Customs Merc chop progress with compiled project pics
Discussion in 'The Hokey Ass Message Board' started by Verbal Kint, Jun 1, 2009.
  1. Kustomkid
    Kustomkid
    from Montana
    And the gauges are working!!! Oil pressure is running on the low side, but fuel and temp are working fine. Next are tail lights. [​IMG]
    55Deso, chryslerfan55, drdave and 4 others like this.
  2. Squablow
    Squablow
    Great update! I'm jealous.
    OG lil E and Kustomkid like this.
  3. Kustomkid
    Kustomkid
    from Montana
    Been trying to get it ready for Labor Day weekend, but there is to much to do and not enough time to do it all in. But I should be able to drive it around a bit in a couple weeks. I hope.....
    drdave, Squablow and OG lil E like this.
  4. Kustomkid
    Kustomkid
    from Montana
    I think I got the sides of the headliner figured out. I end up cutting a 1/4 inch rod to run from the header to the rear headliner bow. Wired it to all of the headliner bows and wire tied the last panel to it to pull in between bows to have a smoother look instead of the sags. I think it looks better. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    I steamed the sides just a little to pull the last of the wrinkles out. I hope the rear garnish moldings will help out also. Now p***enger side.
  5. It is nice to see that you are close to having your driver.
    Bob
    Kustomkid, OG lil E and chryslerfan55 like this.
  6. Kustomkid
    Kustomkid
    from Montana
    And the p***enger side is reworked. Got to get the front garnish molding off and rework the corners, but the rods seem to have worked. [​IMG][​IMG]
  7. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
  8. greaser 35
    greaser 35
    from FRANCE
    Beautiful!!,I like tour Merc!!;)
  9. drdave
    drdave
    That's a good idea right there. Nice job!!
    Kustomkid and OG lil E like this.
  10. Kustomkid
    Kustomkid
    from Montana
    Well the merc is settled back in the garage for the winter and ready to finish the upholstery. Got to finish arranging the garage but should be able to drive a merc come spring![​IMG][​IMG]
    K13, 50fish, chryslerfan55 and 6 others like this.
  11. Kustomkid
    Kustomkid
    from Montana
    Got the front insulation down and part of the carpet fit. Still needs to be bound but it fits pretty good. [​IMG][​IMG]
    And the driver side. Hopefully I might be able to bind it this weekend and get the seat back in. [​IMG]
  12. Lookin' sharp, @Kustomkid! What an awesome build! It has been a lot of fun following along. Keep up the great work! E
    chryslerfan55 and Kustomkid like this.
  13. drdave
    drdave
    Looks nice!! Can you come do mine when you are done? I was just vacuuming it out last evening after washing it and thought, man I need so fresh carpet in this thing. LOL
    chryslerfan55, OG lil E and Kustomkid like this.
  14. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Looking good Ryan!
  15. Kustomkid
    Kustomkid
    from Montana
    55Deso, OG lil E, Squablow and 2 others like this.
  16. drdave
    drdave
    Nice job!
  17. Kustomkid
    Kustomkid
    from Montana
    Just finished the steering column cover. Need to cut the insulation but I think that will work. [​IMG][​IMG][​IMG]
    Squablow, OG lil E, drdave and 2 others like this.
  18. Kustomkid
    Kustomkid
    from Montana
  19. drdave
    drdave
    Splendiferous!!
  20. K13
    K13
    Looks good!
    OG lil E likes this.
  21. Kustomkid
    Kustomkid
    from Montana
    The merc is licensed! Might be able to take it on real test drive shortly!
  22. Chavezk21
    Chavezk21
    Well? How was the real test drive?
  23. Kustomkid
    Kustomkid
    from Montana
    Needle and seat stuck closed and died crossing the street. But ran better before that happened.
  24. Chavezk21
    Chavezk21
    Well dang!
  25. drdave
    drdave
    Now we’re getting somewhere! Congrats on the registration, bummer on the carb.
  26. Kustomkid
    Kustomkid
    from Montana
    I have another 97 I’m going to rebuild and try next weekend.
    chryslerfan55, OG lil E and drdave like this.
  27. Kustomkid
    Kustomkid
    from Montana
    Got the frame work built for the other taillight. Going to try and install it Tuesday evening and maybe have taillights working for the forth of July [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  28. Kustomkid
    Kustomkid
    from Montana
    Taillight is in. Got some adjustments to do but it’s in. Now some wiring.....[​IMG][​IMG]
  29. drdave
    drdave
    That's a nice piece you made to mount the lights. Is that how you did it in your first Merc?
  30. Kustomkid
    Kustomkid
    from Montana
    Yeah, pretty much. I didn’t have a shrinker/stretcher when I did the old merc, so it was 4 pieces instead of 2. Held onto my broken lenses for 20 years to do another set of lenses
    Squablow and drdave like this.
