Folks Of Interest Picked up an interesting Flathead.
Discussion in 'The Hokey Ass Message Board' started by Pete, Oct 15, 2017.
  1. Pete
    Pete
    Iv been thinking about taking a ride into Boston to snap a pic of the building.
    I'm going to clean up the stand and add some casters so I can roll the engine around.
  2. Ralph Moore
    Ralph Moore
    Very cool find! You should post this on the Ford Barn as there are many flathead aficionados that would love to see it. If I knew how to post a link, I would.
  3. ratrodjay
    ratrodjay
    from Corona, CA
    You definitely scored...big! I know a few guys looking for the crank Stewart warner tack drive alone! (Me included...lol) Major score! Congratulations!!!
    Sent from my SAMSUNG-SGH-I337 using H.A.M.B. mobile app
  4. panicmike
    panicmike
    Great find - I look all the time - missed that one
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  5. oldiron73
    oldiron73
    from WISCONSIN
    That's awesome........
    Nice find.......
  6. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    IMG_0297.JPG Very nice find! Congrats to you! I have over 55 years Flatmotor experience(includes ground floor French flatheads Texas 1999-2005) but have never seen a more unique power plant. Flatheads Forever!
    kidcampbell71 and Stogy like this.
  7. Stogy
    Stogy
    The Museum of Pete will look after it...;)
    Clay Belt likes this.
  8. Pete
    Pete
    It's sitting on the stand right now but I'm going to clean her up and pop a few speed parts on it.
    Stogy likes this.
  9. FritzJr
    FritzJr
    The water pumps and generator are for big truck and bus. The generator seems to be '38 or earlier since it has a cutout rather than a voltage regulator.
  10. dentisaurus
    dentisaurus
    from Boston
    Nice score. Guess I chose the wrong weekend to be out of town, for a number of reasons it turns out.
  11. Okie Pete
    Okie Pete
    Way Cool find . Thank you for sharing .
  12. Duellym
    Duellym
    So you're the one that got that.
    I guess I was a little too late.
  13. greaser
    greaser
    Sweet! I Wonder if it would sound slightly different than a gas powered flathead. (Probably not.)
  14. Truckintom
    Truckintom
    I have worked on many industrial power plants and engines,The ones that run on propane can have many hours on them,the oil and the internal parts of the engine look and for the most part are like new,the reason for this is that propane burns 100 percent cleaner than gasoline,there is no carbon residue left over after combustion,carbon is the reason gas engine oil turns black and wears out engine parts. Propane engine oil will remain clean and see thru for a very long time.I have removed spark plugs from engines on propane that I know have a thousand hours on them,the white porcelain around the electrode will be a light to medium brown color.A usual cause for over heating a propane engine is to lean a fuel mix or a va***e leak , Great find and a nice time capsule from the past
  15. Pete
    Pete
    Appreciate the insight. I’ll prolly pull a cap to see what it looks like.
  16. Outstanding photography! Most would make great 30x40 framed hanging art. Course the subject matter and back story are great. But I'd like a picture wall of your stuff. Camera and lens data would be nice.
  17. battersea boys
    battersea boys
    from surrey
    Why don't you donate it to ford there are a million hot rod flat heads out there , but prolly one back up pump.....just a thought
  18. sailingadventure
    sailingadventure
    What keeps the tach drive from rotating with the crankshaft?
  19. Clay Belt
    Clay Belt
    Why not a propane rod? Complete with BBQ in the bed for tours? :D In all seriousness, sweet find
  20. Glen E MacDonald
    Glen E MacDonald
    I had similar luck a few years ago. A '39 keystone Merc (see avatar) that was only ever used by the local fire department to run a pump used for fire hose practice. Scored the original control panel they had it bolted to as well and incorporated it (along with some new gauges, etc.) into a rolling test stand. Like you Pete, I have the 'virgin' 11" flywheel too. Not even any surface rust on mine!
    34 GAZ likes this.
  21. Doc.
    Doc.
    That's awesome. Love it.
    Here,s two of mine. Came from a U.S. airforce base in Soesterberg, Netherlands.
    They were reverse mounted in the back of two old WW II Jeeps and hooked up via that big round gear thing to a big sweeper out front. The big lever at the rear of the V8 was used by the driver to operate the clutch. Both engines have about 50 hours use according to the instruments on the panel. They were used to sweep snow, not dust.
  23. Mo rust
    Mo rust
    We bought a stationary engine that spent it's life running a pump or something in Oklahoma and inside it was clean as a new one. We dressed it up and played with it and built a roadster to put it in.
    34 GAZ likes this.
  24. Donate it? If Ford wants it, they can afford to buy it.
  25. fordf1trucknut
    fordf1trucknut
    Very cool. I sold a ford flathead v8 K. R. Wilson power plant a year ago for a friends Aunt that was very similar...... Heavy cast iron grill with a v8 emblem and cast guage pannel with a sheetmental hood over it.
    Bummer is that i dont think the guy ever picked it up, he paid for it but never showed up so it is kinda in limbo right now.
    I have one of those stewart warner tach drives sitting on the shelf as well... I always wondered what it would have been used for.
  26. kadillackid
    kadillackid
    x2 :confused:
  27. Here,s my dirty outside, clean inside, reconditioned in 1962 and then hardly run '39 Mercury 99A keystone Flathead. Anyone else have a hardly run Flathead with a story ??
  28. coilover
    coilover
    from Texas
    The blacksmith in the small farm town I grew up in had a WW2 Quonset building with a flathead engine mounted high on one end that did EVERYTHING. Turned shaft that run length of building and with flat belt pulleys for lathe, mill, drill press,etc. It also powered a water pump, a generator, and had an airplane propeller to circulate air in the summer. This was in the late 40's so no pocket cameras but I would love to see a picture of Whitcamp's Welding in Cherokee, Iowa at that time period.
    charleyw and greaser like this.
  29. Finally got around to removing the ungainly and useless auxillary units on my 8BA & 8RT. Makes the units about 65 kilogram each lighter. ( heavy **** ) :eek:Here,s what was inside. Large pressure plate and flywheel clean as a whistle. Any newly discovered industrial flatheads out there ?
    Speedy Canuck and Aaron D. like this.
