Projects 1956 Pontiac Gasser 389 swap (Finally Running)
Discussion in 'Traditional Hot Rods' started by wvenfield, Oct 29, 2014.
  1. OahuEli
    OahuEli
    from Hawaii
    Sorry it took so long to do the photoshop but here is an idea. 56 Poncho gasser wvenfield w slots.jpg
    1947knuck, brut4s, loudbang and 4 others like this.
  2. 55chieftain
    55chieftain
    I found some longer shocks and modified them to work. It allowed the rear end to drop down further without affecting the ride, I had 15x7 cragars with 235 60 15 and could get them off easily. The replacement monroe shocks were actually shorter than the factory ones and made it worse. How wide is the GTO rear I thought the newer ones were a little wider? The 8.8 explorer rear was a little under 60" and helped some. Guess if your cutting the 1/4's doesn't really matter.
    1947knuck and loudbang like this.
  3. wvenfield
    wvenfield
    Much thanks......That helps with the wheel well cut to get some idea.
  4. wvenfield
    wvenfield
    I think I was told earlier that the GTO was a little wider. It was under my friends 55 Nomad that he drag raced. (It's ready to go). I have a line on a set of Vintage 15X8 and 15X4 Cragers but I have to find the time to go get them. (about 8 hour round trip)
    1947knuck likes this.
  5. seb fontana
    seb fontana
    from ct
    Looks good with radius wheel opening I think..
    OahuEli, greaser and wvenfield like this.
  6. Deuced Up!
    Deuced Up!
  7. 55chieftain
    55chieftain
    Just do it and don't look back lol
  8. safari-wagon
    safari-wagon
    But don't close your eyes when you do it...
  9. wvenfield
    wvenfield
    Trying to get up the nerve. So nice for 60 year old wheelwells. I have to think I can get a 10 inch slick in there. Should have the rear end in place in the next couple weeks. Will measure and measure and measure again before cutting.
    Frame is all welded up. Just waiting for a decent day to get it outside and degreased.
    1947knuck and twoponchos like this.
  10. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Just found this thread and read the whole thing. Very cool.
    wvenfield likes this.
  11. wvenfield
    wvenfield
    Frame cleaned....rear end out of 69 GTO about ready to go in......Just measuring out in the yard it's a 1/2 inch or so wider.
    1947knuck and Donuts & Peelouts like this.
  12. Snowman454007
    Snowman454007
    from Austin, TX
  13. wvenfield
    wvenfield
    Wow, been a year........had some family issues and got delayed. Anyway, new directions and back at it. Hopefully it will roll again by the end of next week.
    Found some fronts.
    Different direction on the intake.
  14. wvenfield
    wvenfield
  15. Max Gearhead
    Max Gearhead
    from Wisconsin
  16. OahuEli
    OahuEli
    from Hawaii
    Looks good! Are you going to leave the front frame tubing open?
  17. wvenfield
    wvenfield
    No, I got ahead of myself but the opportunity to do that presented itself. It still a foot too long or something like that. It will be cut off, rounded, filled and the paint touched up.
  18. wvenfield
    wvenfield
  19. Snowman454007
    Snowman454007
    from Austin, TX
    Great looking progress sir if you ask me!!
  20. Nice job, so far.
    Now I have to question who advised using the 69 GTO rear? If it's the original 8.2 , they are not very strong,
    especially behind a healthy big inch Pontiac and a 4-speed.
    Going to suggest keeping it in the car show area at the nostalgia drags.;)
  21. brut4s
    brut4s
  22. ididntdoit1960
    ididntdoit1960
    from Western MA
    isnt that what it was behind in the (even heavier) GTO?
  23. 55chieftain
    55chieftain
    It's got bolt in axles , it should be fine on the street. my gto had a 428, 4.56 rear and didn't break, just wheel hopped real bad lol.
  24. wvenfield
    wvenfield
    Sorry I missed this. It is not stock. My friend had it behind his Nomad that had far more HP than my car will have. He was running 10 inch slicks and never broke it. I'm not going to be able to get that wide under mine. (at least initially) Even at that I do not have any false expectations. If I get into the 12's I'll be happy.
  25. wvenfield
    wvenfield
    Thanks......slow going. I have the emergency brake run and the firewall ready to paint. Once painted (this week) we will start putting it back together.
    It will be filled.
  26. wvenfield
    wvenfield
  27. Nice to see a Pontiac for a change, looks like you had a nice solid car to start with too, carry on...
  28. Mike Colemire
    Mike Colemire
    This is a sweet build. I put a 99 explorer under my 40 in the aviator. I cut 3 inches out of the long side which made it 56 1/2 total. You can use a factory short side axle, I put Yukon axles in mine. They have 31 spline axles and disc brakes.
    loudbang and wvenfield like this.
  29. Did your friend have a 4 speed?
    My concern was because of the 4 speed.
    Now I even have more concern about trying to run in the 12's.
    What has been done to the rear?
  30. loudbang
    NICE Corvette :)
