Technical 1940 ford trunk mat for less then $25.00
Discussion in 'Traditional Hot Rods' started by Bigmac48, Oct 14, 2017.
  1. Bigmac48
    Bigmac48
    from Dundalk Md
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg my trunk on my 40 was kinda dusty and looking a little dingy . After removing the wood over the tool tray area and blowing everything out with the air hose I then shot the sides and wells with a fresh coat of paintable undercoating ( the kind that dries - doesn't stay tacky ) then I shot the floor with a coat of decent flat back paint . Looked pretty good I thought . Would leave trunk open when she was resting in the garage .everthing dried great .after several weeks checking out eBay for diff. Goodies I came across this generic trunk mat checked the measurement and thought I'll give it a try .think I paid $21.88 . As long as you don't mind the not period correct diamond plate pattern ( nubs up for me) .this I a great fix . Didn't trim anything till I centered it in the trunk with the back centered around the trunk latch catch . Once I centered that didn't take it back out till I was done. Got most of the what I'm calling the back edge tucked under the rubber trunk gasket . Cuts easy with a pair of regular scissors . You will see the back part closest to the back seat is a perfect width .so with mat centered and trimmed to hug trunk catch pic a line in the pattern that matches (meets ) back width and trim away . Take your time t******* along the back that will go under the trunk gasket . Only thing I didn't trim yet was for my spare but even that could be done in the trunk . I think it turned out pretty good looks nice and fresh . I bought the black but also have seen them in gray and tan but they are priced a little higher . My sedan has carpet but I also think someone could use one of these to partially cover the front floor from firwall to front seat . Many sources but here is the one I used .here are my pics 1 pic of the little bit you have to cut off .sorry guys if I post to many pics just trying to help someone else . Looks gray but it's black .
  2. Great solution!
    lothiandon1940 likes this.
  3. Kan Kustom
    Kan Kustom
  4. stillrunners
    stillrunners
    from dallas
    like x2....nice job and thanks for sharing !
  5. Bigmac48
    Bigmac48
    from Dundalk Md
    Thanks guys , was thinking I made to much of a trunk mat .but thought being a quick ,cheap fix was worth the post .
  6. 38Chevy454
    38Chevy454
    Nice thinking and application. Can't beat the price.
