Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. Blues4U
    Blues4U
    from So Cal
    :D :D
    loudbang and Stogy like this.
  2. rusty rocket
    rusty rocket
    Jersey sand would be quite a distance from the Black hills of South Dakota. Quite possibly the Hot Rod hill climb though!
    55Deso, loudbang, Binger and 2 others like this.
  3. Stogy
    Stogy
    These things are generally not street legal so yeah...gotta find somewhere to run it. Your another motivated fellow that's for sure. Front row seats again yaaayy!!!
    loudbang and Gavin Tittle like this.
  4. rusty rocket
    rusty rocket
    I'm going to make this one street legal, biggest part will be the head lights. I have some really kool small red jewels for tail/brake lights.
  5. Runnin shine
    Runnin shine
    I was thinking a single taillight might fit the bottom spot of the tail section with purpose.
    50fish, biggeorge, Hombre and 2 others like this.
  6. rusty rocket
    rusty rocket
    That would be a kool idea but the frame will be stepped in the back so the little area at the bottom will be cut off.
  7. rusty rocket
    rusty rocket
    Well my Rambler Flathead 6 motor option is out. The donar car just got loaded on a trailer and is outa here.
    Stogy and loudbang like this.
  8. rusty rocket
    rusty rocket
    Did a bit to the single seater, I welded the head light pod to the tail section and rolled a ring to cap the end. IMG_2242.JPG IMG_2243.JPG I know I'm doing this all wrong and backwards but this car is not going to be pristine by any means. I guess I'll be happy with bumps and wiggles it is representing a sprint car that would have been built in the 40's. Doesnt have to be purty just get it done and make it to the track.
  9. rusty rocket
    rusty rocket
    I also scored a complete 40 Ford front and rear end. Now just source a motor and trans.
    50fish, biggeorge, Stogy and 2 others like this.
  10. ClarkH
    ClarkH
    This is the right at***ude! I made cosmetic compromises in my build as well, and each was a conscious decision. There is amazing work to be seen on the Hamb, but if you get overly caught up in perfection, it can lead to paralysis. It's your build, man, and you should be proud of it.
  11. rusty rocket
    rusty rocket
    I started messing with the ****pit area. Using 3/8ths rod. IMG_2253.JPG IMG_2256.JPG IMG_2257.JPG IMG_2258.JPG
  12. flatheadpete
    flatheadpete
    from Burton, MI
  13. rusty rocket
    rusty rocket
    I havent had a lot of time to wrk on the project but I did get the ****pit area wrapped with 3/8ths rod. IMG_2264.JPG IMG_2265.JPG IMG_2266.jpg
    brad2v, 50fish, Hombre and 8 others like this.
  14. rusty rocket
    rusty rocket
    Have all my 3/8ths rod welded in and ruffed out. IMG_2277.JPG IMG_2278.JPG
  15. onekoolkat1950
    onekoolkat1950
    Looks rad!
    brad2v likes this.
  16. rusty rocket
    rusty rocket
    Been kicking around ideas for the grill shell. This summer I went to our local Steam and gas threshing bee and found a Kool tractor gas tank for cheap. So little did I realize my gas tank was really my grill shell. Today I threw the tank up on the table to see what it would look like. If you squint and imagine about a foot off the bottom and the under side of the tank cut off theres a Kool track nose there. IMG_2300.JPG
  17. 30tudor
    30tudor
    This is getting very interesting.
    Greenblade likes this.
  18. desotot
    desotot
    keep the pics coming!
  19. Stogy
    Stogy
    Just kicking the can and seeing where it lands...;)
    Tank...What Tank...:p
  20. Fedcospeed
    Fedcospeed
    Outstanding!!!
    kiwijeff and Stogy like this.
  21. Stogy
    Stogy
    Thanks Fedco...We'll see if it strikes the bosses fancy...
  22. dirt t
    dirt t
    Stogy likes this.
  23. Stogy
    Stogy
    Not sure if these comments are directed towards me...if so thank you...I
    find inspiration in the inspiration of others. There is a lot of that going on around here...;)
    These talents don't really need it but I have fun playing around with visions.​
    Atwater Mike likes this.
  24. rusty rocket
    rusty rocket
    Stogy, thats the **** right there. I do want to build the hood a bit shorter. Going on the same lines as onekoolkats one seater. Your rendering looks more drylake and I'm shooting for late 40's sprint car.
    kiwijeff, onekoolkat1950 and Stogy like this.
  25. rusty rocket
    rusty rocket
    I have also stuck a name on the car. It is going to be called the Id-L-do Special. Im going to attempt to do most of the work myself without the help of my buddys, so if I mess something up and its close enought to p*** muster IT WILL DO!
  26. ClarkH
    ClarkH
    I like yer thinkin'!
    4speed_mopars and onekoolkat1950 like this.
  27. Fabber McGee
    Fabber McGee
    Took me a few seconds to figure out how to pronounce the name, how about one of these?
    Ittldoo Special
    Ittldue Special
    Ittldew Special
    In any case, it darned sure will.
    Hombre and Stogy like this.
  28. Los_Control
    Los_Control
    from TX
    I vote for this one ... thinking doodlebug it gains some sort of legitimacy?
    Dunno, but like it.
  29. Fabber McGee
    Fabber McGee
    Stogy likes this.
  30. It's really starting to look like something....Stogy's photo shop nose looks the ***s, but then again I'm a track nose kinda guy.
    Stogy likes this.
