Technical 302 and t5 in 56 customline
Discussion in 'The Hokey Ass Message Board' started by Jeremy Welker, Oct 21, 2017.
  1. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    We want to put a 302 and T5 manual Tran in a 1956 Ford Customline. Will it fit? What parts would I need? How much modification would I have to do? Should I just go with a different transmission?
  2. jimmy six
    jimmy six
  3. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    cause i would like input and the knowledge and experience from someone that knows more than i
  4. RICK R 44
    RICK R 44
    If the T5 is out of a Mustang, the shifter will be very close to the stock seat. You might be able to modify the shifter or go with bucket seats. The other option is to use an S10 pick up tail shaft on your trans. I put a Mustang T5 in a 55 crown vic for a customer. If you want more info, e mail me at springgrange@personainternet.com
  5. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    thank you, how much will i have to modify the hump? we had another thought about a truck 3 speed with overdrive, im thinking it would be shorter
  6. HOTRODPRIMER
    HOTRODPRIMER
    I have a 302 & a 5 speed in our 54 Ford Ranch Wagon,you will have to modify the X member but that's not to hard to do.
    I used the engine & transmission out of a 84 Mustang and I modified a old Hurst stick to bolt in place,I also kept the original bench seat.
    If you will click on the link of my build it may help you with some of your questions. HRP
  7. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    what did u do for trans mount
  8. HOTRODPRIMER
    HOTRODPRIMER
    Made a flat plate and used the Mustang mount. HRP
  9. Mr48chev
    HRP shows the trans crossmember in photo 67 of his album He shows the engine and trans install in the bare ch***is in photo 66. Those start on page 3.
    http://public.fotki.com/hotrodprimer/hotrodprimer-1/page3.html
    Looking at photo 70 I'd think you can get the shifter to come out right where you would want it in the 56. Right about where the shifter on a 4 speed would be.
  10. Jeremy Welker
    Jeremy Welker
    from Mendon OH
  11. Mr48chev
  12. evintho
    evintho
    Answers to all your questions in the '52-'59 Ford Social Group.
    At the top of this page click on the 'Members' tab (the 3 heads), click on 'social forums', click on 'brands' then find the '52-'59 Ford Social Group. Everything you need to know is in there.
    BTW, I'll be putting a 302/AOD in a '54 Customline next year.
    JeffB2 likes this.
  13. Rocky72
    Rocky72
    from Pa.
    If your shifter is back to close to the seat you could make a linkage setup to move the shifter towards the dash . I did this with a Ford 302 and T5 ****** and put it in my 36 Chevy pickup , it was never road tested but seemed to shift through the gears with no problem . I don't think I have any pics of the setup but I'll look.
  14. HOTRODPRIMER
    HOTRODPRIMER
    I used a old Hurst 3 speed shifter,I cut the bottom off and drilled holes to attach the shaft protruding from the transmission. HRP
  15. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    would a 3 speed with overdrive out of a f150 do me better , or will o run into more problems?
  16. HOTRODPRIMER
    HOTRODPRIMER
    I don't have a clue,after living with it for the last 5 years if I were to do it over I wouldn't change a thing. HRP
  17. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    do you have a bench seat?
  18. gimpyshotrods
    gimpyshotrods
    Fill out your profile to include your location.
    I have a Mustang T5, and a S10 T5 for sale. With the S10 tail on the Mustang T5, and a speedometer gear relocator, you will not have seat interference.
  19. gimpyshotrods
    gimpyshotrods
    More gears = more better. The gear spread on the 3+od is to wide. It is a great truck transmission, but you're not building a truck.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Jeremy,have you even looked at the link I posted? and so did another member,there are over 300 step by step build photos that will answer a lot of your questions. HRP
    CLICK HERE
  21. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    yes i did and it has i keep going back to it
  22. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    i really like this idea, wish i was closer probally cost a small fortune to ship. but i would like to learn more about it, is their a website on how i can do this myself?
  23. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    im confused on what he did with the k member. one picture looks like he took it out and the next its there. doesnt mention if he modified it or the tunnel. im not afriad of modifying either 1 if i have too. im sure i will have too. guy did a amazing job
  24. 3W JOHN
    3W JOHN
    danny tells you what is done under every picture
  25. gimpyshotrods
    gimpyshotrods
    Top cover, shift rail, shift forks (all one ***embly) come from the S10 T5, and go onto the Mustang T5.
    A speedometer gear relocator from that auction site puts the S10 speedometer gear on the Mustang output shaft, in the S10 location. A Mustang T5 bushing and seal go in the S10 T5 tail housing, and then it goes on the Mustang T5.
  26. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    any idea what year s10 or sonoma
  27. Jeremy Welker
    Jeremy Welker
    from Mendon OH
    or how much do u need for just the parts for me to do the swap
  28. gimpyshotrods
    gimpyshotrods
    Up to 89. After that, they have an electronic speedometer drive.
  29. gimpyshotrods
    gimpyshotrods
    WHERE ARE YOU LOCATED!
    A T5 is a heavy thing. Shipping might make it a bad deal.
  30. evintho
    evintho
    I've shipped a couple of T5's from here to the east coast via FedEx........$85.
