Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. kidcampbell71
    kidcampbell71
    Are you feeling the @Limey Kid build here or something ? Maybe, I guess, in the sense of race car modern in hot rod camoflage. Reminiscent could be the word. I see innovation and thoughtful process, with some kick *** fabrication here. Both builds are fantastic thus far. Thanks for NOT being happy building something anyone could.
    AHotRod likes this.
  2. brsturges
    brsturges
    from Miami, FL
    AHotRod likes this.
  3. gnichols
    gnichols
    from Tampa, FL
  4. dentisaurus
    dentisaurus
    from Boston
    loving this, day dreaming in metal. Brilliant.
  5. rottenleonard
    rottenleonard
    I had this 48 Ford F1 front end that I could steal the brakes off of,
    I have heard this would work but I have never personally done it, so here is my experience with it. Some people say to just Mount the brakes upside down and then roll the wheel cylinders over. They mount up okay,
    But the wheel cylinder mounting is not concentric with the center line of the wheel cylinder bores. You would have to alter the mounting in the backing plate in order for it to work as it also throws off wear the shoes meet the wheel cylinder.
    Another option that is talked about is redrilling the four mounting holes on the backing plate in order to rotate the wheel cylinder ahead of the spring mount. This could work too, but what I can see is it rotates the wheel cylinder to an angle and it looks to me like there's going to be problems getting the air out of them. I'm sure it could be dealt with but didn't look like the best option to me.
    The most viable option in my mind is to mountain straight up as they should be, and this causes an interference with the springmount hitting the backing plate, but there isn't much t******* that needs to be done to get everything to fit together. It seems to leave plenty of room for the brake line to p*** the Spring Mount, and really the only issue is that the bleeder screw comes into contact with the Shock mount. I believe you could find a shorter bleeder screw if the shock mount was needed, in my case I'm not using the shock mount so I just cut it off and blended it in.
    20171013_104127.jpg 20171013_104115.jpg 20171013_122900.jpg 20171013_123030.jpg 20171013_123238.jpg
    It all fit together nicely, unfortunately I forgot to take a picture after I put it on. I will grab one when I'm back down at the shop.
    Runnin shine, brEad, AHotRod and 2 others like this.
  6. rottenleonard
    rottenleonard
    As a side note, I will be using the 37 to 39 hubs and wide 5 Wheels, however every set of wide 5 drums I have seems to be well beyond using. If someone has a nice pair please let me know. 20171013_101813.jpg 20171013_114406.jpg
    Tim_with_a_T, Stogy and kidcampbell71 like this.
  7. '52 F-3
    '52 F-3
    from Central PA
    very interesting build..... with great skills and ideas.
    I like it a lot.... and will be watching :)
  8. rottenleonard
    rottenleonard
    As the plot thickens, the rear wheels are down for a nasty sand storm and powder coating, the front IMG_20171019_164051106_HDR.jpg IMG_20171019_164541734.jpg s are 19 inch Harley. Currently building fixtures and leaning some G code from my old man to make it all jive.
  9. Stogy
    Stogy
    It's the re-invention of the wheel second time around Hotrod Style...;)
    charleyw likes this.
  10. Burkedore
    Burkedore
    Tell me more about the Harley wheel idea. I have been contemplating making some hubs to lace to some 19" rims for my Continental star speedster. What would you be using for brakes?
    Also, if you need help with the g-code, I program lathes for a living.
    Frankie47 likes this.
  11. rottenleonard
    rottenleonard
    We had used Readily available Harley wheels on our North West Vintage Dragster along with Model T axle and spindles. Like most Harley stuff the wheels are way over built, makes them a good candidate for light hot rod. I did the drawings for both Model A spindles as well as 32-48 spindles. They use the corresponding wheels bearings that came stock with the spindles. The model A does require the later nut to hit the cotter key hole as it is a little thinner. Just as the path of least resistance I am going to use the Harley brake rotors and I have a set if front calipers coming from a Dyna.... Stay tuned to see how that works out.
    brEad, harpo1313, Blues4U and 2 others like this.
