Hot Rods T Bucket Interiors
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Aug 12, 2017.
  1. tfeverfred
    tfeverfred
    And it's even easier, when the fuse box is under the seat.
  2. tfeverfred
    tfeverfred
    Nope. Never had a problem with glare. I'll mount mine in the dash the way it's been done for decades.
    dana barlow and loudbang like this.
  3. upspirate
    upspirate
    When I wired my '32 dash, it was so easy to wire on the bench, then with the same color wires I installed a junction block on the firewall and hooked up my dash wires to it after dash was installed. I just left the harness long to the gauges, and when they were installed,terminated them at a junction block.
    More room to install block and run the other wires without the dash in the way too.
  4. dana barlow
    dana barlow
    from Miami Fla.
    My own looks a bit more Italian with meatballs. LOL.
    Working for 55 years though! Thats nice as well
    loudbang and upspirate like this.
  5. upspirate
    upspirate
    Thanks Dana, The more I do , the more I learn, and try to do projects neatly.
    loudbang and dana barlow like this.
  6. tfeverfred
    tfeverfred
    VERY nicely done. I was considering using this:
    https://www.speedwaymotors.com/Universal-Dash-Harness-for-Mechanical-Speedometer,2357.html
  7. upspirate
    upspirate
    Thanks, When I did my '32, I used a EZ-wire kit.
    I wired the gauge wires to the junction block, then with the excess, color coded of course, I used that excess wire to make a harness with the dash laying on the bench and of course I had to have music and hydration while doing it!:):D
    I don't see the need to spend the $98 when all you need is a few crimps and wire ties in addition to the wire you cut off the harness. Spend that $$$$ elsewhere!!!
    Chances are that their spacing and run will not fit as well as you custom making it to fit your gauge placement.Also, get the harness made, then install the dash or gauge cluster, then run the wires to the junction block, then terminate so everything runs nice and neat.
    If you notice in my pics, I ran two separate harnesses to the dash, don't remember why now,(don't have truck to look) but there was some reason that way ran cleaner..
    Doing it this way, you have the advantage of removing the dash easily if you need to and re-installing it with out weird gymnastics, and a spaghetti mess of wires
    loudbang and tfeverfred like this.
  8. upspirate
    upspirate
    BTW, I used marine hardware for things like the junction block, etc.
    Our Ace hardware has a marine section, but I may have bought stuff from West marine also.
    Check out Blue Seas Systems for some good marine electrical hardware,fuse panels,etc.
    https://www.bluesea.com/
  9. tfeverfred
    tfeverfred
    Yes, that $99 price tag was an issue.:D But the idea is good.
  10. upspirate
    upspirate
    Good source for high amp fuse holders and breakers too
  11. RICH B
    RICH B
    Since a "T" bucket is, electricity wise, pretty basic; you don't really need a fancy harness and fuse panel with the mounting and extra wiring involved. I have used a headlight switch with an attached breaker, an inline ATO fuse off the switch for tail and panel lights, another inline fuse off the battery terminal on the ignition switch for the brake light feed, and if you need signals one more inline fuse off the accessory terminal. Simple to wire and keep track of. Suppose, if you get anxious about this stuff, you could put a maxi fuse or fusible link in the main power feed.
  12. tfeverfred
    tfeverfred
    I've been looking at my Rodder's Journal issue featuring the clones of Norm's T Bucket and I've been studying Mr.Mac's interior shot. The side panel's and door panel look like something I could at least give a try. It looks like the material I found: https://www.marinevinylfabric.com/products/marine-vinyl-fabric?variant=13535168902
    could be attached to 1/8" Luan and attached as per Mr. Mac's interior. The bottom piece will be 3" or 4" foam on 3/4" marine grade plywood with holes and webbing. Back to basics.
    Looking at the Speedway interior kit instructions, https://static.speedwaymotors.com/pdf/tbucket_interior.pdf , I'm considering a 3" foam back piece covered with the same material as above, on Luan and attached to the back of the body with: https://www.itapestore.com/3m-dual-lock-sj3871-by-the-yard.html , instead of velcro.
    Doing my interior this way will take full advantage of the extra interior room I'm paying for in the stretched body. I think if I take my time, which I have plenty of, it'll look pretty good.
    Oh....... all in black.;)
  13. saltflats
    saltflats
    from Missouri
    Just thinking out load but I really like the look of the curved seat back but was thinking with the curve on just your one side do these seats have you always wanting to lean to the inside of the and if you have a p***enger they would be leaning toward you.
    I think a bolster in the center may be something to think about.
  14. tfeverfred
    tfeverfred
    I plan on making my back piece with a very slight curve. The back piece in my old T Bucket was basically straight across and leaning inside wasn't an issue.
    Of course, by limiting my p***engers to females, leaning closer wouldn't be too bad.;)
  15. Dick Stevens
    Dick Stevens
    I like the look of Mr Mac's interior too! Go for it Fred, you won't be sorry for doing it!
