rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. roo is correct. Melts lexan real fast. race cars being race cars there are always things being cut off or welded on. It would look bad in a hurry. Paint is also flameable. clear spray paint won't stick long without primer. all spray paint is removed with brake cleaner and we use a lot of that.
  2. milwscruffy
    milwscruffy
    What time are you running today ?
    els likes this.
  3. Tried to make a pass. Engine is locked up tight. Blew the burst panel on the burnout. My guess is a bolt came out of the gear drive or pump drive spud. The bolt is most likely between the gears. I wont fix it at the track. i don't think we spun a bearing the car was not running long enough.
    mad mikey, bobwop, Stogy and 2 others like this.
  4. squirrel
    ouch! I guess it's telling you it wants some more engine work....
    Stogy, loudbang, racer-x and 2 others like this.
  5. Runnin shine
    Runnin shine
    Hell yeah! Come on 6s!
    els, loudbang and racer-x like this.
  6. ROADSTER1927
    ROADSTER1927
    Sorry to hear that, but Racers get on with it! You Will! Gary
  7. I will find out what is going on this week. It sucks to waste the good weather. A weekend like this is getting rare as we get 20170912_063437.jpg late in the year.
    mad mikey, bobwop, Stogy and 6 others like this.
  8. 20171008_174932.jpg 20171008_174941.jpg After i calmed down a bit i tore into the engine. The picture is alot clearer now. I removed the pump extension and found the drive was able to turn freely. Thats not good. That spins the dual drive. It went lean on the burnout popping the burst panel and breaking the belt. The spud was still connected to the spacer. Its the spacer that bolts to the cam that came loose. To get at it i need to pull the front cover. I know it wasnt a lean tune up because i had just set the leak prior to attempting a pass. We will see how all this goes i wont make bowling green but i might be able to get one more try at the ellusive seven second time slip.
    mad mikey, Stogy, els and 3 others like this.
  9. wrenchbender
    wrenchbender
    Well at least that shaft didn't break lol hope the rest is ok and can be repaired easily brian thanks for all the info you provide it does help us in more ways than you know
    mad mikey, els, enloe and 3 others like this.
  10. the hardest part will be supporting the engine while removing the front mounts. they need to come off first before i can get the cover off. after the covers off i can get a better look to see if the gear has any damage. i will know more tomorrow. its not snowing around here yet. as a kid i remember trick or treating in the snow. I'm starting to run out of time. we will stay focussed and see what happens.
    mad mikey, RICH B, els and 3 others like this.
  11. saltflats
    saltflats
    from Missouri
    Hurry up!!! you can make Mo-Kan next weekend. :D
    mad mikey, els and loudbang like this.
  12. How late do they stay open. The grove stays open as long as its not snowing and sticking. I do remember making passes while there were some light flurries one sunday.
  13. wrenchbender
    wrenchbender
    They will have test and tune into November as long as weather is clear and next Sunday is the hot rod reunion at mokan I will be there with the digger and I think Saltflats is bringing the salt shaker as well
  14. saltflats
    saltflats
    from Missouri
    I will be there.....Jackson you don't get to have all the fun.
  15. 20171008_104119.jpg 20171008_121702.jpg 20171008_104139.jpg 20171008_104127.jpg Salty this was pitted next to me. I took these for you. The car was perfect. 20171008_104127.jpg
  16. saltflats
    saltflats
    from Missouri
    That's Dan
    Got a new best then smoked a clutch.
    Nice guy I have a pair of heads that he has worked over and hope to try them soon.
    mad mikey, bobwop, els and 2 others like this.
  17. FinnishFireball
    FinnishFireball
    She's so fine, that four 'o nine? What did you find Brian, any major issues?
    loudbang and els like this.
  18. im off tomorrow. I plan on getting it apart then. weather looks like rain Saturday going into sunday morning. I don't know if we will be able to get it out for a few passes.
  19. bobwop
    bobwop
    from Arley, AL
    I used to run my 63 Belair 409 "Faded Memories" against the "Homewrecker" owned by Bob and Dan Hradisky. The "Homewrecker" was sold new at Hoskins Chevrolet of Elk Grove, IL to an old friend of mine, Joe Scarlotta. It was originally powered by a 327 with four speed. Joe won many, many races with the car, as it came from the factory. He is the one that named it. And yes, he has been divorced a few times. And he is still racing!
    mad mikey, loudbang, els and 2 others like this.
  20. 20171013_095514.jpg 20171013_123825.jpg 20171013_141902.jpg 20171013_164922.jpg 20171013_164946.jpg When i pulled the front cover i found the center broken out of the aluminum spud adaptor. The bolt holding it on was loose. I will never know what part was the first to go. Im using alot of parts in ways they were never intended to be used. Sometimes we need to make our own parts to fit our unique needs. To cure this we spent several hours on the lathe and rotary table making a new one out of high strength steel. It was made with over twice the thickness were the center bolt goes through. It was also made to trap the center bolt exactly were it cant back out. We added a register to the backside were it attatches to the cam hub. When we decided to add this register bob at hot heads was able to give us the dimention we needed. The car was not close by to get it ourselves. This piece has received several upgrades. We think this 20171013_095514.jpg 20171013_123825.jpg 20171013_141902.jpg 20171013_164922.jpg 20171013_164946.jpg is the last time we will have this problem. 20171013_095514.jpg 20171013_123825.jpg 20171013_141902.jpg 20171013_164922.jpg 20171013_164946.jpg
    mad mikey, els, loudbang and 2 others like this.
  21. somehow the pictures multiplied. I have a car to put back together so im not fiximg it.
  22. 20171013_180719.jpg All back together.
    els, bobwop, Woogeroo and 5 others like this.
  23. You sometimes cant always explain things. I think the car was telling me not to run it any more so it disconnected the drive for me. As i was scraping the timing cover surface i found this big crack in the block. Who knows what would have happened if i would have gotten the car down track at speed. The crack goes all the way up number one at the front of the block. Wow. I guess i have to wait until next spring for a seven second pass. 20171013_211855.jpg
  24. nrgwizard
    nrgwizard
    from Minn. uSA
    Wow... Somebody's looking out for you - & I'm glad.
    Guess the "opportunity to upgrade" came earlier than expected. At least you didn't get to wear the contents of the mill n fuel tank. That'd be just a little too exciting...
    Thanks for the reply on the Q's before.
    Hope the new build goes well. I'm going to guess the 'stupid horsepower level' is awaiting the new build... :D .
    Does this one get built to withstand the Green Flames concoction? :D .
    Marcus...
    mad mikey, els, racer-x and 2 others like this.
  25. squirrel
  26. loudbang
    MAN that is terrible news. But at least you caught it BEFORE it came apart. :)
  27. Stogy
    Stogy
    That pic before the closeup (post 2371) you can see it quite clearly. @racer-x you are conditioned for setbacks. The sport is hard on components and you have a good eye. I wonder how long that was there it almost looks rusty. Well we are with you ups and downs and all and you are okay and Thats Number One...;)
    mad mikey, Gammz, loudbang and 2 others like this.
  28. saltflats
    saltflats
    from Missouri
    You may have been runnin over your crank on that one. :eek:
  29. FinnishFireball
    FinnishFireball
  30. ididntdoit1960
    ididntdoit1960
    from Western MA
    Wow - Nitro is hard on parts......not for the faint of heart......keep the faith - gas is for washing parts!
    Stogy, loudbang, els and 1 other person like this.
