Customs Can anyone I.D. this transmission for me?
Discussion in 'The Hokey Ass Message Board' started by Kerrmudgeon, Oct 22, 2017.
  1. Kerrmudgeon
    Kerrmudgeon
    from Canada
    I'm trying to find a four speed auto for my 56 Chev convertible. I'm told that a 200R4 has the same overall length as my powerglide. A buddy has this trans available and I don't know enough about them to ID it. Check it out and see if it's what I need.....thanks!
  2. Dick Stevens
    Dick Stevens
  3. EnglishJon
    EnglishJon
    It's a late TH700R4/4L60 with an auxiliary valve body. And electric speedo.
    Kerrmudgeon likes this.
  4. [​IMG]
    I know I have another one about ID ing by pan gasket shapes, but I can't seem to find it quickly right now.
    Your pic does have a 700r4 look like the one in my Stude, but I built mine 20+ yrs ago, so I am using old memory :)
    WHY BE ORDINARY ?
  5. [​IMG]
    WHY BE ORDINARY ?
  6. squirrel
    you don't need a chart to see that it's a 700, do you ?
  7. EnglishJon
    EnglishJon
    I always find the 'transmission ID' charts that use pan gaskets could always be more informative. They often don't show the orientation in the vehicle, they don't specify whether you are looking up or down at the unit and are reproduced at varying sizes mixed together.
  8. Kerrmudgeon
    Kerrmudgeon
    from Canada
    Yes Jim, I DO need help ID-ing any automatic. Driven manual four speeds most of my life.
    Thanks gents, for all the quick responses and charts. A great help.
    Any idea as to value?
  9. gimpyshotrods
    gimpyshotrods
    $150-400USD depending on condition.
  10. squirrel
    Working at a junkyard for a while should be a prerequisite for building hot rods
    saltflats likes this.
  11. Budget36
    Budget36
    They had 700R4's in the 70's? ;)
    sawbuck and Kerrmudgeon like this.
  12. Kerrmudgeon
    Kerrmudgeon
    from Canada
    Probably more like....in the 60's. :D
    Budget36 likes this.
  13. Kerrmudgeon
    Kerrmudgeon
    from Canada
    Now any of you wise guys know if there's anyway that trans would fit in my 56 chev ragtop with the X braced frame? Does it need a computer to run it? and I thought there was a way to hook up the mechanical speedo instead of the electric? I know the 200r4 is the same length as my powerslide but I'm not sure about the 700r4 swap.
    Thanks in advance.
  14. gimpyshotrods
    gimpyshotrods
    Neither a 700R4 or a 2004R require a computer. They do require a 12+ IGN wire, if you'd like the torque converter to lock up in high gear. Both can have mechanical speedometer drives.
    Neither is the same length as a Powerglide, although, if you have the longer aluminum Powerglide, a 2000R4 is pretty close.
  15. gimpyshotrods
    gimpyshotrods
    The "X" looks like it is largely behind where the body of the transmission is:
  16. Kerrmudgeon
    Kerrmudgeon
    from Canada
    Thanks for the info.....very helpful. I guess I'll p*** by the Tri-five forum and see what's up with the swap. cheers.
  17. squirrel
    heh...nope! and I quit working at the junkyard in 1982, just after the 700 came out. I saw my first one at the transmission shop, where I worked next. They had trouble with them from the beginning.