  16. saltflats
    saltflats
    from Missouri
    Just don't pick up the bony ones. :eek:
  17. RodStRace
    RodStRace
    Good planning!
    I will suggest buying more material than needed, and expecting to do at least one trial run. The door would probably be best. Small and fairly flat.
    Develop the skill and make mistakes on that, then do it for real. Work up to the full length driver's side.
    http://www.how-to-build-hotrods.com/door-panels.html
    http://route66hotrodhigh.com/DoorPanels.html
    Pleats are cool and timeless, easy to lay out.
    Don't forget diamonds, though. None other than Tony Nancy did this one...
    http://www.ebay.com/itm/Vinyl-Uphol...d=122018811466&_trksid=p2045573.c100033.m2042
    Dannerr and loudbang like this.
  18. RodStRace
    RodStRace
    Note that both of the Red interiors you posted have piping or a bead attached at the top of the panel.
    You could have a local shop sew these up for you to attach to the panel after it's face is done. Maybe your supplier will have it by the yard too.
  19. tfeverfred
    tfeverfred
    I plan on keeping it simple the first time, so my panels will be straight and smooth.
  20. RodStRace
    RodStRace
    A pocket on the driver's side.
    I could see this being useful for small items (phone, tire gauge, etc.)
    It could be placed next to your hip so it would be more hidden and allow a spot to grab the seat bottom to flip forward.
    You can see it's just a hole sut into the panel, the upholstery cut and fitted to the hole, and another piece of material attached behind the hole to form the back. then an elastic is sewn into another section of the material and then attached to form the front of the pocket.
    Here's another with pockets as it got made. I refuse to post the pics (dash):eek:, but the pockets might be useful.
    http://www.catalinacustom.com/showc...e_gallery_street_rods_23_ford_t_bucket_02.htm
  21. RodStRace
    RodStRace
    Piping is simply the same material wrapped around a flexible center cord and sewn. it can be attached to the covered edge at the back of the panel. Simple to add the finishing touch to the top edge of the panel. The hardest part is firmly attaching it. Staples tend to poke through the backing and out the front upholstery.
  22. tfeverfred
    tfeverfred
    Yes, I know what it is, but it's something I'll try later. For now, K.I.S.S. Sometimes, I forget that simple phrase.
  23. RodStRace
    RodStRace
    Just tossing out ideas for you and others!
    K.I.S.S is wise, especially when the alternative is 'mission creep'! :D
    If someone is also using properly spaced screws to hold the panels (don't forget to 'gl*** in the wood backing strip or blocks) , a second strip of backing board could be attached to firmly hold the piping/welt/bead.
    I wish Chip would visit and explain this stuff. He's got a great background for this thread.
  24. tfeverfred
    tfeverfred
    Thanks. I forgot about that.;)
  25. steel rebel
    steel rebel
    Fred save up some $ and have the interior done by professional. I did. You are a welder not an upholster. The upholstery is something that jumps out at you. If it isn't professional looking your bucket is second rate. You can skimp on chrome and custom paint but don't skimp on upholstery.
    I really like the below orange rod interior if you want comfort and a '60s look, but **** me what do I know.
    Rebel
    DaPeach likes this.
  26. DaPeach
    DaPeach
    from NE OH
    IMG_5094.JPG IMG_5095.JPG My welt was stapled on independently of the side panels. Makes for a nice uniform top edge w/o struggling to line up separate panels to the edge. Having a functioning door will require a little matching, I wouldn't think it would be too bad this way though.
    Just another way to do it...
  27. tfeverfred
    tfeverfred
    I'm going to remember that. Thanks for the motivation. It reminds me of what my boss at the place I built my previous T Bucket said, when I asked if I could use a corner of his warehouse for my build.
    "Sure, but those guys are professionals. You can't just up and build a car."
    Consider THAT ^, pushed. And if I fail, I'll dust myself off and start over. I'm kinda programmed that way.
    Driver50x, Sancho and Dick Stevens like this.
  28. saltflats
    saltflats
    from Missouri
    I think you will find it easier than welding. ;)
  29. tfeverfred
    tfeverfred
    I had a rethink on the panel and seat upholstery. Considering I'll be folding material over some curved sections and stapling or gluing to Luan, the previous 1/4" foam backed vinyl would be too thick to staple securely. So, I found some marine grade vinyl that doesn't have a foam backing and has flex built into it. I have edited the above post accordingly. Here it is: https://www.marinevinylfabric.com/products/marine-vinyl-fabric?variant=13535168902
    This way, I can glue foam to just the Luan and then roll the material over the edge and glue it down to the back of the Luan. I got the idea from "Stich's" thread on door panels.
    Another plus, this vinyl is a lot cheaper.:)
    saltflats likes this.
  30. tfeverfred
    tfeverfred
    Peach, I'm having a hard time Google searching welting that thick. Did your upholstery shop make it or do you know where it can be found?
