Technical Brake line bending
Discussion in 'The Hokey Ass Message Board' started by 48stude, Oct 21, 2017.
  1. 48stude
    48stude
    This bend is as close to the fitting as my tubing bender will allow. I need the bend to be at least a half inch closer to the fitting.
    Will this tool enable me to shorten up the distance from the fitting? Thanks , Bill s-l200.jpg
  2. manyolcars
    manyolcars
    Use your hands and thumbs. Brake line bends easily
  3. Truck64
    Truck64
    from Ioway
    Maybe if you fill the tubing with fine sand?
  4. Tim
    Tim
    from KCMO
    Can you make the bend and then slide the fitting on and flair it? Might get you closer
    Bandit Billy and 1934coupe like this.
  5. Tim
    Tim
    from KCMO
    He’s not trying to bend it tighter and trying to avoid a kink, he wants the bend physically closer to the fitting. His bending tool won’t seat with the fitting any closer.
  6. manyolcars
    manyolcars
    I insert the proper size Phillips screwdriver for this purpose and bend by hand
  7. V8 Bob
    V8 Bob
    If that's 3/16" steel tube, you might try and bend with your hands. Fashion a "handle" about 6" in length out of 1/8" pipe and a pipe-to-female 3/16" inverted flare fitting. Thread the tube nut into the fitting, then place the handle in one hand, tube in the other, and slowly bend with your thumbs. 3/16" is pretty forgiving and will bend fairly sharp without kinking, if done slowly. This is the method I use/used for 95% of all the 3/16" brake lines I've ever made.
    Blues4U and gimpyshotrods like this.
  8. DDDenny
    That may work but also could gink the tube at the screwdriver point and/or leave a weak spot to allow a crack to form, better to use a piece of aluminum rod with a radius formed on the end.
    Put a loop on the end to pull the rod out if it catches in the bend.
  9. Hemi Joel
    Hemi Joel
    from Minnesota
    Could you use a 90-degree fitting instead? And the brake line would be straight.
    Automotive Stud and v8deuce like this.
  10. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    You might have to bend it the other way....... Not starting from the fitting/flare, but from the line to where your 90* stops at the fitting..... But this requires making a new line........ Been there before.
    Hot Rod Grampa and Mr48chev like this.
  11. Ed Angel
    Ed Angel
    Put a socket or tube in a vise , and pull the bend with both hands . The socket will keep you from kinking the tube .
    Woogeroo, RMR&C and Truck64 like this.
  12. gimpyshotrods
    gimpyshotrods
    I hand bend brake lines all of the time. As long as you don't go all wackadoodle, you will be fine.
    I am 30-years in, and hundreds of lines deep. Zero failures.
    V8 Bob likes this.
  13. DRD57
    DRD57
    The short answer to your actual question is: Yes.
    The flat side of the tool pictured goes right against the flare nut and you just pull the tube over the curved die.
    Just Gary and X38 like this.
  14. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Looks like basic steel line. Try NiCopp brake line its Nickle/Copper line. You can bend it by hand and straighten it back out if you need to without a bender. For a tight 90 like your looking for here I would use the NiCopp with a 3/8 wrench to hold the nut and a 5/16 deep socket in a vice with nice easy pressure and it will bend right around nicely without kinking. I'm not a salesmen. I get my NiCopp from Advance Auto try it.
    Russco and Blues4U like this.
  15. Marty Strode
    Marty Strode
    DRD57 is correct, That style of tool works great for the tight spots. I used one on the line exiting the master cyl on this car. IMG_0685.JPG
    Timmyd, Countn'Carbs and Blues4U like this.
  16. Mike VV
    Mike VV
    from SoCal
    I PACK the tube with salt and close with tape.
    There IS a limit that the given diameter tube will bend without kinking..!
    Mike
    OLDSMAN likes this.
  17. hotrodA
    hotrodA
    Will this tool enable me to shorten up the distance from the fitting? Thanks , Bill View attachment 3691688 [/QUOTE]
    What's the scoop on this bender? Looks like a good addition to my toolbox.
  18. 28 Ford PU
    28 Ford PU
    from Upstate NY
    48stude likes this.
  19. DRD57
    DRD57
    Google "brake line tubing bender".
    Lots of places sell them like Amazon, Eastwood, Sears, etc.
    Neiko 20726A is one example.
  20. V8 Bob
    V8 Bob
  21. Yes!! That tool will do what you need.
    There's another one, like this.
    I made one using vice old vice grips. The radius starts imediatly.
    It works amazingly well on the bench and under a car. It doesn't show the fitting here but you can get right up close.
    48stude and trollst like this.
  22. lostone
    lostone
    from kansas
    I'm looking into this myself, 31Vicky do you have a couple pics of the one you made?
  23. ^^^ That ni copp photo above looks like it has flattened the tube to much to my eye. I wouldn't run it.
    I have a few different tubing benders including one that doesn't crimp like the pliers style does but actually is designed to be placed in a vice and has no moving parts. You just bend the tubing around it.
    Sometimes you can actually put the nut on the end of the brake line into the stationary arm on the bender and go from there. In other words the threads of the nut are touching the bender stationary arm as you bend the tube. Typically there's not enough force to damage the threads.
    If that makes any sense.
  24. image.jpeg Or use one of these - gets you out of a tight spot, or somewhere where you cant swing a spanner, but can get in with a socket.
    winduptoy likes this.
  25. oj
    oj
    I have Rigid brand benders and when I need very tight bends I use a box end wrench on the hex of the brake line fitting and use that to tighten the radius. The wrench acts like a lever and the tube fitting keeps the tube from kinking, you pull down a little and move the fitting, pull down and move.
    Just Gary likes this.
  26. seamus43
    seamus43
    WHAT FOR CYLINDER FROM WILWOOD ? THANK YOU,SEAMUS
  27. 48stude
    48stude
    WOW! A lot of responses:) Tomorrow, I'll have a lot of your methods to try. I'm gonna make a run to the Chinese store tomorrow first thing.
    28 FORD PU If I hadn't already bought 100' of 3/16 tube for another idea I had, I would try that nickle/copper line out. I really appreciate you guys chiming in :):) Bill
  28. Marty Strode
    Marty Strode
    seamus, I don't understand the question. It's a 1" bore.
  29. Budget36
    Budget36
    Bill, sometimes it's better to spend a few extra bucks for something that may work better, than to use what you have on hand.
    PLus, you'd still have a lot of 3/16th left over:)
  30. 28 Ford PU
    28 Ford PU
    from Upstate NY
    This was just a s**** piece I didn't run out and buy one to give a perfect example. No matter how you try to help around here there is always someone ready to bash your head in!!!!