  12. SimonSez
    SimonSez
  13. rottenleonard
    rottenleonard
    Photo dumping cause I am switching phones this weekend. You will have to make your own descriptions. I will come back and fix it later. IMG_20171020_094939951.jpg IMG_20171020_161858676.jpg IMG_20171020_132435678.jpg IMG_20171020_103824113.jpg IMG_20171020_160736961.jpg IMG_20171020_092629098.jpg IMG_20171020_163306511.jpg IMG_20171020_114614077.jpg IMG_20171020_141750055.jpg IMG_20171020_120357174.jpg IMG_20171020_085542212.jpg IMG_20171020_160159564.jpg IMG_20171020_132348013.jpg
  14. fatkoop
    fatkoop
    I like the way you think. And work.
  15. Tim
    Tim
    from KCMO
    Very cool I’m looking forward to seeing this come together
  16. rottenleonard
    rottenleonard
    Finished up the machine work on the wheels, and had the Excelsiers mounted up. I absolutely love the look. We can do this for model A spindles and 32-48 spindles, pm me if you are interested in a set. Made some progress on the seats, then had to put the cowl on for some glamour shots. 20171023_144032.jpg 20171023_145257.jpg 20171023_145305.jpg 20171024_150121.jpg 20171025_110421.jpg 20171025_110959.jpg 20171025_111043.jpg
  17. rottenleonard
    rottenleonard
    Here is what it would have looked like 50 years ago ;)
  18. kidcampbell71
    kidcampbell71
    You're such a bad***. That is sweet !
    Runnin shine likes this.
  19. Casual 6
    Casual 6
    from Great NW
    Hi Rob,
    Just so I'm clear on mounting the HD spoke wheels on the Ford spindles:
    You made all new hubs for the wheels? And didn't modify the HD hubs?
    Did you re-lace the wheels yourself?
  20. gnichols
    gnichols
    from Tampa, FL
    N I C E, N I C E, N I C E! Gary
  21. harpo1313
    harpo1313
    from wareham,ma
    I love **** like this, very good pics, and a ton of eyeball on your part.
  22. pitman
    pitman
    Cotton Werksman's 1972 Nats. Build.
    A Boner, continentaljohn and AHotRod like this.
  23. alleyoop
    alleyoop
    Very nice a lot of work but you did it your way that is good .
  24. gdaddy
    gdaddy
    from nw fl.
    the black and white makes the chrome pop , your work is wonderful , thanks for sharing . I don't know why , but the b&w makes the 4 banger stand out more .
  25. James D
    James D
    Wow! What an original build. Love it.
  26. rottenleonard
    rottenleonard
    No these are reproduction sportster front wheels, they have a boat load of fat in the hubs (like most Harley Parts) I made up a mount and bored a larger hole in one side to accept the Ford bearings.
    Seems like it makes my shop look cleaner too:p
  27. rottenleonard
    rottenleonard
    After sitting in the car I could tell that one of the crossbars was going to be right where you wanted to put your foot for the gas pedal. Solution was to cut it out and tap the end of the shaft where the pedals originally pivoted. Then reattach the bar there to carry the load forward in the bellhousing. The next pictures show the process of Designing the pedal ***embly, you will notice that the lower plate changes partially through as I found that I could not reach the pedals even though I am fairely long-legged. This allowed me to bring the master cylinders in side of the cowl which I like and I am using a Wilwood balance bar which will be nice for setting the Brake bias 20171025_112924.jpg 20171025_131457.jpg 20171025_145601.jpg 20171026_102201.jpg 20171026_151914.jpg 20171026_155026.jpg 20171026_163731.jpg 20171027_153135.jpg .
    Runnin shine, jebbesen, Jet96 and 5 others like this.
  28. rottenleonard
    rottenleonard
    The clutch shaft runs through the brake pivot tube to the right hand side of the pedals and mechanically actuates the lever as it did before, I just had to re-index the arms on the shaft.
  29. rottenleonard
    rottenleonard
  30. gnichols
    gnichols
    from Tampa, FL
    Great stuff. I'd like to book a ride, please! Gary
