Technical Ford Toploader Shifter Conversion
Discussion in 'Traditional Hot Rods' started by Merc Flat Head, Oct 8, 2016.
  1. Merc Flat Head
    Merc Flat Head
    I am building a 1930 Ford Coupe with a 1950 Merc flat head and a 1967 Ford 4-speed top-loader transmission. I am in need of the 1990 SRM magazine article describing the process of removing the side mount shift linkage and installing the Jeep T176 top mount shifting ***embly.
    Thanks for any help!
  2. RichFox
    RichFox
    I thought that was only for three speeds
  3. wbrw32
    wbrw32
    That's not "Traditional" per HAMB rules
  4. metalman
    metalman
    ??? Doesn't fit Hamb rules? Model A with a flathead sounds pretty traditional to me, don't care what ****** it has.
    You might PM Cl***ic Gary on here, he did that conversion on his Model A with a toploader 4 speed a year or two ago.
  5. deathrowdave
    deathrowdave
    from NKy
  6. 51504bat
    51504bat
    I installed a Jeep T-176 top shifter housing on a '66 Mustang toploader. Pretty straight forward install. You have to grind the case to allow the reverse fork to fit so you have to pull the trans apart so as not to get grindings inside the trans.. I used freeze plugs to block off the holes where the shifter shafts came through the case. I had the article but I think it was on my other lap top that died. I think I used Mr. Google to find it. IMG_3248.JPG IMG_3249.JPG IMG_3250.JPG IMG_3251.JPG IMG_3252.JPG IMG_3253.JPG Attached are some photos of the finished install. Sorry no photos of the actual change over.
    popawolf and town sedan like this.
  7. dirty old man
    dirty old man
    I bought my roadster in a mockup condition with one of these conversions in it. Once completed with a shift boot on it, it looks just like a '39 toploader if you weld on the right gear stick.
    But it was balky to shift from 2nd to 3rd at times, and finally hung up in first gear and wouldn't come out. Took out floor insert and removed shifter to find one of the stamped sheet metal parts had failed, most like from the kind of "enthusiastic" shifting most of us do with a hot rod, and not anticipated by Tremec on a trans meant for a Jeep. Bought the parts online from a dealer in Jeep parts and fixed it.
    After a couple of trips to the drag strip and about a year of around town driving, things went South again.
    So, having another good trans on hand, I pulled that one out, put a Hurst Comp Plus shifter on the spare, installed it and haven't even looked at the other one with Jeep shifter to see what is wrong inside.
  8. deucemac
    deucemac
    Rich, the Jeep T150 for three speeds and the T 176 for 4 speeds. Easy peasy job on both of them. Have a 3 speed in my deuce roadster and the shifter sits within 1 inch of where the original shifter came through.
    bondojunkie and RoddyB34 like this.
  9. Wooster
    Wooster
    from Soso, MS
    Look here on the HAMB at
    Top-Shift Toploaders... OP was Fat Hack and also Top Loader 4 Speed in Model A and OP was threebone.
    bondojunkie likes this.
  10. Merc Flat Head
    Merc Flat Head
    The T-176 shifter conversion is complete! Thanks to all for your help.
    bondojunkie, town sedan and deucemac like this.
  11. junkyardjeff
    junkyardjeff
    I will have to remember this since I do have a 4 speed in stock and nothing to put it in so if I do come up with a 30s car it could go in and have 4 gears and the shifter would not look out of place.
  12. 36tudordeluxe
    36tudordeluxe
    The RUG J-2 top-loader comes with the correct length input shaft for the flathead, it's a little shorter than the top loaders that came with the small block Fords.
    Ric Dean likes this.
  13. 31pickemup
    31pickemup
    Can these 4-speed units be converted to torque tube? and if so who is making the adapter plates?
  14. town sedan
    town sedan
    Don't know, back to the top.
    -Dave
  15. 51504bat
    51504bat
    Not sure but a complete trans from a 4 wheel drive Jeep minus the bolt on rear transfer case would be a good start to convert to a closed drive shaft. If I remember correctly there was a guy here on the Hamb that was advertising an adapter for a closed drive shaft installation but I could be mistaken. Also check with Model Engineering Company. In case anyone is interested there is a 4 speed trans with a jeep top loader shifter for sale on San Francisco Craigslist:
    https://sfbay.craigslist.org/nby/pts/d/ford-mustang-top-loader/6339746834.html Not mine nor do I have any interest or knowledge regarding this trans.
  16. Asphalt Demon
    Asphalt Demon
    from Australia
    IMG_1461.JPG 31 pickemup! I am currently converting a three speed toploader to torque tube and machining up a 5/8 adapter plate. You need to still respline the shaft and cut it down. There is a company in New Zealand that sells these adapters also, named Macs, they sell on evil bay
    town sedan likes this.
  17. fiftyv8
    fiftyv8
    from CO & WA
    Here is some info that may help, I copied from some other thread.
    I think the guy was in Australia who had done it.
    There is a picture as well, but it is not being accepted for loading.
    PM me with an email address and I can send it to you.
    Russ.
    My 3 speed has the Jeep shifter and I converted it to go closed drive to a model A torque tube, shortened the output shaft, made a support adaptor for the clamshell.
    Actually, Ford did build a full-sync 3 speed with OD. In the late 70s into the 80s Ford offered a re-tasked toploader four speed with third gear converted to OD as a stop-gap. Looks just like the four speed, except it has a bulge on the p***enger side of the case to clear the OD gear. A later version had internal linkage and an aluminum case (the SROD), found in light-duty applications. A common issue with both was neither would tolerate more than moderate loading in OD as that would quickly wear out the cluster gear shaft/bearings.
  18. RoddyB34
    RoddyB34
    Machine off the extension housing to support the bearing and allow oil drain back ,,I incorporated a seal in the adaptor
  19. RoddyB34
    RoddyB34
    Forgot this one ,,,the shaft shortened,splined and drilled ,,some shafts reduce in size here ,,mine was from a stumpy pickup trans and was thick enough to get all splined ,,
  20. Asphalt Demon
    Asphalt Demon
    from Australia
    Nice work! So you are running the cut off housing , and the adapter bolted to that? Any reason why? You chose that thickness ? Johnny
  21. RoddyB34
    RoddyB34
    Yes Johnny, the cut off housing is essential for bearing support ,,the adaptor plate I thought might take a bit of a pounding and I wanted the raised ring to help support the clam shell and the oil seal ,,would probably be ok thinner ,had to shorten the drive shaft and tube 48 mm anyway ,with my new engine (Mercruiser 3.0) I have moved everything forward and will use a standard length drive shaft and tube ,,drove it with the A motor works great ,
    Asphalt Demon and town sedan like this.
