Projects Clark Coupe Build
Discussion in 'Traditional Hot Rods' started by etboy97, Dec 21, 2016.
  1. Malcolm
    Malcolm
    from Nebraska
    Cool project - looks good so far! I also have a Blackboard frame under my roadster. Great quality product for a fair price.
  2. etboy97
    etboy97
    That is a good idea. I also am planning on installing a metal panel on the inside of the fire wall that is offset from the fire wall for installing things like the fuse panel so there is something to screw to with out going through the fire wall.
  3. etboy97
    etboy97
    Got the front motor mount welded up, sandblasted, and installed.
    I will build the mid mounts when the body comes off next time.
  4. 29StudeDude
    29StudeDude
    If you want a more modern gauge layout, a company on eBay is making an aluminum insert for your dash. I had one in my '51 Plymouth Concord.
    loudbang and catdad49 like this.
  5. etboy97
    etboy97
    Thanks but I plan on keeping the gauges looking stock.
  6. etboy97
    etboy97
    I went ahead and started the top chop. I have been going back and forth between 3" and 4". I don't want it to be claustrophobic. I decided to start with cutting out 3" and see what I think.
    The hardest part so far was getting the top door pins out.
  7. sloppy jalopies
    sloppy jalopies
    Couldn't tell which you cut first,
    IMO... when I chop a model A I like to make the upper cut first as the body is a lot more rigid for making the second cut than the roof is...
  8. vtwhead
    vtwhead
    How does one handle the taper in the front posts when chopping these A's? Must end up with a bump in the middle of the posts.....
  9. sloppy jalopies
    sloppy jalopies
    I split them top to bottom, I spread the top half, squeeze the bottom half...
    you will have to do this on both door posts and the front and back vertical edges of the quarter window...
    some guys remove the top hinge and cut the "chop amount" from the A pillar...
    brEad and loudbang like this.
  10. etboy97
    etboy97
    Yes I cut the top cuts first.
  11. etboy97
    etboy97
    I finished the lower cuts today and sat the top down to see what I thought of the 3" removed. After sitting in it I am going to stop at 3".
  12. etboy97
    etboy97
    Got the top welded back on along with one of the door tops.
  13. brianf31
    brianf31
    The 3" chop looks perfect.
    chop job and loudbang like this.
  14. brady1929
    brady1929
  15. vtwhead
    vtwhead
    nice job....lots of welding and grinding huh? goes with the territory.............
  16. etboy97
    etboy97
    Yes it gets tedious. You have to keep telling yourself just a tack or two at a time and not get carried away with the welding. I am happy with the way it turned out but it in no way compares with what the guys that can metal finish can do.
    oliver westlund and loudbang like this.
  17. vtwhead
    vtwhead
    Agreed, I am no @Flop for sure. Just finished chopping my A coupe 3 1/2. I cheated and did only two hinges as that is how my old timer friend does it. Still lots of work for one guy alone as you can attest to. I am skim coating now. Another hateful job imho. :D
    loudbang and rally1 like this.
  18. fiftyv8
    fiftyv8
    from CO & WA
    Yes, 3" chop helps keep some shape in the 1/4 windows which I like better.
    Rear window in your chop looks pretty nice also.
    Front engine cradle is awesome...
    brEad likes this.
  19. CURSED GEARS
    CURSED GEARS
    Nice build. I want to read more! That front motor mount looked impressive.
  20. etboy97
    etboy97
    Been working on the doors. I had a hard time getting the rest of the door hinge pins out but finally got them all out. The next struggle was getting the body mounted side of the hinges off (I have only done the p***enger side so far). I ended up having to drill out the screws after trying to weld nuts on to the screws heads did not work. I ended up having to weld up the hinge screw holes so I could drill and re-tap them. Both of my doors sagged down low and had some gap issues at the front edge. I am sure the door has been over extended and bent the hinges. With a little tweaking of the hinges with my press I have gotten the p***enger side to door to line up nice. Will get started on the drivers side next.
    Here is the p***enger door bottom with the bondo ground off.
    I replaced the lower door skin and door frame bottom section.
    Door alignment after the hinges were tweaked.
    I messed up the middle hinge some getting the door pin out so need to weld up the hole. Here is my idea to fix it instead of welding up the entire hole. I have not tried it yet but it should work. I took some sheet copper and wrapped it around a framing nail to give a diameter just smaller then the door pin. With the door set and this copper clad pin installed I should be able to weld up the gap, drive out the copper pin and then drill out the hole to the correct size.
  21. loudbang
    That is some awesome thinking "outside the hole" :)
  22. brianf31
    brianf31
    Nice! Who's door frame bottom piece did you use? I have to do this job soon and I need to figure out the door bottom location. Do you mind pulling a dim when you get a chance? The opening from the top edge of door bottom would work.
  23. etboy97
    etboy97
    All of my sheet metal is from Brattons. See below for dimension. Is this what you wanted? IMG_20171207_135457716.jpg
  24. brianf31
    brianf31
    Perfect! Thanks for going through the trouble.
    osage orange and loudbang like this.
  25. chop job
    chop job
    from Wisconsin
    Love the chop good job. For door pins check out the door pins for interior doors of your house at the hardware store , worked fo me.
  26. etboy97
    etboy97
    Now that the holidays are over I have been able to get back to work on the car. I got the drivers side door patch panel complete and the door adjusted to fit.
    I installed a Brookville 32 cowl vent as I love having a cowl vent on the hot days.
  27. banjorear
    banjorear
    Dang. Lookin' good, man. Great work.
  28. sloppy jalopies
    sloppy jalopies
  29. Just checking in on the progress. Looks awesome.
  30. etboy97
    etboy97
    Thanks. Glad you are enjoying it.
    sstock...not likes this.
