
  30. saltflats
    saltflats
    from Missouri
    Glad we didn't have to wait a hole year for an update. :D
